产品名称: H61H2-M4
型  号: H61H2-M4
工业主板H61H2-M4  (具体价格请与客服联系)
详细介绍
处理器
Supports new 2nd & 3rd gen Intel® Core™ family, Pentium, Celeron series processors in LGA1155 socket
芯片
 Intel® H61 Express Chipset
内存
º Dual-channel DDR3 Memory architecture
º Supports DDR3 1600/1333 non-ECC, Un-buffered SDRAM Memory
º 2 X 240-pin DDR3 DIMM socket
º Support up to 16 GB*
º * Due to the operation system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation
扩展槽
1 X PCI Express X16 Gen 3.0 slot(s)
1 X PCI Express X 1 Gen 2.0slot(s)
存储
Support by H61 Express Chipset
• 4 X Serial ATAII 3Gb/s
音频
6-Channel HD audio CODEC
网络
º Atheros AR8161 Gigabit Fast Ethernet Controller
º Wake-On-LAN
规格尺寸
MATX  190 mm(W) X 170mm(H)
后I/O面板
1 X PS/2 Keyboard & PS/2 mouse connectors
º 1 X Audio port (Line Out/Line In/Mic In)
º 1 X RJ-45 port
º 1 X D-Sub (VGA) port(s)
º 4 X USB2.0 port(s)
板载接口
º 1 X 24-pin ATX Power Supply connector
º 1 X 4-pin 12V Power connector
º 1 X 4-pin CPU_FAN connector
º 1 X 3-pin SYS_FAN connector
º 1 X Front panel audio header
º 2 X USB 2.0 header
    • Support additional 4 USB ports
º 4 X SATA II 3Gb/s connector(s)
º 1 X CLR_CMOS header
关 键 词: H61H2-M4 H61H2-M4 H61H2-M4
公司名称: 广州锡杨电子有限公司
联 系 人: 李保军
电  话: 020-22109677
手  机:
地  址: 广州市天河区天河北路900号高科大厦A539
邮  编: 510898
ECS H61H-G11(H61H-G11)
工业底板XY-6S4 (XY-6S4)
壁挂式防尘工控机箱XY-(XY-6051)
研祥壁挂式工业机箱 I( IPC-6805E)
低功耗主板NM70-IT(NM70-ITX)
研祥平板电脑PPC-15(PPC-1561V)
研祥小型紧凑型整机IPC(IPC-620)
工业平板电脑PPC-12(PPC-1201)
工控主板XYD2550D(XYD2550DC8)
研祥全新设计第3代4U1(IPC-820)
MINI-ITX嵌入式主(ECS C7VCM2-1.5G)
超薄主板、MINI-I(ECS H61H-G11)
低功耗、高性能嵌入式主板(ECS VX900-I)
工业级Mini-ITX主(ITX-IP5MI828)
Mini-ITX主板 工( ITX-IBXM6116)
凌动双核Mini-ITX(ITX-IC2M1026)
精英主板ECS TIGD(ECS TIGD-CI3)
嵌入式主板 VIA MM(VIA MMC 7000)
超薄嵌入式主板NM70((NM70(1037))
