Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú Æô¿Æ£º¹¤ÒµÏà»ú
²úÆ·Ãû³Æ£º Æô¿Æ£º¹¤ÒµÏà»ú
ÐÍ ºÅ£º KP-F200PCL/SCL,KP-F80PCL/SCL,KP-F39PCL/SCL,KP-F30PCL/SCL
PoCL/Mini CLºÚ°×ÖðÐÐɨÃèÏà»úII
Æ·ÅÆ£ºÈÕÁ¢£¨HITACHI)
Ö÷ÒªÌØµã
Ö¡¿ìÃÅ£º¿ÉÌáÉýÒÆ¶¯ÎïÌå´¹Ö±·½ÏòÉϵÄÇåÎú¶È¡£
¶à¼¶¿ìÃÅ£ºÏà»ú¾ßÓж༶µç×Ó¿ìÃÅ»ò¿É±ä¿ìÃŹ¦ÄÜ¡£(×îС1/100,000Ãë)
Ö¡ÇëÇ󣺾ßÓÐÖ¡ÇëÇó¹¦ÄÜ£¬Í¼Ïñ¶Áȡʱ¼äºÍÆØ¹âʱ¼ä¿ÉÈÎÒâ¿ØÖÆ¡£
Ô¶³Ì¿ØÖÆ£ºÍ¨¹ýCameraLink½Ó¿Ú£¬¿ÉÔ¶³Ì¿ØÖÆ¿ìÃÅ¡¢Ä£Ê½¡¢ÔöÒæ¡¢¾Ö²¿É¨Ãè±ÈÌØÎ»µÈ ¸÷ÖÖ¹¦ÄÜ¡£
¾Ö²¿É¨Ã裺¾Ö²¿É¨Ã蹦ÄÜ¿ÉÈ¡µÃ´Ó¿ªÊ¼Ïßµ½Ö¸¶¨·ù¶È¼äµÄÈÎÒâ»­Ãæ¡£
¿ÉʵÏÖ»­ÃæµÄ¸ßÖ¡Êý´«Êä¡£
¿ÉÑ¡±ÈÌØÎ»£º
12-/10-/8-bit
KP-F500PCL/SCL
10-/8-bit
KP-F230PCL/SCL,KP-F200PCL/SCL,KP-F80PCL/SCL,KP-F31PCL/SCL,
KP-F39PCL.SCL,KP-F30PCL/SCL,KP-FB30PCL/SCL
±³ÃæÍ¼£º
           KP-FxxxPCL                                         KP-FxxxSCL
¼¼Êõ²ÎÊý£º
Model
KP-
F200PCL/SCL
KP-
F80PCL/SCL
KP-
F39PCL/SCL
KP-
F30PCL/SCL
Imaging device
1/1.8-inch interline CCD
1/3-inch interline CCD
Effective pixels
1628 (H) x 1236 (V)
1034 (H) x 779 (V)
659 (H) x 494 (V)
Sensing area
7.16 mm (H) x 5.44 mm (V)
4.76 mm (H) x 3.57 mm (V)
4.88 mm (H) x 3.66 mm (V)
Scanning system
Progressive
Aspect ratio
 4£º3
Frame rate
15 frames per second (full pixel readout)
36 frames per second (full pixel readout)
91 frames per second (full pixel readout)
60 frames per second (full pixel readout)
Sync system
Internal
Lens mount
C mount (Flange focal distance =17.526 mm)
Resolution
Horizontal / Vertical: 1200 TV lines
Horizontal / Vertical: Approx. 800 TV lines
Horizontal: 500 TV lines / Vertical: 490 TV lines
Sensitivity
400 lx, F4, 3200 K
400 lx, F2.8, 3200 K
400 lx, F4, 3200 K
Minimum illumination
1.0 lx (F1.4, MAX GAIN, without IR cut filter)
2.0 lx (F1.4, MAX GAIN, without IR cut filter)
Signal noise to ratio
50 dB
Gamma
¦Ã = 1
Trigger input
CameraLink (CC1)  *When Reset control mode CC1 and CC2 are used
Power supply voltage
12 ¡À 1 VDC
External dimensions
29 (W) x 29 (W) x 29 (D) mm (Not including protrusions)
Mass
Approx. 50 g
¹«Ë¾Ãû³Æ£º Æô¿Æ(ÉϺ££©×Ô¶¯»¯ÏµÍ³ÓÐÏÞ¹«Ë¾
µç »°£º 021 51978078 / ÕŰ²ç÷
ÊÖ»ú£º
µØ Ö·£º ÉϺ£ÊÐÆÖ¶«ÐÂÇø½ð¸Û·333ºÅÓíÖݽðÇŹú¼Ê´óÏÃÒ»×ù802ÊÒ
ÓÊ ±à£º 201206
Ö÷ Ò³£º http://www.checksystem.cn
  • DALSA¹¤ÒµÏà»ú£¬DALSAÃæÕóÏà»ú£¬DalsaÏßÕóÏà»ú
  • Æô¿Æ£ºÆ¿¸Ç¼ì²â»ú
  • ¿ÕÆ¿¼ìÆ¿»ú
  • Æô¿Æ£ºIEEE1394.bºÚ°×ÖðÐÐɨÃèÏà»ú
  • Camera Link¹¤ÒµÊý×ÖÏà»ú
  • Æô¿Æ£ºPoCL/Mini CL RawÊý¾ÝÊä³öÖðÐÐɨÃèÏà»úI
  • Æô¿Æ£º°²ê³¼ì²â»ú
  • Æô¿Æ£ºPoCL/Mini CL 1CCD²ÊÉ«ÖðÐÐɨÃèÏà»ú
  • Æô¿Æ£º3CCD¹¤ÒµÏà»ú
  • Æô¿Æ£ºÆ¿Åß¼ì²â»ú
