YX¡¢YXCÐ͵ç½ÓµãѹÁ¦±í
YX¡¢YXC Series Electrical Contact Pressure Meter
¼ò½é
µç½ÓµãѹÁ¦±íÊÊÓÃÓÚ²âÁ¿¶ÔͺϽðÎÞ¸¯Ê´¡¢ÎÞ±¬Õ¨Î£ÏÕ¡¢·Ç½á¾§µÄ¸÷ÖÖÒºÌå¡¢ÆøÌåµÈ½éÖʵÄѹÁ¦¡£ÒDZí¾ÓëÏàÓ¦µÄµçÆøÆ÷¼þÅäÌ×ʹÓ㬿ɴﵽ¶Ô±»²âѹÁ¦ÏµÍ³ÊµÏÖÔ¤ÏÈÉ趨µÄ×î´ó»ò×îСѹÁ¦ÖµµÄ˫λ×Ô¶¯¿ØÖƺͷ¢ÐÅ£¨±¨¾¯£©µÄÄ¿µÄ¡£
ÒDZí¾ßÓвâÁ¿¿ØÖƹ¦ÄÜ£¬¿ÉÈÎÒâÉ趨ÉÏ¡¢Ï¿ØÖÆÑ¹Á¦Öµ£¬¶¯×÷Îȶ¨¿É¿¿£¬ÔÚʯÓÍ¡¢»¯¹¤¡¢µçÕ¾¡¢Ò±½ðµÈ¹¤ÒµÆóÒµ¼°»úµçÉ豸ÉϹ㷺ÅäÌ×ʹÓá£
±¾¹«Ë¾Éú²úµÄµç½ÓµãϵÁаüÀ¨À¨´ÅÖúµç½Óµã¡¢ÄÍÕðµç½Óµã¡¢²»Ðâ¸Öµç½Óµã¡¢¸ôĤµç½Óµã¡¢°±Óõç½ÓµãµÈ£¬¿ÉÈ«ÃæÂú×ãʹÓÃÌõ¼þµÄÒªÇó¡£
Brief Introduction:
Electrical contact pressure meter is applicable to measure pressures of various such mediums as non- crystallized liquids or gases without danger of explosion that has no corrosive action on copper alloy. This instrument, if used with corresponding electrical devices in supporting set, may achieve the purposes of two-digital automatic control and message sending (alerting), which show pre-set max. or min. pressures of the tested pressure system.
This instrument has measuring and controlling function, which enables arbitrary setting of upper and/or lower values of pressure control. With its reliable action, it is widely used supporting device in electromechanical equipments in such industries as petroleum, chemical industry, power station, and metallurgy.
Electrolysis point series produced by this company include: magnet-booster electric contact, shock resistance electric contact, stainless steel electric contact, diaphragm electric diaphragm, electric contact for ammonia, etc., fully satisfying requirements of applied conditions.
¹¹³ÉʾÒâͼ
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º1.6¼¶£¬2.5¼¶
- ´¥µç¹¦ÂÊ£ºYXC´ÅÖúʽΪ1A¡¢10VA£¬ YX Ö±½Ó×÷ÓÃʽΪ0.7A¡¢30VA
- ×î¸ß¹¤×÷µçѹ£ºAC380V ¡¢DC220V
- ¿ØÖÆ·½Ê½£ºÉÏ¡¢ÏÂÏÞ¡¢Ë«ÉÏÏÞ¡¢Ë«ÏÂÏ޵ȿØÖÆÐÎÊÆ¡£
- ʹÓû·¾³£º-40¡æ¡«70¡æ£¬Ïà¶Ôʪ¶È²»´óÓÚ85%
Principal technical parameters
- Precision : 1.5, 2.5 grades
- Electric shock power: 1A, 10VA, YX for YXC magnet assisting type 0.7A, and 30VA for direct action type
- Highest working voltage: AC380V
- Control style: upper or lower limit, double upper limit, double lower limit, or other control forms
- Environmental condition in use: -40¡«70¡æ, relative humidity less than 85%
½á¹¹ÔÀí
ÒDZíÓɲâÁ¿ÏµÍ³¡¢Ö¸Ê¾×°Öᢵç½Óµã×°Öá¢Íâ¿Ç¡¢µ÷½Ú×°Öü°½ÓÏߺеÈ×é³É¡£
µ±±»²âѹÁ¦×÷ÓÃÓÚµ¯»É¹Üʱ£¬ÆäÄ©¶Ë²úÉúÏàÓ¦µÄµ¯ÐÔ±äÐΡª¡ªÎ»ÒÆ£¬¾´«¶¯»ú¹¹·Å´óºó£¬ÓÉָʾװÖÃÔÚ¶ÈÅÌÉÏָʾ³öÀ´¡£Í¬Ê±Ö¸Õë´ø¶¯µç½Óµã×°ÖõĻ´¥µãÓëÉ趨ָÕëÉϵĴ¥Í·£¨ÉÏÏÞ»òÏÂÏÞ£©Ïà½Ó´¥µÄ˲ʱ£¬ÖÂʹ¿ØÖÆÏµÍ³½Óͨ»ò¶Ï¿ªµç·£¬ÒÔ´ïµ½×Ô¶¯¿ØÖƺͷ¢Ðű¨¾¯µÄÄ¿µÄ¡£
ÔÚµç½Óµã×°ÖÃÉÏ×°Óпɵ÷½ÚµÄÓÀ¾Ã´Å¸Ö£¬¿ÉÒÔÔö¼Ó½ÓµãÎüÁ¦£¬¼Ó¿ì½Ó´¥¶¯×÷£¬´Ó¶øÊ¹´¥µã½Ó´¥¿É¿¿£¬Ïû³ýµç»¡£¬ÄÜÓÐЧµØ±ÜÃâÒDZíÓÉÓÚ¹¤×÷»·¾³Õñ¶¯»ò½éÖÊѹÁ¦Âö¶¯Ôì³É´¥µãµÄƵ·±¹Ø¶Ï¡£ËùÒÔ¸ÃÒDZí¾ßÓж¯×÷¿É¿¿¡¢Ê¹ÓÃÊÙÃü³¤¡¢´¥µã¿ª¹Ø¹¦ÂʽϴóµÈÓŵ㡣
Configuration principle
This instrument consists of measuring system, indicating device, magnet-assisted electric contact device, outer housing, adjusting device, and junction box, etc.
When the pressure acts on the spring pipe, corresponding elastic deformation or displacement occurs at the pipe end accordingly, which is amplified through running gear and displayed in indicating devices dial as the pressure being tested. Meanwhile, indicating needle makes the armature contact of the electric contact device and the contactor (superior limit or lower limit) fixed on needle contact together instantaneously, which causes the controlling system switches on or off, for the purpose of automatic control and alert by sending message.
A piece of permanent magnetic steel is fixed on the electric contact signaling needle of the electric contact device, so as to reinforce the magnetism of the contactor and speed up the contact action. This may ensure reliable contact of the contactors, to eliminate electric arc, and to avoid such frequent switch-on/off of the contactors caused by the working environment, vibration, or medium pressure pulse of the instrument. This instrument has a lot of advantages, including reliable action, long-term life span of usage, greater power of contact switch, and so on. |
