Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú LPCI-3488A
²úÆ·Ãû³Æ£º LPCI-3488A
ÐÍ ºÅ£º LPCI-3488A
Features
  • Supports a 32-bit 3.3V or 5V PCI bus
  • Low-profile PCI MD1 form factor
  • Fully compatible with IEEE 488 standard
  • Up to 1.5MB/s data transfer rates
  • Built-in 2 KB FIFO for read/write operations
  • Provides APIs compatible with NI-488.2* driver software
  • Supports industrial-standard VISA library
  • Interactive utility for testing and diagnostics
Introduction
ADLINK LPCI-3488A GPIB controller interface card, fully compatible with the IEEE 488 instrumentation control and communication standard, is capable of controlling up to 14 stand-alone instruments via IEEE 488 cables. It is designed to meet the requirements for high performance and maximum programming portability. The built-in 2KB FIFO and a block transfer mode provide up to 1.5 MB/s GPIB transfer rate. With the APIs that are compatible with NI-488.2* and VISA support, the LPCI-3488A provides the greatest compatibility with your existing applications and instrument drivers. (* NI-488.2 mentioned herein is the trademarks and properties of National Instruments Corporation.)
Ordering Information
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
