IEEE1394.a 3CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
HV-F22F, HV-F31F
Æ·ÅÆ£ºÈÕÁ¢£¨HITACHI)
Ö÷ÒªÌØµã
IEEE1394.a ½Ó¿Ú
¸ßÇåÎú¶È
1/2ÐÍ / 145ÍòÏñËØ£¨HV-F31F: 1/3ÐÍ / 79ÍòÏñËØ£©Õý·½ÏñËØÖðÐÐɨÃèCCD(R.G.B.3CCD) ²¢ÇÒ²ÉÓø߾«¶ÈCCD¶¨Î»¼¼Êõ¡¢Êä³ö1360£¨H£©¡Á1024£¨V£©(SXGA)(HV-F31F: 1024(H)¡Á768(V)(XGA)µÄ¸ßÇåÎúͼÏñ¡£
¸ß¾«¶ÈµÄÊý×ÖͼÏñ´¦Àí
²ÉÓÃÈÕÁ¢µÄ´¦ÀíÆ÷¼¼Êõ£¨0.18¦Ìm´¦ÀíÆ÷¡¢ÄÚºËÇý¶¯µçѹ1.8V£©¡¢´¦ÀíÆ÷²¿·Ö²ÉÓõ¥Ð¾Æ¬
³¬¼¶´ò¹æÄ£¼¯³Éµç·£¨300ÍòÃÅ£©¡¢ÊµÏÖСÐÍ»¯¡¢µÍ¹¦ºÄ¡£²ÉÓÃ12±ÈÌØA/Dת»»¼°14±ÈÌØ
Êý×ÖÐźŴ¦ÀíÆ÷¡¢¿ÉÌáÉýS/N ºÍ¿í·ù¶¯Ì¬·¶Î§¡£
¸ßÉ«²Ê»¹ÔºÍÉ«²ÊÇåÎú¶È
²ÉÓÃ3CCD(R.G.B)ºÍÀ⾵ϵͳ¡¢ÊµÏÖ¸ßÉ«²Ê»¹ÔºÍ¸ßÉ«²ÊÇåÎú¶È¡£
6É«¶ÀÁ¢Ãɰæ
ºì¡¢À¶¡¢ÂÌ¡¢ÇàÉ«¡¢Æ·ºì¡¢»ÆÉ« 6 É«¶ÀÁ¢µ÷Õû¡£ÊÊÓÃÓÚͼÏñ¶ÁÈ¡¡¢ÏÔ΢¾µµÈ¶ÔÉ«²Ê»¹Ô
¶ÈÓкܸßÒªÇóµÄ³¡ºÏ¡£
Èñ»¯·ù¶È£¨DTL£©¿Éµ÷Õû
ÂÖÀªÈñ»¯Ðźŵķù¶È¿ÉÒÔµ÷Õû¡£µ±ÂÖÀªÈñ»¯ÐźÅÉèÖÃΪµÍʱ£¬Í¼ÏñÂÖÀª±íÏÖ¸ü×ÔÈ»£»µ±
ÂÖÀªÈñ»¯ÐźÅÉèÖÃΪ¸ßʱ£¬Í¼ÏñÂÖÀª±íÏÖ¸üÇåÎú¡£
×Ô¶¯ÒõӰУÕý£¨ASC£©£º¶Ô¾µÍ·ºÍ¹âÏß²úÉúµÄ²ÊÉ«ÒõÓ°¿É½øÐÐ×Ô¶¯Ð£Õý¡£
·á¸»µÄCCDÇý¶¯¹¦ÄÜ£ºÍâ´¥·¢¹¦ÄÜ¡¢³¤Ê±¼ä»ý·Öģʽ¡¢¾Ö²¿É¨Ãèģʽ¡¢×Ô¶¯µç×Ó¿ìÃÅ(AES)
·á¸»µÄÉãÏñ¹¦ÄÜ
4¸öÓ¦ÓÃÎļþ¡¢ÊµÊ±×Ô¶¯°×ƽºâ¡¢×Ô¶¯Í¼Ïñˮƽ¿ØÖÆ(ALC)¡¢½¹µãÊý¾ÝÊä³ö£¨´®ÐÐÊý¾Ý£©¡¢2ģʽÔöÒæ¿ØÖÆ£¨AGC¹¦ÄÜ¡¢1db/²½¿É±à³ÌÔöÒæ¿ØÖƹ¦ÄÜ£©¡¢¶Ô±Èµ÷Õû¹¦ÄÜ¡¢Ò«°ßУÕýµç·¡¢ÁÁ¶È£¨Ö÷ºÚ£©¡¢R/BºÚ¡¢R/BÔöÒæ¿Éµ÷Õû¡¢²ÊÌõÐźš¢ÕýƬ/·´Æ¬Çл»
ʹÓüòµ¥µÄͼÏñ½çÃæÈí¼þ£ºÏà»ú¹¦ÄÜ¿Éͨ¹ý¼òµ¥µÄͼÐνçÃæ½øÐÐÉèÖá£
¼¼Êõ²ÎÊý£º
Model |
HV-F31F |
HV-F22F |
Imaging device |
1/3-inch progressive scan interline CCD (R, G, B 3 CCD) |
1/2-inch progressive scan interline CCD (R, G, B 3 CCD) |
Total number of pixels |
1077(H) x 788(V) |
1392(H) x 1050(V) |
No. of effective pixels |
1024(H) x 768(V) |
1360(H) x 1024(V) |
Pixel size |
4.65 µm (H) x 4.65 µm (V) (Square pixel) |
Optical system |
1/3-inch F2.2 prism |
1/2-inch F1.6 prism |
Scanning area |
4.76 mm (H) x 3.53 mm (V) |
6.32 mm (H) x 4.76 mm (V) |
Scanning system |
Progressive |
Sync system |
Internal / external (HD/VD automatically switch) |
Lens mount |
C mount |
Video output |
Interface |
IEEE1394.a |
Cable |
IEEE1394.a 6 pin bus powered type |
Transfer rate |
400MHz |
Image format |
RGB 24/48 bit, YUV 16 bit |
Image size |
1024(H) x 768(V), 800(H) x 600(V) |
1360(H) x 1024(V), 1280(H) x 960(V), 640(H) x 480(V) |
Frame rate |
7.5 frames per second (RGB 24 bit, 1024 x 768) |
7.5 frames per second (RGB 24 bit, 1360 x 1024) |
Sensitivity |
2000 lx, F5.6 (at 1/30 second shutter) |
2000 lx, F8 (at 1/30 second shutter) |
Electric shutter speed |
Auto(AES) / Variable / Accumulate mode |
Variable |
1/30 to 1/100,000 second |
AES |
OFF to 1/100,000 second |
Accumulate |
1/30 to 4 second (1 frame step) |
External trigger shutter |
Mode |
Fixed shutter, One trigger |
Input |
12-pin connector (Hardware trigger) |
Input level |
Low: 0 V DC, High: 3 to 24 V DC |
White balance |
ATW / MANUAL/ One-push |
Gain |
AGC (0 to +12 dB) or 1dB step |
Gamma |
0.45 / 1.0 (ON / OFF) |
Color masking |
OFF/ON(6 color independent masking) |
Color bar |
Full |
Power supply |
DC+12 V (10. 5 V to 15 V DC without ripple) |
Power consumption |
Approx. 8.0 W (DC+12 V) |
Vibration endurance |
24.5 m/s2 or less (10 to 200 Hz, 30 minutes each on XYZ axes) (Do not subject to strong vibration for long periods of time.) |
External dimensions |
65(W) x 65(H) x 130(D) mm (not including lens and protrusions) |
Mass |
Approx. 600 g (without lens) |
