使用 DataMan 8100 对手术灯生产的流程控制
Depending on the type of surgery, specific lighting conditions are required in order to achieve maximum visual acuity. Berchtold GmbH & Co. KG located in Tuttlingen, Germany, manufactures premium surgical lights and has high quality standards for production. To ensure this quality standard can be met for 100 percent of the lights manufactured, the company relies on processes for complete traceability of all production steps and product components. They accomplish this by reading Data Matrix codes for the main components using DataMan® 8100 industrial ID readers from Cognex.
The new generation of Berchtold LED lights are comprised of a total of 52 LED printed circuit boards (PCBs) with specially developed lens units. Each of the PCBs has its own individual Data Matrix code. Before being assembled, the code of each LED unit is read with a DataMan 8100. In the event of an error, this makes it possible to accurately determine the production batch of the PCBs used in each assembled light. Any potential shortcomings of third-party products used can therefore be precisely located and recalls initiated if necessary.
Every step is documented on a PC. Key components are identified before use by giving them each a Data Matrix code that is read with one of three DataMan 8100 units. The system only accepts the work as actually completed after the scan, and the subsequent step can only then be executed. "This is how we make sure that each item is actually assembled and how we know exactly which component is in each operating room light," says Peter Rönnberg. Throughout the service life of a light, the company can see when, where and how a product was made and with what parts. With duplicates codes on the light packaging, a traceable logistics process can also be ensured.
After the final calibration of the LED lights, the set values are added to the product’s data record. There is now detailed and complete documentation on the entire manufacturing process of each surgical light.
Berchtold chose the DataMan 8100 ID reader for its robustness, the high reliability of the read data and the wireless data transmission. The sturdy DataMan 8000 series readers offers the industry's most advanced technology for reading 1-D and 2-D codes—regardless of size, quality, printing method or surface. The Data Matrix codes on the LED PCBs, measuring just five by five millimeters, are easily read—even in the case of over soldering. In addition, the DataMan 8000 series readers from Cognex are the only portable industrial barcode readers with an industrial Ethernet port. Another crucial point for Rönnberg was the flexible way they can be used as both a mobile and a stationary ID reader. "We have some process steps where it is easier to put the PCB under a stationary scanner to read the code," explains the experienced process engineer, "so it’s good that we can convert the Cognex DataMan from a mobile handheld device into a fixed-position ID reader with just a simple holder.”
要解决的问题:全新一代 Berchtold LED 手术灯由 52 个 LED 印刷电路板 (PCB) 组成。为了记录组装流程,在组装前、组装期间和最终包装时都要读取每个 PCB 各自的数据矩阵代码。LED PCB 上的数据矩阵代码只有五乘五毫米,有时由于过度焊接很难对其进行解码。
解决方案:Berchtold 选择 DataMan 8100 ID 读码器,因为它坚固耐用,并且能够可靠地读取一些棘手的代码。它也是通过以太网将数据传输到网络的唯一途径。
优点:由于组装前会读取每个 LED 设备的代码,Berchtold 现在可准确确定每个组装灯中使用的 PCB 的生产批次。因此可精确确定任何潜在的缺陷,并在需要时进行召回。
公司名称: 康耐视中国
联 系 人: 市场部
电  话: 400-008-1133
传  真: 021-32091980
地  址: 上海浦东新区外高桥保税区泰谷路207号一楼D1座
邮  编: 200131
该厂商相关解决方案:
康耐视的Checker传感器确保瓶装检测的正确无误
全程质量跟踪确保西门子汽车业客户长期保持高满意度
康耐视的视觉系统保证更好的瓶装技术
TipTop冰淇淋的完美包装
Checker™ - 以100个工件/秒的速度实现完美无暇的标签检测
康耐视:复杂视觉应用的唯一解决方案
康耐视PatMax™- 适用于机器人应用环境的统一解决方案
康耐视视觉系统简化了激光焊接技术
康耐视实现外科植入物完全自动化检测
康耐视 In-Sight使汽车装配时间缩短了20%
对2000种不同的断路器实现百分之百的可靠检测
更多方案...
立即发送询问信息在线联系该解决方案厂商::
