Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Æô¿Æ£ºPoCL/Mini CL 1CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
²úÆ·Ãû³Æ£º Æô¿Æ£ºPoCL/Mini CL 1CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
ÐÍ ºÅ£º KP-FD500PCL/SCL,KP-FD202PCL/SCL,KP-FD140PCL/SCL
Æ· ÅÆ£º 11
Æ·ÅÆ£ºÈÕÁ¢£¨HITACHI)
Ö÷ÒªÌØµã
Mini CL £¨ÃÔÄãCameraLink£©
²ÉÓÃCameraLink½Ó¿Ú£¬¿ÉÒÔʵÏÖͼÏñÊý¾ÝµÄ¸ßËÙ´«Ê䡣ͬʱMiniCameraLink½Ó¿ÚµÄʹÓã¬Ê¹µÃÏà»úµÄÍâÐͱäµÃ¸ü¼ÓСÇÉ¡£
PoCL (¹©µçÐÍCameraLink)
²ÉÓù©µçÐÍCameraLink½Ó¿Ú£¬¿ÉʹµçÔ´¹©¸ø¡¢Í¼ÏñÊý¾Ý´«ËÍ¡¢Ïà»ú¿ØÖÆÍ¨¹ýÒ»Ìõ
CameraLinkÁ¬ÏßÓëͼÏñ²É¼¯¿¨ÏàÁ¬½Ó£¬Ê¹µÃ¹¹½¨Ó¦ÓÃϵͳ¸ü¼òµ¥¡£
¸ßÇåÎú¶È¡¢¸ßÖ¡Êý£º¸ßÇåÎú¶ÈÓë¸ßÖ¡ÊýͬʱʵÏÖ¡£
¿ÉÒԹ㷺ӦÓÃÓÚͬʱÐèÒª¸ßÇåÎú¶ÈºÍ¸ßÖ¡Êý´«ÊäµÄÁìÓò¡£
KP-FD500 PCL/SCL
505ÍòÏñËØ
      12
Ö¡/Ãë
KP-FD202 PCL/SCL
201ÍòÏñËØ
30
Ö¡/Ãë
KP-FD140 PCL/SCL
145ÍòÏñËØ
30
Ö¡/Ãë
Ö¡¿ìÃÅ£º¿ÉÌá¸ßÒÆ¶¯ÎïÌåµÄ´¹Ö±ÇåÎú¶È¡£
¶à¼¶¿ìÃÅ£º·²¾ßÓж༶¿É±ä¿ìÃÅ¡££¨×îС1/100,000Ã룩
Ö¡ÇëÇó£ºÍ¼Ïñ¿ªÊ¼Ê±¼äºÍÆØ¹âʱ¼ä¿ÉÓÉ´¥·¢ÐźÅÈÎÒâ¿ØÖÆ¡£
Ô¶³Ì¿ØÖÆ£ºÍ¨¹ýCameraLink½Ó¿Ú£¬¿ÉÔ¶³Ì¿ØÖÆ¿ìÃÅ¡¢Ä£Ê½¡¢ÔöÒæ¡¢¾Ö²¿É¨Ãè¡¢±ÈÌØÎ»ÊýµÈ
¹¦ÄÜ¡£
¾Ö²¿É¨Ã裺 ¾ßÓпªÊ¼ÏߺÍÏß·ù¿ÉÈÎÒâÑ¡ÔñµÄ¾Ö²¿É¨Ã蹦ÄÜ£¬¿ÉÒÔʵÏÖ¸ßÖ¡ÊýͼÏñÊä³ö¡£
±ÈÌØÎ»Êý¿ÉÑ¡Ôñ£º36/30/24±ÈÌØ¿ÉÑ¡Ôñ¡£
¸ßÉ«²Ê»¹Ô­£º²ÉÓÃRGBÔ­É«ÂíÈü¿ËÂ˲¨Æ¬ºÍ14±ÈÌØDSP,±£Ö¤ÁË¸ßÆ·ÖʵÄÉ«²Ê»¹Ô­¡£
¶àÑùµÄ°×ƽºâµ÷Õû£º¾ßÓжàÖְׯ½ºâµ÷Õûģʽ£ºATW(×Ô¶¯°×ƽºâ)£¬Manual(RºÍGÔöÒæÊÖ
¶¯µ÷Õû)£¬One-push¡£
6É«¶ÀÁ¢Ãɰ棺ºì£¬ÂÌ£¬À¶£¬ÇàÉ«£¬Éîºì£¬»ÆÉ«6É«¶ÀÁ¢µ÷Õû£¬ÖÒʵµÄ»¹Ô­×î¼ÑÉ«²Ê¡£
¼¼Êõ²ÎÊý£º
Model
KP-FD500PCL/SCL
KP-FD202PCL/SCL
KP-FD140PCL/SCL
Imaging device
2/3-inch progressive scan interline CCD
1/1.8-inch progressive scan interline CCD
1/2-inch progressive scan interline CCD
Effective pixels
2456(H) x 2058(V)
1628(H) x 1236(V)
1392 (H) x 1040 (V)
Color filter
RGB primary color mosaic filter
Scanning system
Progressive
Aspect ratio
  5£º4
  4£º3
Frame rate
12 frames per second (full pixel readout)
30 frames per second (full pixel readout)
Scanning frequency
Horizontal: 24.922 kHz    Vertical: 11.99 Hz
Horizontal: 37.5 kHz    Vertical: 29.95 Hz
Horizontal: 32.179 kHz    Vertical: 30.13 Hz
Sync system
Internal
Lens mount
C mount (Flange focal distance = 17.526 mm
Video output Interface
CameraLink 64.0000 MHz
CameraLink 72.0000 MHz
CameraLink 57.6000 MHz
Sensitivity
2000 lx, F11, 3200 K
2000 lx, F5.6, 3200 K
Minimum illumination
5 lx (F1.4, MAX GAIN)
10 lx (F1.4, MAX GAIN)
Signal noise to ratio
48 dB
Frame on demand
 Mode: (A) Fixed shutter mode (8 steps or variable)     (B) ONE trigger mode     (C) VD reset mode         Trigger input: CameraLink (CC1) or DCIN/SYNC connector
Partial scan
Selectable start position and height of picture grabbing in 1H step.
Gain
Auto/Manual (0 to +12dB) (Approx. 0.0358dB step)
Auto/Manual (0 to +18dB) (Approx. 0.0358dB step)
White balance
ATW / MANUAL / One-push
Gamma
OFF (¦Ã=1) / LUT
Color masking
OFF / ON (6 vector independent masking)
Power supply voltage
12 ¡À 1 VDC
External dimensions
44 (W) x 44 (H) x 41 (D) mm (not including mount protrusions)
Mass
Approx. 110 g
¹«Ë¾Ãû³Æ£º Æô¿Æ(ÉϺ££©×Ô¶¯»¯ÏµÍ³ÓÐÏÞ¹«Ë¾
µç »°£º 021 51978078 / ÕŰ²ç÷
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÆÖ¶«ÐÂÇø½ð¸Û·333ºÅÓíÖݽðÇŹú¼Ê´óÏÃÒ»×ù802ÊÒ
ÓÊ ±à£º 201206
Ö÷ Ò³£º http://www.checksystem.cn
  • DALSA¹¤ÒµÏà»ú£¬DALSAÃæÕóÏà»ú£¬DalsaÏßÕóÏà»ú
  • Æô¿Æ£ºÆ¿¸Ç¼ì²â»ú
  • ¿ÕÆ¿¼ìÆ¿»ú
  • Æô¿Æ£ºIEEE1394.bºÚ°×ÖðÐÐɨÃèÏà»ú
  • Camera Link¹¤ÒµÊý×ÖÏà»ú
  • Æô¿Æ£ºPoCL/Mini CL RawÊý¾ÝÊä³öÖðÐÐɨÃèÏà»úI
  • Æô¿Æ£º°²ê³¼ì²â»ú
  • Æô¿Æ£ºPoCL/Mini CL 1CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
  • Æô¿Æ£º3CCD¹¤ÒµÏà»ú
  • Æô¿Æ£ºÆ¿Åß¼ì²â»ú
