YTZÐ͵ç×èÔ¶´«Ñ¹Á¦±í YTZ Series Resistance Remote Transmitting Pressure Meter
¼ò½é
Ô¶´«Ñ¹Á¦±íÊÊÓÃÓÚ²âÁ¿¶Ô¸Ö¼°ÍºÏ½ð²»Æð¸¯Ê´×÷ÓõÄÁ÷Ìå£¬ÆøÌåºÍÕôÆûµÄѹÁ¦¡£µç×èÐźÅÊä³ö´«ÖÁ¶þ´ÎÒDZíÉÏ£¬¿ÉÒÔʵÏÖÏÖ³¡¾ÍµØÖ¸Ê¾Ñ¹Á¦ÒÔ±ãÓÚÏÖ³¡¹¤ÒÕ¼ì²é£¬»¹¿ÉÒÔʵÏÖÔ¶¾àÀ뼯ÖпØÖƺ͵÷½Ú¡£
²»Ðâ¸Öµç×èÔ¶´«Ñ¹Á¦±íµÄµ¼Ñ¹ÏµÍ³¼°Íâ¿Ç¾ù²ÉÓÃÁ˲»Ðâ¸Ö²ÄÁÏ£¬ÓнÏÇ¿µÄÄ͸¯Ê´ÐÔÄÜ£¬ÊÊÓÃÓÚ¶ÔÄÍÊ´ÐÔÄÜÓнϸßÒªÇóµÄ³¡ºÏ¡£
ÔÚ²»Ðâ¸Öµç×èÔ¶´«Ñ¹Á¦±íÄÚ³ä¹à×èÄáÒº¼°¼Ó×°»º³å×°Ö㬳ÉΪ²»Ðâ¸ÖÄÍÕðµç×èÔ¶´«Ñ¹Á¦±í¡£ÊÊÓÃÓÚ¹¤×÷»·¾³ÓнÏÇ¿Õ𶯵ij¡ºÏ¡£
Brief Introduction:
The remote transmitting pressure meter is applicable to measure pressure of such liquids, gases or vapors that have no erosive attack on steel or copper alloy. Its resistance signal may be output to the secondary instrument, so as to realize local pressure indicating at field and facilitate field technological testing, even to realize concentrated remote control and adjustment.
The pressure conducting system and its outer housing for stainless steel resistance remote transmitting pressure meter is made of stainless steel, with stronger capacity of corrosion resistance, and applicable to such occasions with higher requirements for capacity of corrosion resistance.
To fill damping liquid and add shock reducer in stainless steel resistance remote transmitting pressure meter, the stainless steel shock resistance resistance remote transmitting pressure meter is constructed, applicable to occasion with stronger vibration in working environment.
Ö÷Òª¼¼Êõ²ÎÊý
1. ¾«È·¶È£º1.6¼¶
2. ·¢ËÍÆ÷Æðʼµç×èÖµ£º3¡«20¦¸
3. ·¢ËÍÆ÷Âú¶Èµç×裺340¦¸¡«400¦¸
4. ·¢ËÍÆ÷½ÓÏß¶Ë¢Ù¢ÛÍâ¼Óµçѹ²»´óÓÚ6V
5. ʹÓû·¾³Ìõ¼þ£º-40¡«+60¡æ£¬Ïà¶Ôʪ¶È²»´óÓÚ85%£¬ÇÒÕ𶯺ͱ»²â½éÖʵļ±¾çÂö¶¯Ó¦¶ÔÒDZíÕý³£¹¤×÷ÎÞÃ÷ÏÔÓ°Ïì¡£
6. ζÈÓ°Ï죺ʹÓÃÎÂ¶ÈÆ«Àë20¡À5¡æÊ±£¬Æäζȸ½¼ÓÎó²î²»´óÓÚ0.4%/10¡æ¡£
Principal technical parameters
1. Accuracy: 1.6 grades
2. Initial resistance value of transmitter: 3¡«20¦¸
3. Full scale resistance value of transmitter: 340¦¸¡«400¦¸
4. Impressed voltage between terminals ¢Ù and ¢Ú: not greater than 6V
5. Environmental condition in use: -40¡«+60oC, with relative humidity not greater than 85% and no vibration and pulse of tested medium greater enough to make obvious be impacted on the instrument from normal working.
6. Temperature affect: in case that the temperature in use 20¡À5¡æ offset, the additional error shall be less than 0.4%/10¡æ.
¹¹³ÉʾÒâͼ Internal structure
Ðͺűíʾ Model designations
±ê¼ÇʾÀý£ºYTZN-150B
²»Ðâ¸Öµç×èÔ¶´«ÄÍÕðѹÁ¦±í¡£¡¶µç×èʽԶ´«Ñ¹Á¦ÏµÁÐÒDZíÑ¡ÐÍÖ¸ÄÏ¡·¡£
Marking instance£ºYTZN-150B £º
Stainless steel resistance remote transmitting pressure meter. Product computer coding, please see the¡°Guide for type selection
of resistance remote transmitting pressure series meters.¡±
ÐͺŹæ¸ñ Types and specifications
½á¹¹ÔÀí
±¾ÒDZíÓÉÒ»¸öµ¯»É¹ÜѹÁ¦±í£¨ÎªÒ»´ÎÒÇ±í£©ºÍÒ»¸ö»¬Ïßµç×èʽ·¢ËÍÆ÷µÈ×é³É¡£
Ò»´ÎÒDZíµÄ×÷ÓÃÔÀíÓëÒ»°ãµ¯»É¹ÜѹÁ¦±íÏàͬ¡£ÓÉÓÚµç×è·¢ËÍÆ÷ϵÉèÖÃÔÚ³ÝÂÖ´«¶¯»ú¹¹ÉÏ£¬Òò´Ëµ±³ÝÂÖ´«¶¯»ú¹¹ÖеÄÉÈÐγÝÂÖÖá²úÉúƫתʱ£¬µç×è·¢ËÍÆ÷µÄת±Û£¨µçË¢£©Ò²ÏàÓ¦µÄµØÆ«×ª¡£ÓÉÓÚµçË¢ÔÚµç×èÆ÷ÉÏ»¬ÐУ¬Ê¹µÃ±»²âѹÁ¦ÖµµÄ±ä»¯±ä»»Îªµç×èÖµµÄ±ä»¯£¬´«µ½¶þ´ÎÒDZíÉÏָʾ³öÓëÒ»´ÎÒDZíÏàÓ¦µÄѹÁ¦Öµ¡£
Structure and principle:
This instrument comprises of a pressure meter, a slide resistance transmitter, and so on.
The mechanical part of this instrument plays same role with normal pressure meter. Because the resistance transmitter is built in the tooth gear, when deflexion occurs on the axle of the segment gear, the rocking arm (electric brush) of the resistance transmitter deflects accordingly. Due to the slide of electric brush on the resistor, changes of the tested pressure value are transformed into changes of resistance value, which is transmitted to secondary instrument. Corresponding value is displayed accordingly. Meanwhile, primary instrument will also indicate corresponding value.
ÍâÐγߴç External dimension
µç×èʽԶ´«Ñ¹Á¦±íÅäÖÃXCZ-104ÐͶþ´ÎÒDZí½ÓÏß·½·¨ Resistance remote transmitting pressure
meter if configured with XCZ-104 type secondary instrument wiring method.
ÓëÆäËûÊýÏÔ¶þ´ÎÒDZíÅä½Óʱ£¬Çë°´¶þ´ÎÒDZí˵Ã÷ÊéµÄ½ÓÏßͼÅä½Ó¡£
For connection with other digital-displaying secondary instrument, please follow the wiring drawing in the instruction book
for secondary instrument.
¶©»õÐëÖª:
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶ÈµÈ¼¶¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇ󣬶©»õʱÇë×¢Ã÷¼¼ÊõÒªÇó¡£
ÎÞÎýÊÐÒËÐËË«»ªÒDZíÓÐÏÞ¹«Ë¾ ÁªÏµÈË£º ÁõÀöÄÈ ÁªÏµ·½Ê½£º025-52771556
