YAϵÁа±Ñ¹Á¦±íYA Series Ammonia Pressure Meter
¼ò½é
°±Ñ¹Á¦±íΪ°±×¨ÓÃÒÇ±í£¬ÓÃÓÚ²âÁ¿¶ÔÆÕ̼ͨ¸Ö¡¢ºÏ½ð½á¹¹¸Ö¡¢°ÄÊÏÌåÀ಻Ðâ¸Ö¼°ÎýǦºÏ½ðÇ¥º¸ÁÏÎÞ¸¯Ê´×÷Ó㬷ǽᾧºÍÄý¹ÌµÄ°±Æø¡¢°±Òº½éÖʵÄѹÁ¦¡£Ö÷ÒªÊÊÓÃÓÚ»¯·ÊÉú²ú¹ý³ÌÖÐÉ豸»òÆäËûÖÐÓÃÀ´²âÁ¿°±µÄÒºÌå¡¢ÆøÌå»òÆä»ìºÏÎïµÈµÄѹÁ¦¡£
Brief Introduction:
Ammonia pressure meter is a special meter for ammonia, used to measure various non-crystallized and solidified medium that have no corrosive action on common carbon system steel, alloy structural steel, Austenite stainless steel, or tinsel bar solder, principally applicable for measuring pressures of liquefied ammonia, gas, or other mixtures in cooling equipments in chemical fertilizer production.
½á¹¹ÔÀí
ÒDZíÓɵ¼Ñ¹ÏµÍ³£¨°üÀ¨½ÓÍ·¡¢µ¯»É¹ÜµÈ£©¡¢´«¶¯»ú¹¹¡¢Ö¸Ê¾×°ÖúÍÍâ¿ÇµÈ×é³É¡£
µ±±»²â½éÖÊ×÷ÓÃÓÚµ¯»É¹Üʱ£¬Æä¹Ü¶Ë²úÉúÏàÓ¦µÄµ¯ÐÔ±äÐΡª¡ªÎ»ÒÆ£¬¾´«¶¯»ú¹¹·Å´óºó£¬ÓÉָʾװÖÃÔÚ¶ÈÅÌÉϰѱ»²âѹÁ¦Ö¸Ê¾³öÀ´¡£
Configuration principle
This instrument consists of pressure pilot system (comprising joints, spring pipe, and so on), running gear, indicating device, and outer housing, etc.
When the medium acts on the spring pipe, corresponding elastic deformation or displacement occurs at the pipe end accordingly, which is amplified through running gear and displayed in indicating devices dial as the pressure being tested.
Ðͺűíʾ
±ê¼ÇʾÀý£ºYA-150ZT
ÖáÏòǰ±ß°±ÓÃѹÁ¦±í£¬°²×°ÐÎʽΪÖáÏòÅÌװʽ¡£
²úÆ·µçÄÔ±àÂëÏê¼û¡¶°±ÓÃѹÁ¦ÏµÁÐÒDZíÑ¡ÐÍÖ¸ÄÏ¡·¡£
Model designations
Mark example: YA-150ZT
For axial front pressure meter for ammonia, the installation form is dial-mounted in axial direction. For further information on computer code, please see the ¡°Guide for type selection of ammonia series instruments and meters¡±
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º2.5¼¶£¬1.6¼¶
- ʹÓû·¾³Ìõ¼þ£º-40¡«70¡æ£¬Ïà¶Ôʪ¶È²»´óÓÚ90%
- ζÈÓ°Ï죺²»´óÓÚ0.4%/10¡æ£¨Ê¹ÓÃÎÂ¶ÈÆ«Àë20¡À5¡æ£©
Principal technical parameters:
- Accuracy: 1.6, 2.5 grades
- Environmental condition in use: -40¡«70¡æ, relative humidity less than 90%
- Temperature affect: no greater than 0.4%/10oC (with temperature departure of 20¡À5oC)
ÐͺŹæ¸ñ Tpes and specifications
ÐͺŠ|
¾«¶È 1.6
ѹÁ¦·¶Î§£¨MPa£© |
YA-100¡¢100Z¡¢100ZT
YA-150¡¢150Z¡¢150ZT |
0¡«0.1£»0¡«0.16£»0¡«0.25£»0¡«0.4£»0¡«0.6£»0¡«1£»0¡«1.6£»0¡«2.5£»0¡«4£»0¡«6£»0¡«10£»0¡«16£»0¡«25£»0¡«40£»0¡«60 |
ÍâÐγߴç External dimension
¶©»õÐëÖª Ordering instructions
¶©»õʱÐë×¢Ã÷£º¡¢Ðͺš¢Ãû³Æ¡¢¾«È·¶È¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇó£¬Çë×¢Ã÷¼¼ÊõÒªÇó¡£
Ordering instructions: types, names, accuracy grades, and measuring ranges .must be clearly noted. In case of special requirements, technical requirements shall be clearly noted specifications on the back of the order on ordering goods. |
