YEϵÁÐĤºÐѹÁ¦±í
Theca Case Pressure Gauge
¼ò ½é
ĤºÐѹÁ¦±í²ÉÓÃĤºÐ×÷Ϊ²âѹÁ¦Ãô¸ÐÔª¼þ¡£²âÁ¿¶ÔÍºÏ½ð²»Æð¸¯Ê´×÷Óá¢ÎÞ±¬Õ¨Î£ÏյįøÌåµÄ΢ѹºÍÕæ¿Õ£¬¹ã·ºÓ¦ÓÃÓÚ¹øÂ¯Í¨·ç¡¢ÆøÌå¹ÜµÀ¡¢È¼ÉÕ×°Öü°ÆäËüÀàËÆÉ豸ÉÏ¡£
²»Ðâ¸ÖĤºÐѹÁ¦±íÔÚÆÕͨĤºÐѹÁ¦±íµÄ»ù´¡Éϵ¼Ñ¹ÏµÍ³¼°Íâ¿Ç¾ù²ÉÓÃÁ˲»Ðâ¸Ö²ÄÁÏ¡£Ó¦ÓÃÓÚÄ͸¯Ê´ÒªÇó½Ï¸ßµÄ¹¤ÒÕÁ÷³ÌÖжԸ÷ÖÖÆøÌå½éÖʵÄѹÁ¦ºÍÕæ¿ÕµÄ²âÁ¿¡£
ÔÚĤºÐѹÁ¦±íµÄ»ù´¡ÉÏÄÚ²¿Ìî³ä×èÄáÒººÍ»º³å×°Öü´³ÉÄÍÕðĤºÐѹÁ¦±í¾ßÓÐÁ¼ºÃµÄÄÍÕðÐÔÄÜ£»ÊÊÓÃÓÚ±»²â½éÖʵÄѹÁ¦ÓÐÇ¿ÁÒÂö³å±ä»¯»òѹÁ¦³å»÷ºÍÔÚÉú²ú¹¤ÒÕÖо³£Í»È»Ð¶ºÉµÄ³¡ºÏ£¬ÒÔ¼°»·¾³Õ𶯽ϴóµÄ³¡Ëù¡£
ĤºÐѹÁ¦±íÓëÏàÓ¦µÄµçÆøÆ÷¼þÅäÌ×ʹÓ㬼´³ÉΪµç½ÓµãĤºÐѹÁ¦±í£¬¿É´ïµ½¶Ô±»²âѹÁ¦ÏµÍ³ÊµÏÖÔ¤ÏÈÉ趨µÄ×î´ó»ò×îСѹÁ¦ÖµµÄ˫λ×Ô¶¯¿ØÖƺͷ¢ÐÅ£¨±¨¾¯£©µÄÄ¿µÄ¡£
ÎÒ¹«Ë¾Éú²úµÄYE-70ĤºÐѹÁ¦±íÅúÁ¿³ö¿ÚÃÀ¹ú¡£
Brief Introduction
Theca box pressure gauges are used to measure micro pressure and negative pressure of gas that has no danger of explosion and does not erode alloy. Adopting theca box as sense organ, the gauges are widely applied to boiler ventilating, gas pipeline, burning device and other similar devices.
Based on common theca box pressure gauges, stainless theca box pressure gauges introduce stainless material uesd in pressure leading system and crust. The gauges are not only suitable for measuring micro pressure and negative pressure of various gas medium in craftwork flow, which require higher performance of corrosion resistance, but also can be applied to boiler ventilating, gas pipeline, burning device and other similar devices.
¹¹³ÉʾÒâͼ
½á¹¹ÔÀí Structure
ÒDZíÓɵ¼Ñ¹ÏµÍ³£¨°üÀ¨½ÓÍ·¡¢Ä¤ºÐµÈ£©¡¢´«¶¯»ú¹¹¡¢Ö¸Ê¾×°ÖᢺÍÍâ¿ÇµÈ×é³É£¨µç½ÓµãĤºÐѹÁ¦±í»¹°üÀ¨´ÅÖúµç½Óµã×°Öᢵ÷½Ú×°Öü°º½¿Õ²åÍ·µÈ£©¡£
µ±±»²â½éÖÊ×÷ÓÃÓÚĤºÐʱ£¬Æä¹Ü¶Ë²úÉúÏàÓ¦µÄµ¯ÐÔ±äÐΡª¡ªÎ»ÒÆ£¬¾´«¶¯»ú¹¹·Å´óºó£¬ÓÉָʾװÖÃÔÚ¶ÈÅÌÉϰѱ»²âѹÁ¦Ö¸Ê¾³öÀ´¡£
µç½ÓµãĤºÐѹÁ¦±íÔÚָʾװÖý«±»²âѹÁ¦ÏÔʾÔÚÒDZí¶ÈÅÌÉϵÄͬʱ£¬Ö¸Õë´ø¶¯µç½Óµã×°ÖõĻ´¥µãÓëÉ趨ָÕëÉϵĴ¥Í·£¨ÉÏÏÞ»òÏÂÏÞ£©Ïà½Ó´¥µÄ˲ʱ£¬¿ØÖÆÏµÍ³½Óͨ»ò¶Ï¿ªµç·£¬ÒÔ´ïµ½×Ô¶¯¿ØÖƺͷ¢Ðű¨¾¯µÄÄ¿µÄ¡£
The meter is composed of pressure leading system (including joint and theca box, etc), driving framework, indicating device and crust.(electric contact theca box dressart meter in dude,magnetism of electric conacd)
When theca box is operated by measured medium, its end will produce elasticity distortiondisplacement. The displacement is enlarged by driving machine, and measured pressure value will be shown up by indicating device on meter dial.
When indicating device installed at electric contact theca box pressure meter shows the measured pressure value on meter dial, the pointer will simultaneously drive active contactor of electric contact device to meet the contactor (upper limit or lower limit) installed at the pointer. Thus control system will switch on or cut off circuit, and both aims of autocontrol and signal sending are all achieved
Ðͺűíʾ
±ê¼ÇʾÀý£ºY..
E-100-ZT ²úÆ·µçÄÔ±àÂëΪ0030053402
ĤºÐµç½ÓµãѹÁ¦±í£¬±í¿Ç¹«³ÆÖ±¾¶100mm£¬°²×°ÐÎʽΪÖáÏòǰ±ß£¬ÖáÏòÅÌװʽ¡£ÏêϸµçÄÔ±àÂë²ÎÕÕ¡¶Ä¤ºÐѹÁ¦ÏµÁÐÒDZíÑ¡ÐÍÖ¸ÄÏ¡·
Marking in stance£ºYJE-100-ZT Production computer coding£º0030053402
Electric contact theca box pressure meter , meter dials nominal diameter is 100mm, installation mode is axial front, and installing mode is axial plate mounting. For detail production computer coding information, please refer to ¡°Guide for type selection of theca box series instruments and meters¡±
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º1.6¼¶¡¢2.5¼¶
- ʹÓû·¾³Î¶ȣº-25¡æ~55¡æ£¬Ïà¶Ôʪ¶È²»´óÓÚ85%
- ζÈÓ°Ï죺²»´óÓÚ0.4%/10¡æ
- ¿¹¹¤×÷»·¾³Õñ¶¯£ºV.H.3
V.H.4 £¨ÄÍÕðĤºÐѹÁ¦±í£©
Principal technical parameters
- Accuracy: 1.6 ¡¢2.5 grades
- Temperature of applicable circumstance: -25¡æ~55¡æ,relative
- humidity not greater than 85%
- Temperature influence: no more than 0.4%/10¡æ
- Resistance against vibration of working environment: V.H. 3
V.H.4(shockproof theca box pressure meter
ÐͺŹæ¸ñ
ÐͺŠ|
±ê¶È·¶Î§ Measuring ranges(kPa) |
¾«È·¶È
Accuracy |
ѹÁ¦
Pressure |
Õæ¿Õ Vacuum |
ѹÁ¦Õæ¿Õ£¨Áª³Ì£©
Pressure vacuum (linkage) |
YE-40
YE-50
YE-60
YE-70
YE-75
YE-100
YE-150 |
0¡«1.6
0¡«2.5
0¡«4
0¡«6
0¡«10
0¡«16
0¡«25
0¡«40
0¡«60 |
-1.6¡«0
-2.5¡«0
-4¡«0
-6¡«0
-10¡«0
-16¡«0
-25¡«0
-40¡«0
-60¡«0 |
-0.8¡«+0.8
-1.2¡«+1.2
-2¡«2
-3¡«+3
-5¡«+5
-8¡«+8
-12¡«+12
-20¡«+20
-30¡«+30 |
1.6¡¢2.5 |
²ÄÖÊ˵Ã÷
Áã¼þÃû³Æ |
²ÄÖÊÃû³Æ |
ÆÕͨĤºÐѹÁ¦±í |
²»Ðâ¸ÖĤºÐѹÁ¦±í |
½ÓÒº²ÄÖÊ |
»ÆÍHPb59-1 |
1Cr18Ni9²»Ðâ¸Ö¡¢304²»Ðâ¸Ö¡¢316L²»Ðâ¸Ö |
Ãô¸ÐÔª¼þ
£¨Ä¤ºÐ) |
îëÇàÍ QBe2 |
316L²»Ðâ¸Ö |
Íâ¿Ç |
¸Ö°å08F |
1Cr18Ni9²»Ðâ¸Ö¡¢304²»Ðâ¸Ö |
ÍâÐγߴç
ÐͺÅmodel |
D |
D1 |
d0 |
A |
B1 |
B |
H |
h |
h1 |
L |
d1 |
d2 |
40 |
¦µ40 |
8 |
40 |
42 |
21 |
2 |
10 |
¦µ5 |
50 |
¦µ50 |
¦µ68 |
¦µ60 |
10.5 |
50 |
48 |
31.5 |
2 |
2 |
10 |
¦µ5 |
¦µ3.4 |
60 |
¦µ60 |
¦µ78 |
¦µ70 |
12.3 |
59 |
56 |
31 |
2 |
2 |
14 |
¦µ5 |
¦µ3.4 |
70 |
¦µ70 |
¦µ85 |
¦µ76 |
8 |
42 |
58 |
58 |
3 |
2 |
14 |
¦µ5 |
¦µ4.5 |
75 |
¦µ75 |
¦µ95 |
¦µ86 |
8 |
42 |
56 |
38 |
3 |
2 |
14 |
¦µ5 |
¦µ4.5 |
100 |
¦µ100 |
130 |
118 |
17 |
91 |
90 |
48.5 |
3 |
3 |
20 |
¦µ6 |
¦µ6 |
150 |
¦µ150 |
180 |
165 |
17 |
95 |
118 |
54 |
3 |
3 |
20 |
¦µ6 |
¦µ6 |
ÐͺÅmodel |
D |
D1 |
d0 |
L1 |
B |
H |
H1 |
H2 |
L |
d |
100 |
¦µ100 |
130 |
118 |
91 |
90 |
84 |
17 |
48.5 |
20 |
20 |
150 |
¦µ150 |
180 |
165 |
95 |
118 |
84 |
17 |
50 |
20 |
20 |
½Ó¿Ú³ß´ç
ÐͺÅmodel |
½Ó¿Ú³ß´ç |
YJE-40¡¢50ϵÁÐ |
M10¡Á1;G1/8;1/8NPT; |
YJE-60¡¢70¡¢75ϵÁÐ |
M14¡Á1.5£»1/4NPT;G1/4; |
YJE-100¡¢150ϵÁÐ |
M20¡Á1.5£»G1/2£»1/2NPT |
µçÆøµç·Á¬½ÓʾÒâͼ Electrocircuit Connection Chart
½Óµã×°ÖÃµçÆø²ÎÊý¼°¿ØÖÆÐÎʽ
´¥Í·¹¦ÂÊ
Contact
power |
×î¸ß¹¤×÷µçѹ
The maximal
voltage |
×î´ó¹¤×÷µçÁ÷
The maximal
current |
¿ØÖÆÐÎʽ
Controlling
type |
30VA
£¨×èÐÔ¸ºÔØ£© |
220V DC
»ò380V AC |
1A |
ÉÏÏÂÏÞ¡¢Ë«ÉÏÏÞ¡¢
Ë«ÏÂÏÞ |
