德国HBM称重传感器:
波纹称重传感器:
Z6FD1: 5KG 10KG 20KG 50KG 100KG 200KG 500KG 1T
Z6FC3: 5KG 10KG 20KG 50KG 100KG 200KG 500KG 1T
Z6FC3MI: 50KG 100KG 200KG
Z6FC4: 10KG 20KG 50KG 100KG 200KG 500KG
Z6FC6: 50KG 100KG 200KG
力传感器:
C18: 10 kN,20 kN, 50 kN, 100 kN, 200 kN,300 kN, 500 kN, 1 MN, 2 MN,3 MN,
4,5 MN
C2: 1-C2/50KG 1-C2/100KG 1-C2/200KG 1-C2/500KG 1-C2/1T 1-C2/2T 1-C2/5T 1-C2/10T 1-C2/20T 1-C2/50T
2-C2/50KG
C4: 20KN, 50KN,100KN,200KN,500KN
C6A: 200KN,500KN,1MN, 2MN, 5MN
C9B: 50N,100N,200N,0.5KN,1KN,2KN,5KN,10KN,20KN,50KN
KD: 1000KN,2000KN,3000KN,5000KN
STZ: 600KN,1000KN
KDB: 2000KN
KMR: 20KN,40KN,60KN,100KN,200KN,300KN,400KN
PACEline CMC: 5KN, 20KN, 50KN, 70KN, 120KN
S2: 20KN,50KN,100KN,200KN,500KN,1000KN
S9: 2KN,5KN,10KN,20KN,50KN
TOP-Z230: 100N,200N,500N,1000N,2KN,5KN,10KN
TOP-Z4A: 20KN,50KN,100KN,200KN,500KN
U-10M:1.25KN, 2.5KN, 5KN, 12.5KN, 25KN, 50KN, 125KN, 250KN 5OOKN
U15: 2.5KN, 5KN, 10KN, 25KN, 50KN, 100KN, 250KN 5OOKN 1MN
U1A: 10N 20N 50N
U2B: 0.5KN 1KN 2KN 5KN 10KN 20KN 50KN 100KN 200KN
U3: 0.5KN 1KN 2KN 5KN 10KN 20KN 50KN 100KN
U5: 100KN 200KN 500KN
U93: 1KN 2KN 5KN 10KN 20KN 50KN
U9B: 50N 100N 200N 0.5KN 1KN 2KN 5KN 10KN 20KN 50KN
Z30: 50N 100N 200N 500N 1000N 2KN 5KN 10KN
Z30A: 50N 100N 200N 500N 1000N 2KN 5KN 10KN
Z4A: 20KN 50KN 100KN 200KN 500KN
压力传感器:
P15RVA1 / P15RVA2: 10bar 20bar 50bar 100bar 200bar 500bar
P2VA1 (output signal in V) : 100bar 200bar 500bar 1000bar 2000bar
3000bar 5ooobar
P2VA2 (output signal in mA): 100bar 200bar 500bar 1000bar 2000bar
3000bar 5ooobar
P3, P3MB. P3MBP: 10bar 20bar 50bar 100bar 200bar 500bar
1000bar 2000bar 3000bar
P3 Top Class: 10bar 20bar 50bar 100bar 200bar 500bar
1000bar 2000bar 2500bar 3000bar
P6A: 10bar 20bar 50bar 100bar 200bar 500bar
P8AP: 10bar 20bar 50bar 100bar 200bar 500bar
U2A: 5OKG 100KG 200KG 500KG 10T 20T
U2AD1: 500KG 1T 2T 5T
RTN0.05: 1T 2.2T 4.7T 10T 15T 22T 33T 47T 68t 100t 150t 220t 330t 470t
RTNC3: 1T 2.2T 4.7T 10T 15T 22T 33T 47T 68t 100t 150t 220t 330t 470t
S型传感器
S2: 20N,60N,100N,200N,500N,1000N
RSCA C1:50KG 100KG 200KG 500KG 1T 2T 5T
RSCA C3:500KG 1T 2T 5T
RSCB C1:200KG 500KG 1T 2T 5T
RSCB C2:500KG 1T 2T 5T
SSC D1:550KG 880KG
SSC C1:880KG
S40 : 50KG 100KG 200KG 500KG 1T 2T 3T 5T
单点式称重传感器:
SP1 20G,30G
SP2 100,300g
SPL 0.3,0.6,1.5,3 KG
DF6S 1,2,4,5,10,15,20,30KG
PW2AC3 7.2,12,18,36,72KG
PW4KRC3 0.3,0.5,2,3,KG
PW6KR 3,5,10,15,20,30,40KG
PW6KRC3 3,5,10,15,20,30,40KG
PW6KRC3MR 3,5,10,15,20,30,40KG
PW24AC3 100,200,300KG
SP4C3 3,5,7,10,15,20KG,30,50,75,100,200KG
PW10C3 50,100,150,200,250KG
PW12B 75,150,200,250KG,300,500,635KG
PW15C3 7.5,15,20,30,50KG,75,100,150,200KG
PW16C3 30,50,75,100,150KG,200,250,300,500,660KG
数字称重传感器:
PW20i:5KG 10KG 20KG
FIT/0: 5KG 10KG 20KG 50KG 75KG
FIT/1: 5KG 10KG 20KG 50KG 75KG
FIT/4: 5KG 10KG 20KG 50KG 75KG
FIT/5: 5KG 10KG 20KG
C16ID1: 20T 30T 40T 60T
C16IC3: 20T 30T 40T 60T
剪切梁式称重传感器:
HLC_D1: 220kg 550kg 1.1t 1.76t 2t 4.4t
HLC_C3: 220kg 550kg 1.1t 1.76t 2t 4.4t
HLCBD1/1OT
HLCF1D1: 220kg 550kg 1.1t 1.76t
HLCF1C3: 220kg 550kg 1.1t 1.76t
Z7AD1: 0.5T 1T 2T 5T 10T
Z7AC3: 2T 5T 10T
柱式传感器:
C16AD1:15T 20T 30T 40T 60T 100T
C16AC3:15T 20T 30T 40T 60T 100T
C16AD1/1OOT
C16A/200T
1-C16AC3/20T/EEXD
1-C16AC3/30T/EEXD
1-C16AC3/40T/EEXD
1-C16AC3/50T/EEXD
1-C16AC3/60T/EEXD
1-C16AC3/100T/EEXD
1-C16AC3/200T/EEXD
称重模块:
Z6AMC4: 50KG 100KG 200KG 500KG
Z6AMC6: 50KG 100KG 200KG 500KG
Z6AMD1: 220KG 550kg 1.1t 1.76t 2t 2.2t 4.4t
Z6AMc3: 220KG 550kg 1.1t 1.76t 2t 2.2t 4.4t
Z6MD1: 50KG 100KG 200KG 500KG
Z6MC3: 50KG 100KG 200KG 500KG
RTN/MC3: 1T 2.2T 4.7T 10T 15T 22T 33T
C2A/M1D1: 1T 2T 5T 10T
C2A/M1C3: 1T 2T 5T 10T
C2A/M1C4: 1T 2T 5T 10T
C16D1: 20T 30T 40T 60T 100T 200T
C16C3: 20T 30T 40T 60T 100T 200T
C16C4: 20T 30T 40T 60T 100T 200T
HLCM: 220KG 550KG 1.1T 1.76T 2T 2.2T 4.4T
RTN/M2LAR2.2T: 1T 2.2T
RTN/M2LAR4.7T:4.7T
RTN/M2LAR22T: 10T 15T 22T
RTN/M2LAR33T: 33T
C16M: 20T 30T 40T 60T 100T 200T
扭矩传感器:
SK5/40 SK5/55 SK5/95
SK6/40 SK6/55 SK6/95
SK12/40 SK12/55 SK12/95
T10F/50Nm T10F/100Nm T10F/200Nm T10F/500Nm T10F/1KNm T10F/2KNm T10F/3KNm T10F/5KNm T10F/10KNm
T10FH/100KN T10FH/130KN T10FH/150KN T10FH/200KN T10FH/250KN T10FH/300KN
T10FM/15kNm T10FM/20kNm T10FM/25kNm T10FM/30kNm T10FM/40kNm T10FM/45kNm T10FM/50kNm T10FM/60kNm T10FM/70kNm T10FM/80kNm
T10FS/100Nm T10FS/200Nm T10FS/500Nm T10FS/1kNm T10FS/2kNm T10FS/3kNm T10FS/5kNm T10FS/10kNm
T12/500NM...1KN , T12/2KN....3KN, T12/5KN,T1210KN
T20WN/0.1Nm T20WN/0.2Nm T20WN/0.5Nm T20WN/1Nm T20WN/2Nm T20WN/5Nm T20WN/10Nm T20WN/20Nm T20WN/50Nm T20WN/100Nm T20WN/200Nm
T22/5NM,T22/1ONM,T22/20NM,T22/50NM,T22/100NM,T22/500NM,T22/1KNM
T40/500NM,T40/1KN,T40/2KN,T40/3KN
T4A/5Nm T4A/10Nm T4A/20Nm T4A/50Nm T4A/100Nm T4A/200Nm T4A/500Nm T4A/1000Nm
T4WA-S3/5Nm T4WA-S3/10Nm T4WA-S3/20Nm T4WA-S3/50Nm T4WA-S3/100Nm T4WA-S3/200Nm T4WA-S3/500Nm T4WA-S3/1000Nm
T5/10Nm T5/20Nm T5/50Nm T5/100Nm T5/200Nm
TB1A/100Nm TB1A/200Nm TB1A/500Nm TB1A/1KNm TB1A/2KNm TB1A/5KNm TB1A/10KNm
TB2/500Nm TB2/1KNm TB2/2KNm TB2/3KNm TB2/5KNm TB2/10KNm
TN/100Nm TN/200Nm TN/500Nm TN/1kNm TN/2kNm TN/5kNm TN/10kNm TN/20kNm
TTS/100Nm TTS/200Nm TTS/500Nm TTS1K/Nm TTS/3KNm
位移传感器:
W1EL/0
WA L - 电感式标准传感器(活塞)
WA2, WA10, WA20, WA50, WA100, WA200, WA300, WA500
WA T - 电感式标准传感器(探针)
WI/2mm-T, WI/5mm-T, WI/10mm-T
应变传感器:
DD1, SLB-700A/06
称重仪表:AD101B, AD103C, AD104C, AD105C, AED Basic Devices , RM4220 ,
SC232/422B, WE2107, WE2108, WE2110
接线盒
VKK4 VKK1R-4 VKK2-6 VKK2-8 VKK2R-8 VKK2R-8DIGITAL
VKEEX
SB01A 安全栅, SD01A:Zener安全栅
CABA16线制电缆, CABE2 应用于防爆环境的6线制电缆
