Model |
KP-FR
500PCL/SCL |
KP-FR
230PCL/SCL |
KP-FR
31PCL/SCL |
KP-FBR
30PCL/SCL |
Imaging device |
2/3-inch interline CCD |
1/1.8-inch interline CCD |
1/3-inch interline CCD |
Effective pixels |
2456 (H) x 2058 (V) |
1628 (H) x 1236 (V) |
659 (H) x 494 (V) |
Color filter |
RGB primary color mosaic filter |
Sensing area |
8.47 mm (H) x 7.10 mm (V) |
7.16 mm (H) x 5.44 mm (V) |
4.88 mm (H) x 3.66 mm (V) |
Scanning system |
Progressive |
Aspect ratio |
5£º4 |
4£º3 |
Frame rate |
16 frames per second (full pixel readout) |
30 frames per second (full pixel readout) |
120 frames per second (full pixel readout) |
60 frames per second (full pixel readout) |
Sync system |
Internal |
Lens mount |
C mount (Flange focal distance = 17.526 mm) |
Special mount |
Video output |
Digital output (CameraLink) |
Resolution |
Horizontal/Vertical: 2000TV lines |
Horizontal / Vertical: 1200 TV lines |
Horizontal: 500 TV lines / Vertical: 490 TV lines |
Sensitivity |
2000 lx, F8, 3200K |
2000 lx, F5.6, 3200 K |
2000 lx, F4, 3200 K |
Minimum illumination |
15 lx (F1.4 GAIN MAX) |
20 lx (F1.4, MAX GAIN) |
35 lx (F1.4, MAX GAIN) |
Signal noise to ratio |
48dB |
45 dB |
50 dB |
Gamma |
¦Ã = 1 |
Trigger input |
CameraLink (CC1) or DCIN/SYNC connector |
CameraLink (CC1) *When Reset control mode CC1 and CC2 are used |
Partial scan |
Selectable start position and height of picture grabbing in 1H step. |
Power supply voltage |
12 ¡À 1 VDC |
External dimensions |
44 (W) x 44 (H) x 41 (D) mm(Not including mount protrusions) |
29 (W) x 29 (W) x 38 (D) mm (Not including protrusions) |
Head: 12 (W) x 12.5 (H) x 47.5 (D) mm |
CCU: 29 (W) x 29 (H) x 38 (D) mm |
Mass |
Approx. 110 g |
Approx. 50 g |
Head: Approx. 18 g |
CCU: Approx. 50g (without cable) |
