| Introduction
The ADLINK PCI-6202 is a 4-CH, 16-bit high resolution voltage output card with hardware timed waveform generation. Four analog output channels can simultaneously and support up to 1 MS/s rate per channel. PCI-6202 features excellent linearity (DNL < 1 LSB), which is suitable for dynamic signal simulation and control applications requiring high accuracy through voltage output. Furthermore, PCI-6202 provides additional I/O control lines for system integration, such as 16-CH isolated digital input and 16-CH isolated output, 8-CH TTL DI and 8-CH TTL DO, 3-CH encoder inputs, and 4-CH PWM outputs. Combined, these I/O functionalities, solid voltage output linearity, and high accuracy, make PCI-6202 the best single-board solution for both equipment manufacturers and laboratory research applications. |
