²úÆ·Ãû³Æ£º PCI-9524
ÐÍ ºÅ£º PCI-9524
Æ· ÅÆ£º ADLINK
Features
  • 4-CH strain gauged-based transducer inputs
  • Up to 30kS/s sampling rate
  • Transducer input accuracy up to 1/200,000 counts at full-scale
  • 4-CH 24-bit general-purpose analog input
  • 3-CH PWM output, supporting single pulse and pulse train
  • 3-CH encoder inputs, supporting CW/CCW & AB phase
  • 2-CH 16-bit analog outputs
  • Auto-calibration feature
Introduction
The PCI-9524 is a robust, multi-purpose module designed for turnkey material test systems (MTS). Equipped with four strain gauge-based transducer input channels, four general purpose analog input channels, and a 3-axis motion controller, the PCI-9524 delivers a complete hardware solution for MTS manufacturers. The PCI-9524 easily integrates physical quantity measurement and implements strategy of close-loop control in a single module package. For transducer measurement, the PCI-9524 supports sensitivity from 1.0 mV/V to 4.0 mV/V and provides a 1/200000 accuracy of measurement of full scale. These features make the PCI-9524 suitable for precise measurement in large-scale transducers.
Ordering Information
¹«Ë¾Ãû³Æ£º Á軪¿Æ¼¼£¨Öйú£©ÓÐÏÞ¹«Ë¾
µç »°£º 010 58858666ת8830 / ÕŸ£Ç¿
ÊÖ»ú£º
µØ Ö·£º ±±¾©º£µíÇøÉϵض«Â·1ºÅÓ¯´´¶¯Á¦´óÏÃE×ù°Ë²ãÎ÷
ÓÊ ±à£º 100085
Ö÷ Ò³£º http://www.adlinktech.com
  • PXIS-2719
  • PXIS-2558T
  • PXI-3910
  • PXI-3920
  • PXI-3950
  • PCIe-RTV24
  • PCI-8144
  • PCI-8102
  • PCI-8124
  • PCI-8134
