YϵÁÐÒ»°ãѹÁ¦±í Y Series Common Pressure Meter
¼ò½é
Ò»°ãѹÁ¦±íϵÁÐÓÃÓÚ²âÁ¿ÎÞ±¬Õ¨Î£ÏÕ£¬²»½á¾§£¬²»Äý¹Ì£¬ÇÒ¶Ô¸Ö¼°ÍºÏ½ð²»Æð¸¯Ê´×÷ÓõÄÒºÌå¡¢ÆøÌåºÍÕôÆûµÄѹÁ¦»òÕæ¿Õ¡£
µäÐ͵ÄÓ¦Óó¡ËùΪ:¿ÕÆøÑ¹Ëõ»ú¡¢Õæ¿Õ±Ã¡¢¹¤Òչܷ¡¢µ÷ѹ·§¡¢²âÊÔÉ豸¡¢Ò½ÓÃÏû¶¾Æ÷µÈ¡£
Brief introduction
Common pressure meter series are suitable for measuring the pressure of liquid, gas and steam or vacuum, which are non-crystalloid and non-concretionary, and have no danger of explosion and do not erode steel and copper alloy.
Typical applicable locations are: air compressor, vacuum pump, compressing air pipeline, pressure regulating valve, testing equipment, and medical sterilizer, etc.
¹¹³ÉʾÒâͼ Internal structure
Ö÷Òª¼¼Êõ²ÎÊý
- ¾«È·¶È:1.6¼¶¡¢2.5¼¶
- ʹÓû·¾³Ìõ¼þ: -40¡æ~70¡æ,Ïà¶Ôʪ¶È²»´ó
ÓÚ85%¡£
- ζÈÓ°Ï죺ʹÓÃÎÂ¶ÈÆ«Àë20¡À5¡æÊ±,²»´óÓÚ
Principal technical parameters
- Accuracy: 1.6¡¢ 2.5 grades
- -40¡æ~70¡æ, relative humidity is not more than 85%
- Temperature influence:
- When temperature departure is 20¡À5¡æ, additional
- temperature error is not more than 0.4%/10¡æ.
Ðͺűíʾ Model designations
±ê¼ÇʾÀý£ºYJZ-100ZT ²úÆ·µçÄÔ±àÂëΪ:1002054301
ÖáÏòǰ±ßѹÁ¦Õæ¿Õ±í£¬°²×°ÐÎʽΪÖáÏòÅÌװʽ¡£²úÆ·µçÄÔ±àÂëÏê¼û¡¶Ò»°ãѹÁ¦ÏµÁÐÒDZíÑ¡ÐÍÖ¸ÄÏ¡·¡£
Marking instance£ºYJZ-100ZT Production computer coding£º1002054301
Axial front pressure vacuum meter. mounted form is axial dial mounted product computer coding, please see the¡°Guide for type
selection of common series instruments and meters¡±
ÐͺŹæ¸ñ Types and specifications
½á¹¹·Ö½âͼ Internal structure
˵Ã÷: ·À±¬´°¿ÉÊÍ·ÅÒò¹ýÔØµ¯ÐÔÔª¼þÆÆÁѶø²úÉúµÄÄÚ²¿Ñ¹Á¦£¬ÔöÇ¿ÁËÈËÔ±¼°ÉèÊ©µÄ°²È«ÐÔ¡£
Specification:explosion-proof window can release inner pressure caused by break of elastic component when over loaded, and thus security of personnel and establishment is ensured.
½á¹¹ÔÀí
ÒDZíÓɵ¼Ñ¹ÏµÍ³£¨°üÀ¨½ÓÍ·¡¢µ¯»É¹ÜµÈ£©¡¢³ÝÂÖ´«¶¯»ú¹¹¡¢Ê¾Êý×°Öã¨Ö¸ÕëÓë±íÅÌ£©ºÍÍâ¿Ç£¨°üÀ¨±í¿Ç¡¢±íÕÖ¡¢±í²£Á§µÈ£©×é³É¡£
µ¯»É¹ÜÔÚѹÁ¦ºÍÕæ¿ÕµÄ×÷ÓÃÏ£¬²úÉúµ¯ÐÔ±äÐÎÒýÆð¹Ü¶ËÎ»ÒÆ£¬ÆäÎ»ÒÆÍ¨¹ý»úе´«¶¯»ú¹¹½øÐзŴ󣬴«µÝ¸øÊ¾Êý×°Öã¬ÔÙÓÉÖ¸ÕëÔÚ¿ÌÓз¨¶¨¼ÆÁ¿µ¥Î»µÄ¶ÈÅÌÉÏÖ¸³ö±»²âѹÁ¦»òÕæ¿ÕÁ¿Öµ¡£
Configuration principle
The meter is composed of pressure leading system (including joint, spring tube, etc), gear wheel driving machine, indicator device (pointer and meter dial) and crust (including meter crust, meter cover, meter glass, etc).
Under the action of pressure and vacuum, spring tube will produce elastic deformation causing displacement at the end. The displacement is enlarged by mechanical driving device and transferred to indicator, and then the pointer of the meter dial, with measure unit on it, indicates the pressure value or vacuum value
¶ÈÅ̱íʾ·½·¨ Show method of the dial
×îС·Ö¶ÈÖµ±í Min value of pitch line
ÈçÐè¶¨ÖÆÌØÊâ±íÅÌ,ÇëÔÚ¶©µ¥ÖÐ×¢Ã÷¡£For customized special meter dial,clear notes shall be made on the order.
ȱ±í¸ñ
¶ÈÅ̲ο¼Í¼ Dial plate
ÍâÐγߴç External dimension
¶©»õÐëÖª:
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶ÈµÈ¼¶¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇ󣬶©»õʱÇë×¢Ã÷¼¼ÊõÒªÇó¡£
ÎÞÎýÊÐÒËÐËË«»ªÒDZíÓÐÏÞ¹«Ë¾ÄϾ©°ìÊ´¦ ÁªÏµÈË£º ÁõÀöÄÈ ÁªÏµ·½Ê½£º025-52771556
