NORGREN VP10电气比例阀
NORGREN VP10电气比例阀是可靠的I/P E/P转换器,高精度,高流量 IP65防护等级,适用范围非常广泛。
NORGREN VP10电气比例阀技术参数:
介质Medium: |
Oil free, dry air, filtered to 5micron |
输出压力Output Pressure: |
0.2-1.0bar(3-15psig), 0.2-2.0bar(3-30psig), 0.2-4.0bar (360psig), two wire version
0.2-6 bar (2-90psig) 0.2-8bar (2-120psig) three wire version |
流量Flow Capacity: |
Up to 300Nl/min (10scfm) |
空气消耗Air Consumption: |
<4bar: 0.85l/min (0.03scfm) typical >4bar: 1.75l/min (0.06scfm) typical |
工作压力Operating Pressure: |
At least 0.7bar above maximum required output pressure |
接口Connections: |
G1/4 |
工作温度Operating Temperature |
-20 ℃to 70℃ |
响应时间Response Time:
<2bar/30psig: less than 0.5seconds for 10-90% step change >2bar/30psig: 2 seconds for 10-90% step change |
结构材质Material of Construction:
Zinc die-casting passivated and epoxy paint, nitrile diaphragms, stainless steel/nylon flapper nozzle and supply valve |
质量Mass:
1500g approx. |
NORGREN VP10电气比例阀选型表:
订货号 |
Pressure range and input signal options |
Part Number |
Control signal |
Output Pressure |
VP1001BJ100A00 |
0-10V |
0.2-1bar |
VP1001BJ400A00 |
4-20mA |
0.2-1bar |
VP1002BJ100A00 |
0-10V |
0.2-2bar |
VP1002BJ400A00 |
4-20mA |
0.2-2bar |
VP1004BJ100A00 |
0-10V |
0.2-4bar |
VP1004BJ400A00 |
4-20mA |
0.2-4bar |
VP1006BJ101A00 |
0-10V |
0.2-6bar |
VP1006BJ401A00 |
4-20mA |
0.2-6bar |
VP1008BJ101A00 |
0-10V |
0.2-8bar |
VP1008BJ401A00 |
4-20mA |
0.2-8bar |
