YTNϵÁÐÄÍÕðѹÁ¦±í
YTN Series Shock Proof Pressure Meter
¼ò½é
ÄÍÕðѹÁ¦±íÄÚ²¿³ä¹à×èÄáÒººÍÅäÌ×»º³å×°Ö㬾ßÓÐÁ¼ºÃµÄÄÍÕðÐÔÄÜ£¬ÊÊÓÃÓÚ±»²â½éÖʵÄѹÁ¦ÓÐÇ¿ÁÒÂö³å±ä»¯»òѹÁ¦³å»÷ºÍÔÚÉú²ú¹¤ÒÕÖо³£Í»È»Ð¶ºÉµÄ³¡ºÏ£¬ÒÔ¼°»·¾³Õ𶯽ϴóµÄ³¡Ëù¡£ÒDZíÄÜ²âÆøÌå¡¢ÒºÌåÂö¶¯Ñ¹Á¦µÄƽ¾ùÖµ£¬ÒÔ¿Ë·þ½éÖÊÇ¿ÁÒÂö³å¼°»·¾³Õ𶯶ÔÒÇ±í´øÀ´µÄË𺦣¬È·±£¶ÁÊýµÄ׼ȷÐÔ¡£
Brief introduction:
Shock proof pressure meter is filled with damping liquid inside and assembled with buffering device, owning good performance of shock proof. This sort of meters is suitable for locations where the pressure of medium changes intensely and pressure shock exists, or pressure is released suddenly in the course of manufacturing, or working environment shock largely. The meter can measure fluctuating pressure average of gas and liquid mediums. Thus damage to meter induced by intensive fluctuation and environmental shock can be overcome smoothly and accuracy of reading is ensured.
¹¹³ÉʾÒâͼ Internal structure
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º1.6¼¶¡¢2.5¼¶
- ʹÓû·¾³Î¶ȣº5¡æ~55¡æ ±í¿ÇÄÚ³ä¸ÊÓÍ
-25¡æ~55¡æ ±í¿ÇÄÚ³ä¹èÓÍ
- Ìî³ä¹¤×÷Òº£ºa£º¸ÊÓÍ£»b£º¹èÓÍ£»c£º¸ù¾ÝÓû§ÐèÇóÌî³ä
- Íâ¿Ç·À»¤µÈ¼¶£ºIP65
- ¿¹¹¤×÷»·¾³Õñ¶¯£ºV.H.4
Principal technical parameters
- Accuracy: 1.6, 2.5 grades
- Temperature of applicable environment: 5¡æ~55¡æ with glycerin filled inside the crust-25¡æ~55¡æ with silicon petrol filled inside the crust
- Filled operating liquid: a£ºglycerol; b£ºsilicon petrol; c£ºFilled into
- according to users requirement
- Defend grade of crust: Ip65
- Resistant operational environmental vibration: V.H.4
ÐͺŹæ¸ñ Types and specifications
ÐÍ ºÅ
Model |
¾«È·¶È
Accuracy |
YTN-60 |
2.5 |
M14¡Á1.5
1/4NPT;G1/4; |
0~0.16;0~0.25;0~0.4;0~0.6;0~1;0~1.6;
0~2.5;0~4;0~6;0~10;0~16;0~25;0¡«40;0¡«60 |
YTN-60Z¡¢ZT |
YTN-100 |
1.6 |
M20¡Á1.5
G1/2£»1/2NPT |
0~0.1;0~0.16;~0~0.25;0~0.4;0~0.6;0~1;
0~1.6;0~2.5;0~4;0~6;0~10;0~16;0~25;
0~40;0~60 |
YTN-100Z¡¢ZT |
YTN-150 |
YTN-150Z¡¢ZT |
YZTN-100¡¢100ZT |
1.6 |
M20¡Á1.5
G1/2£»1/2NPT |
0~40;0~60 |
TZTN-150¡¢150ZT |
×¢£º½Ó¿Ú³ß´ç¿É°´Óû§ÒªÇóÖÆ×÷¡£ Joint dimension can be customized
ÍâÐγߴç External dimension
µ±Èó»¬Ö¬¸ÊÓÍ»ò¹èÓÍÓëÂÈ¡¢µªËá¡¢Ñõ»¯ÂȵÈÇ¿Ñõ»¯¼Á»ìºÏʱ£¬»á×Ô·¢µÄ·¢Éú»¯Ñ§·´Ó¦£¬ÓÐȼÉÕ»ò±¬Õ¨Ôì³ÉÉ豸Ë𻵡¢ÈËÔ±ÉËÍöµÄ¿ÉÄÜ¡£µ±Ñ¹Á¦±íÓÃÓÚÕâЩ³¡ºÏʱ¾ù²»ÄܳäÈó»¬Ö¬¸ÊÓÍ»ò¹èÓÍ£¬ÇëÓë³§¼ÒÁªÏµ£¬³äÌîÕýÈ·µÄÄÚ³äÓÍ¡£
³äÌî¸ÊÓ͵ÄÄÍÕð±í²»ÄÜÔÚµÍÎÂÌõ¼þÏ»òµØÇøÊ¹Óá£
- 0.1MPaÁ¿³Ì·¶Î§ÄÚµÄÕæ¿ÕѹÁ¦±í£¬¾«È·¶ÈÓ¦µÍÓÚ1%(1.6»ò2.5)¡£
Remark
When lubricating grease glycerin or silicon oil mixed with strong oxidant, such as chlorine, nitrogen acid, and chlorine oxide, chemical reaction occurs spontaneously. In the course of reaction, combustion or explosion may cause equipment damaged or personnel injured. When pressure meters are used in such circumstances, lubricating grease glycerin or silica gel oil cannot be filled inside. Please contact with manufacturer for proper in-filled oil.
Shockproof pressure meter filled with glycerin inside cannot be used in low temperature condition or area.
If measure range of vacuum pressure meter is within -0.1MPa, the meters precision shall be lower than 1%
¶©»õÐëÖª:
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶ÈµÈ¼¶¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇ󣬶©»õʱÇë×¢Ã÷¼¼ÊõÒªÇó¡£
ÎÞÎýÊÐÒËÐËË«»ªÒDZíÓÐÏÞ¹«Ë¾ ÁªÏµÈË£º ÁõÀöÄÈ ÁªÏµ·½Ê½£º025-52771556
