产品介绍: |
产品详细说明:
SCDI (直角持续漫射光源) 提供增强的漫射光源特性。SCDI是一项专利设计,它非常适合于中度多层面和中度不平整反射表面的照明。这些机器视觉光源可以允许物品在包装中被检测,从而防止造成视觉系统非均匀的反射光线而无法检测到缺陷。
- 2种颜色和3个尺寸
- 出色的统一性
- 突出的扩散照明
- 经济实惠,维护成本低
- 可靠,固态LED照明
照明举例: 齿轮轴上的Data Matrix码: 漫射照明可形成清晰图像以获得标记符号信息
工作原理:
| 25 mm Continuous |
| Part Number |
Description |
| NER-011301300 |
SCDI-25, R LED-D, 24V-C, 4.5M (15 ft.) Cbl w/Flying Leads |
| NER-011301302 |
SCDI-25, W LED-D, 24V-C, 4.5M (15 ft.) Cbl w/Flying Leads |
| 50 mm Continuous |
| NER-011304004 |
SCDI-50 V2, R LED-D, 24V-C, 4.5M (15 ft.) Cbl w/Flying Leads |
| NER-011304014 |
SCDI-50 V2, W LED-D, 24V-C, 4.5M (15 ft.) Cbl w/Flying Leads |
| 75 mm Continuous |
| NER-011302005 |
SCDI-75, R LED-D, 24V-C, 4.5M (15 ft.) Cbl w/Flying Leads |
| NER-011302012 |
SCDI-75, W LED-D, 24V-C, 4.5M (15 ft.') Cbl w/Flying Leads |
| Power Supply (25, 50,75 mm continuous) |
| NER-011504100 |
DSP60 24VDC 2.5A DIN Mount Power Supply |
| Power Supply Cordsets |
| NER-030028300 |
AC Power Cord for DSPxx Power Supply, US |
| NER-030028400 |
AC Power Cord for DSPxx Power Supply, EU |
| NER-030028500 |
AC Power Cord for DSPxx Power Supply, UK |
| 25 mm Strobe |
| Part Number |
Description |
| NER-011301301 |
SCDI-25, R LED-D, 24V-S, 4.5M (15 ft.) Cbl w/Flying Leads |
| 50 mm Strobe |
| NER-011304002 |
SCDI-50 V2, R LED-D, 24V-S, 4.5M (15 ft.) Cbl w/Flying Leads |
| NER-011304012 |
SCDI-50 V2, W LED-D, 24V-S, 4.5M (15 ft.) Cbl w/Flying Leads |
| 75 mm Strobe |
| NER-011302001 |
SCDI-75, R LED-D, 24V-S, 4.5M (15 ft.) Cbl w/Flying Leads |
| Power Supply/Controllers |
| NER-011504100 |
| 98-000152-01 |
NL200 Lighting Controller (Front Panel Control Only) |
| 98-000152-02 |
NL220 Lighting Controller (Ethernet Control Only) |
| 98-000152-03 |
NL220F Lighting Controller (Ethernet Control Only with Fast Strobe Capability) |
| 030-028300 |
| 030-028400 |
| 030-028500 |
