Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Æô¿Æ£ºPoCL/Mini CL ºÚ°×ÖðÐÐɨÃèÏà»úI
²úÆ·Ãû³Æ£º Æô¿Æ£ºPoCL/Mini CL ºÚ°×ÖðÐÐɨÃèÏà»úI
ÐÍ ºÅ£º KP-F500PCL/SCL, KP-F230PCL/SCL, KP-F31PCL/SCL, KP-FB30PCL/SCL
Æ· ÅÆ£º 11
Æ·ÅÆ£ºÈÕÁ¢£¨HITACHI)
Ö÷ÒªÌØµã
Mini CL £¨ÃÔÄãCameraLink£©
²ÉÓÃCameraLink½Ó¿Ú£¬¿ÉÒÔʵÏÖͼÏñÊý¾ÝµÄ¸ßËÙ´«Ê䡣ͬʱMiniCameraLink½Ó¿ÚµÄʹÓã¬Ê¹µÃÏà»úµÄÍâÐͱäµÃ¸ü¼ÓСÇÉ¡£
PoCL (¹©µçÐÍCameraLink)
²ÉÓù©µçÐÍCameraLink½Ó¿Ú£¬¿ÉʹµçÔ´¹©¸ø¡¢Í¼ÏñÊý¾Ý´«ËÍ¡¢Ïà»ú¿ØÖÆÍ¨¹ýÒ»ÌõCameraLinkÁ¬ÏßÓëͼÏñ²É¼¯¿¨ÏàÁ¬½Ó£¬Ê¹µÃ¹¹½¨Ó¦ÓÃϵͳ¸ü¼òµ¥¡£
¸ßÇåÎú¶È¡¢¸ßÖ¡Êý£º¸ßÇåÎú¶ÈÓë¸ßÖ¡ÊýͬʱʵÏÖ¡£
¿ÉÒԹ㷺ӦÓÃÓÚͬʱÐèÒª¸ßÇåÎú¶ÈºÍ¸ßÖ¡Êý´«ÊäµÄÁìÓò¡£
KP-F500PCL/SCL
5.05 Megapixel
16
frame/second
KP-F230PCL/SCL
2.01 Megapixel
30
frame/second
KP-F200PCL/SCL
2.01 Megapixel
15
frame/second
KP-F80PCL/SCL
0.81 Megapixel
36
frame/second
KP-F31PCL/SCL
0.33 Megapixel
120
frame/second
KP-F39PCL/SCL
0.33 Megapixel
91
frame/second
KP-F30PCL/SCL
0.33 Megapixel
60
frame/second
KP-FB30PCL/SCL
0.33 Megapixel
60
frame/second
¼¼Êõ²ÎÊý£º
Ö÷ÒªÌØµã
KP-F500PCL/SCL
5.05 Megapixel
16
frame/second
KP-F230PCL/SCL
2.01 Megapixel
30
frame/second
KP-F200PCL/SCL
2.01 Megapixel
15
frame/second
KP-F80PCL/SCL
0.81 Megapixel
36
frame/second
KP-F31PCL/SCL
0.33 Megapixel
120
frame/second
KP-F39PCL/SCL
0.33 Megapixel
91
frame/second
KP-F30PCL/SCL
0.33 Megapixel
60
frame/second
KP-FB30PCL/SCL
0.33 Megapixel
60
frame/second
¼¼Êõ²ÎÊý£º
Model
KP-F500PCL
/SCL
KP-F230PCL
/SCL
KP-F31PCL
/SCL
KP-FB30PCL
/SCL
Imaging device
2/3-inch interline CCD
1/1.8-inch interline CCD
1/3-inch interline CCD
Total pixels
2536 (H) x 2068 (V)
1688 (H) x 1248 (V)
692 (H) x 504 (V)
Effective pixels
2456 (H) x 2058 (V)
1628 (H) x 1236 (V)
659 (H) x 494 (V)
Pixel size
3.45 µm (H) x 3.45 µm (V) (square lattice)
4.4 µm (H) x 4.4 µm (V) (square lattice)
7.4 µm (H) x 7.4 µm (V) (square lattice)
Sensing area
8.47 mm (H) x 7.10 mm (V)
7.16 mm (H) x 5.44 mm (V)
4.88 mm (H) x 3.66 mm (V)
Scanning system
Progressive
Aspect ratio
 5:4
 4:3
Frame rate
16 frames per second (full pixel readout)
30 frames per second (full pixel readout)
120 frames per second (full pixel readout)
60 frames per second (full pixel readout)
54 frames per second (vertical 2 pixel addition)
219 frames per second (vertical 2 pixel addition)
Sync system
Internal
Lens mount
C mount (Flange focal distance = 17.526 mm)
Special mount (Flange focal distance = 8.4 mm)
Resolution
Horizontal/Vertical: 2000TV lines
Horizontal / Vertical: 1200 TV lines
Horizontal: 500 TV lines / Vertical: 490 TV lines
Sensitivity
400 lx, F5.6, 3200 K
500 lx, F5.6, 3200 K
550 lx, F4, 3200 K
750 lx, F5.6, 3200 K
Minimum illumination
1.0 lx (F1.4, MAX GAIN, without IR cut filter)
3.9 lx (F1.4, MAX GAIN)
8.6 lx (F1.4, MAX GAIN)
5.9 lx, F1.4, MAX GAIN
Signal noise to ratio
48dB
45dB
50 dB
Gamma
¦Ã = 1
Trigger input
CameraLink (CC1) or DCIN/SYNC connector
CameraLink (CC1)  *When Reset control mode CC1 and CC2 are used
Partial scan
Selectable start position and height of picture grabbing in 1H step.
Power supply voltage
12 ¡À 1 VDC
External dimensions
44 (W) x 44 (H) x 41 (D) mm (Not including protrusions)
29 (W) x 29 (W) x 38 (D) mm (Not including protrusions)
Head: 12 (W) x 12.5 (H) x 47.5 (D) mm
CCU: 29 (W) x 29 (H) x 38 (D) mm
Mass
Approx. 110 g
Approx. 50 g
Head: Approx. 18 g
CCU: Approx. 50g (without cable
¹«Ë¾Ãû³Æ£º Æô¿Æ(ÉϺ££©×Ô¶¯»¯ÏµÍ³ÓÐÏÞ¹«Ë¾
µç »°£º 021 51978078 / ÕŰ²ç÷
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÆÖ¶«ÐÂÇø½ð¸Û·333ºÅÓíÖݽðÇŹú¼Ê´óÏÃÒ»×ù802ÊÒ
ÓÊ ±à£º 201206
Ö÷ Ò³£º http://www.checksystem.cn
  • DALSA¹¤ÒµÏà»ú£¬DALSAÃæÕóÏà»ú£¬DalsaÏßÕóÏà»ú
  • Æô¿Æ£ºÆ¿¸Ç¼ì²â»ú
  • ¿ÕÆ¿¼ìÆ¿»ú
  • Æô¿Æ£ºIEEE1394.bºÚ°×ÖðÐÐɨÃèÏà»ú
  • Camera Link¹¤ÒµÊý×ÖÏà»ú
  • Æô¿Æ£ºPoCL/Mini CL RawÊý¾ÝÊä³öÖðÐÐɨÃèÏà»úI
  • Æô¿Æ£º°²ê³¼ì²â»ú
  • Æô¿Æ£ºPoCL/Mini CL 1CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
  • Æô¿Æ£º3CCD¹¤ÒµÏà»ú
  • Æô¿Æ£ºÆ¿Åß¼ì²â»ú
