PoCL/Mini CL RawÊý¾ÝÊä³ö ÖðÐÐɨÃèÏà»úII
KP-FR200PCL/SCL, KP-FR80PCL/SCL, KP-FR39PCL/SCL, KP-FR30PCL/SCL
Æ·ÅÆ£ºÈÕÁ¢ (HITACHI)
Ö÷ÒªÌØµã
RAWÊý¾ÝÊä³ö
RGBͼÏñÓÉRGBÔÉ«ÂíÈü¿ËÂË¹âÆ¬µÄ¸÷¸ö¸Ð¹âÇøµÄÔʼÊý¾ÝÖ±½Óת»»Êä³öµÃµ½¡£Ê¹µÃ¼ÆËã
»úÈ¡µÃµÄͼÏñÖÊÁ¿Ëðʧ×îÉÙ¡£
¡ï RAWÊý¾Ýת»»Îª²ÊɫͼÏñÐèÒªÓÐרÃÅÈí¼þÀ´Íê³É¡£
Ö¡¿ìÃÅ£º¿ÉÌá¸ßÒÆ¶¯ÎïÌåµÄ´¹Ö±ÇåÎú¶È¡£
¶à¼¶¿ìÃÅ£º·²¾ßÓж༶¿É±ä¿ìÃÅ¡££¨×îС1/100,000Ã룩
Ö¡ÇëÇó£ºÍ¼Ïñ¿ªÊ¼Ê±¼äºÍÆØ¹âʱ¼ä¿ÉÓÉ´¥·¢ÐźÅÈÎÒâ¿ØÖÆ¡£
Ô¶³Ì¿ØÖÆ£ºÍ¨¹ýCameraLink½Ó¿Ú£¬¿ìÃÅ¡¢Ä£Ê½¡¢ÔöÒæ¾Ö²¿É¨Ãè¡¢±ÈÌØÎ»µÈ¡£
¶àÖÖÏà»úµÄ¿ØÖƺ͵÷Õû¶¼¿ÉÒÔʵÏÖ¡£
¾Ö²¿É¨Ã裺 ¾Ö²¿É¨Ã蹦ÄÜ¿ÉÈ¡µÃ´Ó¿ªÊ¼Ïßµ½Ö¸¶¨·ù¶È¼äµÄÈÎÒâ»Ãæ¡£
¿ÉʵÏÖ»ÃæµÄ¸ßÖ¡Êý´«Êä¡£
±ÈÌØÎ»Êý¿ÉÑ¡£º
12-/10-/8-bit |
KP-FR500PCL/SCL |
10-/8-bit |
KP-FR230PCL/SCL,KP-FR200PCL/SCL,KP-FR80PCL/SCL,KP-FR31PCL/SCL,
KP-FR39PCL.SCL,KP-FR30PCL/SCL,KP-FBR30PCL/SCL |
KP-FRxxxPCL KP-FRxxxSCL
¼¼Êõ²ÎÊý£º
Model |
KP-FR200PCL
/SCL |
KP-FR80PCL
/SCL |
KP-FR39PCL
/SCL |
KP-FR30PCL
/SCL |
Imaging device |
1/1.8-inch interline CCD |
1/3-inch interline CCD |
Effective pixels |
1628 (H) x 1236 (V) |
1034 (H) x 779 (V) |
659 (H) x 494 (V) |
Color filter |
RGB primary color mosaic filter |
Sensing area |
7.16 mm (H) x 5.44 mm (V) |
4.76 mm (H) x 3.57 mm (V) |
4.88 mm (H) x 3.66 mm (V) |
Scanning system |
Progressive |
Aspect ratio |
4:3 |
Frame rate |
15 frames per second (full pixel readout) |
36 frames per second (full pixel readout) |
91 frames per second (full pixel readout) |
60 frames per second (full pixel readout) |
Scanning frequency |
Horizontal: 18.75 kHz, Vertical: 14.97 Hz |
Horizontal: 28.346 kHz, Vertical: 35.79 Hz |
Horizontal: 46.875 kHz, Vertical: 91.73 Hz |
Horizontal: 31.468 kHz, Vertical: 59.94 Hz |
Sync system |
Internal |
Lens mount |
C mount (Flange focal distance =17.526 mm) |
Video output |
Digital output (CameraLink) |
Resolution |
Horizontal / Vertical: 1200 TV lines |
Horizontal / Vertical: Approx. 800 TV lines |
Horizontal: 500 TV lines / Vertical: 490 TV lines |
Sensitivity |
2000 lx, F8, 3200 K |
2000 lx, F4, 3200 K |
2000 lx, F5.6, 3200 K |
Minimum illumination |
5.0 lx (F1.4, MAX GAIN) |
20 lx (F1.4, MAX GAIN) |
10 lx (F1.4, MAX GAIN) |
Signal noise to ratio |
50 dB |
Gamma |
¦Ã = 1 |
Trigger input |
CameraLink (CC1) *When Reset control mode CC1 and CC2 are used |
Partial scan |
Selectable start position and height of picture grabbing in 1H step. |
Power supply voltage |
12 ¡À 1 VDC |
External dimensions |
29 (W) x 29 (W) x 29 (D) mm (Not including protrusions) |
Mass |
Approx. 50 g |
