YPϵÁÐĤƬѹÁ¦±í YP Series Theca Pressure Meter Series
¼ò½é
ĤƬѹÁ¦±íÊÊÓÃÓÚ²âÁ¿¾ßÓÐÒ»¶¨¸¯Ê´ÐÔ¡¢·ÇÄý¹Ì»ò·Ç½á¾§µÄ¸÷ÖÖÁ÷Ìå½éÌåµÄѹÁ¦»òÕæ¿Õ£¬ËüÊǽâ¾ö²âÁ¿¸ßÎÂÕ³³íѹÁ¦µÄÓÐЧ;¾¶¡£
Ä͸¯Ê´ÐÔÄÜÈ¡¾öÓÚĤƬ²ÄÁÏ¡£¿É¸ù¾Ý²âÁ¿½éÖʶÔÄ͸¯Ê´ÐÔÄܵIJ»Í¬ÒªÇó¶øÑ¡Óò»Í¬²ÄÖʵÄĤƬ¡£
²»Ðâ¸ÖĤƬѹÁ¦±íµÄµ¼Ñ¹ÏµÍ³ºÍÍâ¿ÇµÈ¾ùΪ²»Ðâ¸Ö£¬ÓнÏÇ¿µÄÄ͸¯Ê´ÐÔÄÜ¡£
ÄÍÕðĤƬѹÁ¦±íÄÚ²¿³ä¹à×èÄáÒººÍÅäÌ×»º³å×°Ö㬾ßÓÐÁ¼ºÃµÄÄÍÕðÐÔÄÜ¡£ÔÚ±»²â½éÖʵÄѹÁ¦ÓÐÇ¿ÁÒÂö³å±ä»¯»òѹÁ¦³å»÷ºÍÔÚÉú²ú¹¤ÒÕÖо³£Í»È»Ð¶ºÉµÄ³¡ºÏ£¬ÒÔ¼°»·¾³Õ𶯽ϴóµÄ³¡ËùÖУ¬ÄÍÕðĤƬѹÁ¦±í¶¼ÄÜÎȶ¨½øÐвâÁ¿¡£
Brief introduction
Diaphragm pressure meters are suitable for measuring pressure or negative pressure of various liquid mediums that is corrosive, non-crystalloid and non-concretionary.Itis officient path to slove measure high temperature viscidity pressure.
Corrosion resistance depends on diaphragm material. Choosing diaphragm material is decided by different performance of corrosion resistant that the measured medium required.
In stainless steel diaphragm pressure meters, stainless steel material is adopted in manufacturing pressure leading system and its crust, so this sort of meters possesses better corrosion-resistant performance.
Shockproof diaphragm pressure meter is filled with damping liquid inside and assembled with buffering device, owning good performance of shock proof. This sort of meters can measure pressure steadily in locations where the pressure of medium changes intensely and pressure shock exists, or pressure is released suddenly in the course of manufacturing, or working environment shock largely.
¹¹³ÉʾÒâͼ Internal structure
½á¹¹ÔÀí
ÒDZíÓɲâÁ¿ÏµÍ³£¨°üÀ¨·¨À¼½ÓÍ·¡¢²¨ÎÆÄ¤Æ¬£©¡¢´«¶¯Ö¸Ê¾»ú¹¹£¨°üÀ¨Á¬¸Ë¡¢³ÝÂÖ´«¶¯»ú¹¹¡¢Ö¸ÕëºÍ¶ÈÅÌ£©ºÍÍâ¿Ç£¨°üÀ¨±í¿ÇºÍÕÖȦ£©µÈ×é³É¡£ÒDZíÍâ¿ÇΪ·À½¦½á¹¹£¬¾ßÓнϺõÄÃÜÐÔ£¬¹ÊÄܱ£»¤ÆäÄÚ²¿»ú¹¹ÃâÊÜÎÛ»à½þÈë¡£
ÒDZíµÄ×÷ÓÃÔÀíÊÇ»ùÓÚµ¯ÐÔÔª¼þ£¨²âÁ¿ÏµÍ³ÉϵÄĤƬ£©±äÐΡ£ÔÚ±»²â½éÖʵÄѹÁ¦×÷ÓÃÏ£¬ÆÈʹĤƬ²úÉúÏàÓ¦µÄµ¯ÐÔ±äÐΡª¡ªÎ»ÒÆ£¬½èÖú¶¥¸Ëʹ¾´«¶¯»ú¹¹¹¤×÷£¬Óɹ̶¨ÓÚ³ÝÂÖÉϵÄÖ¸Õ뽫±»²âÖµÔÚ¶ÈÅÌÉÏָʾ³öÀ´¡£
Configuration principle
This sort of meters is composed of measuring system (including flange joint, ripple diaphragm), driving indicating machine (including connecting bar, gear wheel driving machine, pointer and meter dial), and crust (including meter shell and cover circle). Meter crust is designed into antispatter structure, with better sealing performance, so it can prevent dirtiness from immerging into the inner structure.
Operation principle of the meters is based on distortion of elastic components (diaphragm used in measuring system). Under the action of pressure of measured medium, diaphragm will produce corresponding elastic distortion£displacement. The displacement is enlarged by driving machine in virtue of connecting bar, thus measured pressure value will be shown up gradually by pointer fixed on gear wheel.
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º2.5¼¶
- ʹÓû·¾³Î¶ȣº-40~+70¡æ ±í¿ÇÄÚ²»³äÓÍ 5¡æ~55¡æ ±í¿ÇÄÚ³ä¸ÊÓÍ
-25¡æ~55¡æ ±í¿ÇÄÚ³ä¹èÓÍ Ïà¶Ôʪ¶È²»´óÓÚ90%
- ζÈÓ°Ï죺ʹÓÃÎÂ¶ÈÆ«Àë20¡À5¡æÊ±£¬Æäζȸ½¼ÓÎó²î²»´óÓÚ 0.04%/¡æ
- ¹¤×÷λÖ㺴¹Ö±°²×°
- Íâ¿Ç·À»¤µÈ¼¶£ºIP64
Principal technical parameters
- Accuracy: 2.5 grades
- emperature of applicable circumstance: -40~+70¡æ,
- with no petrol filled inside the crust 5¡æ~55¡æ
- with glycerin filled inside the crust
- Temperature affect: (with temperature departure of 20¡À5¡æ
- the additional error shall be less than 0.04%/¡æ
- Working condition: :uprighness connection
- Defend grade of crust: IP64
Ðͺűíʾ Model designations
±ê¼ÇʾÀý£º YJP-150-MF
²»Ðâ¸ÖÄÍÕðĤƬѹÁ¦±í£¨·¨À¼Á¬½Ó£©¡£
Mark example: YJP-150B-MF Electronic code:0420060430
Stainless steel shock proof diaphragm pressure meter(flange connection).Production computer coding please see£º"Guide
for type selection of theca series instruments and meters
ÍâÐγߴç External dimension
ÐͺŹæ¸ñ Types and specifications
¶©»õÐëÖª Ordering instructions
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶È¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇó£¬Çë×¢Ã÷¼¼ÊõÒªÇó¡£ |
