YTT-150ϵÁвԶ´«Ñ¹Á¦±í
YTT-150 Series Differential Motion Remote Transmitting Pressure Meter
¼ò½é
YTT-150ϵÁвԶ´«Ñ¹Á¦±íÓÃÓÚ²âÁ¿¶Ôͼ°ÆäºÏ½ð²»Æð¸¯Ê´×÷ÓõÄÒºÌå¡¢ÆøÌåºÍÕôÆûµÄѹÁ¦¡£ÒÇ±í´øÉÏ×èÄáÆ÷ºó£¬¿É²âÁ¿Âö¶¯¡¢³å»÷¡¢Í»È»Ð¶ºÉ½éÖʵÄѹÁ¦¡£´øÉϸôĤ²¿·Öºó£¬¿É²âÁ¿Õ³¶È´ó¡¢Óи¯Ê´ÐÔ½éÖʵÄѹÁ¦¡£±¾ÒDZí³ý¾ÍµØ½øÐÐѹÁ¦Ö¸Ê¾Í⣬»¹Á¬ÐøÊä³öÓë±»²âѹÁ¦ÐźųÉÏßÐÔµÄ4¡«20mA»ò0-10mAÖ±Á÷Ðźš£¿ÉÒÔÓë·Ö±ðDDZ-¢óµç¶¯µ¥Ôª×éºÏÒDZíÖеÄÏÔʾ¡¢¼Ç¼¡¢µ÷½ÚÒDZíÁªÓã¬×é³É×Ô¶¯¼Ç¼¡¢µ÷½Ú¡¢¿ØÖƵÈϵͳ¡£ÊÊÓÃÓÚʯÓÍ»¯¹¤¡¢Ò±½ð¡¢µçÕ¾¡¢ÇṤҵµÈ²¿ÃÅʹÓá£
YTT-150 series differential motion remote transmitting pressure meter is used for measuring pressures of liquids, gases, or vapors that do not corrode copper and its alloys. If equipped with shock damper, this meter mayalso measure
Pressures caused by pulsation, concussion, and sudden unloaded mediums. If equipped with diaphragm, it may also be used to measure pressures of such mediums with big viscosity and causticity.This instrument provides not only local pressures with indication, but also continual output of 4¡«20mA direct current signal with linear relationship with its testee pressure signal. It may compose automatic recording, adjustment, control, or other systems, in combination with displaying, recording, and adjusting instruments of DDZ-II electricity-powered units, applicable for applications in such departments as petroleum chemical industry, metallurgy, or light industry.
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È£º1.6¼¶
- Êä³öÐźţº4¡«20mA DC»ò0¡«10mA AC£¬¶þÏßÖÆ»òËÄÏßÖÆ
- ¸ºÔصç×裺250¦¸¡«350¦¸
- ¹©µçµçÔ´£ºÖ±Á÷24V
- ¹¤×÷»·¾³£º
£¨1£©Î¶ȣº-10¡«+55¡æ £¨2£©Ïà¶Ôʪ¶È£º¡Ü85% £¨3£©Íâ´Å³¡£º¡Ü5°ÂË¹ÌØ
- Accuracy: : grade 1.6
- Output signal: 4¡«20mA DC,0¡«10mA AC
two or four wire system
- Resistance value of load: 250¦¸¡«350¦¸
- Power supply: 24V DC
- Working environment:
(1) Temperature: -10¡«+55¡æ (2) Relative humidity: ¡Ü85% (3) External magnetic field: ¡Ü5oresteds
±ê¼ÇʾÀý£ºYZTT-150B ²úÆ·µçÄÔ±àÂëΪ 091206301
²î¶¯Ô¶´«Ñ¹Á¦Õæ¿Õ±í£¬Êä³öÐźÅΪ4¡«20mA DC¡£²úÆ·µçÄÔ±àÂëÏê¼û
¡¶²î¶¯Ô¶´«Ñ¹Á¦ÏµÁÐÒDZíÑ¡ÐÍÖ¸ÄÏ¡·¡£
Mark example: the product computer code for YZTT-150B is 091206301.
For differential motion remote transmitting pressure vacuum meter, the output signal is 4¡«20mA DC. for further information on computer code, please see the ¡°Guide for type selection of differential motion remote
transmittingseries instruments and meters¡±
ÐͺŹæ¸ñ Types and specifications
ÍâÐγߴç External dimension
½Ó¿Ú³ß´ç°üÀ¨£ºM20¡Á1.5£»G1/2£»1/2NPT
Joint dimension includes: M20x1.5, G1/2, and 1/2NPT.
¶©»õÐëÖª:
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶ÈµÈ¼¶¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇ󣬶©»õʱÇë×¢Ã÷¼¼ÊõÒªÇó¡£
ÎÞÎýÊÐÒËÐËË«»ªÒDZíÓÐÏÞ¹«Ë¾ ÁªÏµÈË£º ÁõÀöÄÈ ÁªÏµ·½Ê½£º025-52771556
