In-Sight 5100 在 Rommel GmbH 为 PCB 上的激光代码提供光学控制
康耐视 In-Sight® 5100 视觉系统在 Rommel GmbH 的新激光标记系统中提供检测、检查和评估功能。这种视觉系统向 CO2 激光提供生产线上的位置数据,检查数据矩阵代码的质量,同时进行评估。作为组合的激光相机扫描头的一部分,In-Sight® 5100 缩短了周期时间,并确保结果准确。
Printed circuit boards (PCBs) are used today in nearly every electrically controlled system in the world. The form and functionality of the boards are just as varied as the fields in which they are used. In all cases, printed circuit boards contain small control components that can have a major impact on the performance of the finished product, so no errors or mix-ups may be allowed to occur in their manufacture. Rommel GmbH, based in of Ehingen, Germany, uses lasered Data Matrix codes to ensure that the boards are produced without errors.
The application of codes and inscriptions by laser is performed by ablation or by conversion of solder paints. This delicate process requires the utmost precision. The new laser marking system from Rommel GmbH uses an innovative laser scan head that features a moving deflection mirror. CO2 lasers and the In-Sight® 5100 vision system to reach its precision goals.
Compact process
The WL 700 LCS laser marking system from Rommel not only applies codes and inscriptions, it can also counter-check them in fractions of a second. The intelligent and compact In-Sight 5100 vision system fulfills three important functions: it measures the board, reads the codes and inscriptions, and evaluates their quality. Based on the compressed process, the performance and marking speed of the laser can be configured easily and accurately in order to achieve consistently high code quality. In this way, the inline system from Rommel processes PCBs of various sizes, materials, and thicknesses of solder paint quickly and reliably.
Integrated system
Speed plays a crucial role in the manufacturing process of PCBs. The entry and exit time and the marking and control time were permanently optimized in the WL 700 LCS. The growing demands for speed and accuracy have been met by simultaneous deflection of the laser beam onto the boards and the counter-checking of the code with the vision system integrated into the beam path. In addition, a newly developed transport system with middle-supported conveyor belts permits full-area inscription as far as the edge area of the PCB. The inscription area measures an impressive 400 x 400 mm.
Shortened cycle times
Shorter paths save time. Thus, the WL 700 LCS has no need for a conventional XY table. Instead of the moving product, a two-axis deflection system consisting of two swiveling mirrors ensures a large inspection and working field. Movable lenses focus the laser beam on the Z-axis. An F-Theta lens was not used so as to integrate the camera system downstream of the laser optics into the scanning head. The In-Sight 5100 is integrated via a half-silvered mirror. Rommel GmbH makes use of zinc selenite components in the lenses. These do not react to the laser at the high wavelength of the CO2 laser of about 10,000 nanometers - in contrast to conventional glass.
Increased reliability
For two-sided inscription of PCBs, the system is optionally equipped with a second laser camera system that simultaneously labels and checks the front and back sides. The combination of the laser and the intelligent vision system in one scan head pays dividends. The marking and control system from Rommel applies five Data Matrix codes with a size of 3 x 3 mm each from the top and bottom in just eight seconds including handling, fiducial measurement, and quality evaluation. In this way, the WL 700 LCS sets new standards.
Precise results
The developers from Rommel chose to deploy the In-Sight 5100 in their laser marking system design because this intelligent and complete system executes the required tasks perfectly. The captured images and data are easily handled using In-Sight Explorer software and the extensive library of proven vision tools. In addition, the robust diecast aluminum and stainless steel housing, which is also resistant to high vibration stress, and the inner workings of the intelligent vision system effectively protect against dust and debris. This is a strong argument when companies want to achieve sustainably precise production results in high volumes.
公司名称: 康耐视中国
联 系 人: 市场部
电  话: 400-008-1133
传  真: 021-32091980
地  址: 上海浦东新区外高桥保税区泰谷路207号一楼D1座
邮  编: 200131
该厂商相关解决方案:
康耐视的Checker传感器确保瓶装检测的正确无误
全程质量跟踪确保西门子汽车业客户长期保持高满意度
康耐视的视觉系统保证更好的瓶装技术
TipTop冰淇淋的完美包装
Checker™ - 以100个工件/秒的速度实现完美无暇的标签检测
康耐视:复杂视觉应用的唯一解决方案
康耐视PatMax™- 适用于机器人应用环境的统一解决方案
康耐视视觉系统简化了激光焊接技术
康耐视实现外科植入物完全自动化检测
康耐视 In-Sight使汽车装配时间缩短了20%
对2000种不同的断路器实现百分之百的可靠检测
更多方案...
立即发送询问信息在线联系该解决方案厂商::
