YBϵÁо«ÃÜѹÁ¦±í Diaphragm Seal Pressure Gauge
¼ò ½é
¾«ÃÜѹÁ¦±íÖ÷ÒªÓÃÓÚ¼ìÑéÆÕͨѹÁ¦±í»ò¾«È·²âÁ¿¶Ôͼ°ÍºÏ½ð²»Æð¸¯Ê´×÷ÓõÄÒºÌå£¬ÆøÌå»òÕôÆûµÄѹÁ¦ºÍ¸ºÑ¹£¬¹ã·ºÓ¦ÓÃÓÚ¹¤ÒµÉú²ú¹ý³Ì¾«ÃܲâÁ¿ºÍ¿ÆÑ§ÊÔÑéÊҵȲ¿ÃÅ¡£
²»Ðâ¸Ö¾«ÃÜѹÁ¦±íÔÚÆÕͨ¾«ÃÜѹÁ¦±íµÄ»ù´¡Éϵ¼Ñ¹ÏµÍ³¼°Íâ¿Ç¾ù²ÉÓÃÁ˲»Ðâ¸Ö²ÄÁÏ¡£Ó¦ÓÃÓÚÄ͸¯Ê´ÒªÇó½Ï¸ßµÄ¹¤ÒÕÁ÷³ÌÖжԸ÷ÖÖÆøÌå»òÕôÆû½éÖʵÄѹÁ¦ºÍ¸ºÑ¹µÄ²âÁ¿¡£
±¾³§Éú²úµÄYB-150ÐÍѹÁ¦±íÔÚ¶ÁÊý×°ÖÃÉÏÉèÓÐ
¾µÃ棬ʹÒDZí¶ÁÊý¸ü¼ÓÇåÎú׼ȷ¡£YB-150AÐÍ»¹ÉèÓе÷Áã×°Ö㨿¹ÕðËø¶¨×°Öã©£¬È·±£Óû§Ê¹Ó÷½±ã¡£
ÄÍÕð¾«ÃÜѹÁ¦±íÄÚ²¿³ä¹à×èÄáÒººÍÅäÌ×»º³å×°Ö㬾ßÓÐÁ¼ºÃµÄÄÍÕðÐÔÄÜ¡£ÔÚ±»²â½éÖʵÄѹÁ¦ÓÐÇ¿ÁÒÂö³å±ä»¯»òѹÁ¦³å»÷ºÍÔÚÉú²ú¹¤ÒÕÖо³£Í»È»Ð¶ºÉµÄ³¡ºÏ£¬ÒÔ¼°»·¾³Õ𶯽ϴóµÄ³¡ËùÖУ¬ÄÍÕð¾«ÃÜѹÁ¦±í¶¼ÄܽøÐо«ÃܲâÁ¿¡£
Brief Introduction
This pressure meter is principally used to test normal pressure meters or accurately measure the pressure and vacuum of such liquids, gases, or vapors that has no erosive attack on copper and copper alloy. It is widely used in fine measurement in industrial production process and adopted by scientific experiment laboratories or other sectors.
For stainless steel precision pressure meter, based on normal precision pressure meter, the pressure connecting system and its outer housing is made of stainless steel, used to measure pressure or negative pressure of various gas or vapor mediums in technological processes with higher requirements of corrosion resistance.
YB-150 model pressure meter produced by this factory is build with a mirror mounted on reading device, making value reading more accurate and clearer. For YB-150A type, a nulling device (shock resistance locking gear) is equipped so as to facilitate clients use.
As shock resistance precision pressure meter is filled with damping liquid and supported with shock reducer, good capacity of shock resistance is obtained accordingly. In such occasions or places as measure pressures of tested mediums with violent changes of pulse or pressure attack, or in production technological process with sudden release of load, or environments with stronger vibration, the shock resisting precision pressure meter is capable to perform fine measurement.
Ö÷Òª¼¼ÊõÖ¸±ê Main Technoiogy Data
¹æ¸ñ Specifcations
½á¹¹ÔÀí Configuration Principle
µ¼Ñ¹ÏµÍ³£¨°üÀ¨½ÓÍ·¡¢µ¯»É¹ÜµÈ£©¡¢³ÝÂÖ´«¶¯»ú¹¹¡¢Ê¾Êý×°Öã¨Ö¸ÕëÓë¶ÈÅÌ£©ºÍÍâ¿Ç£¨°üÀ¨±í¿Ç¡¢±íÕÖ¡¢±í²£Á§µÈ£©×é³É¡£ÒDZíÓнϺõÄÃÜ·âÐÔ²¢ÉèÓмì·â×°Öã¬Äܱ£»¤ÆäÄÚ²¿²âÁ¿»ú¹¹ÃâÊÜ»úеËðÉ˺ÍÎÛ»àÇÖÈë¡£
ÒDZíµÄ×÷ÓÃÔÀíÊÇ»ùÓÚµ¯ÐÔÔª¼þ£¨²âÁ¿ÏµÍ³Öеĵ¯»É¹Ü£©±äÐΡ£ÔÚ±»²â½éÖʵÄѹÁ¦×÷ÓÃÏ£¬½üʹµ¯»É¹Ü֮ĩ¶Ë²úÉúÏàÓ¦µ¯ÐÔ±äÐΡª¡ªÎ»ÒÆ£¬½èÖúÓÚÀ¸Ë¾³ÝÂÖ´«¶¯»ú¹¹µÄ´«¶¯²¢Óè·Å´ó£¬Óɹ̶¨ÓÚ³ÝÂÖÖáÉϵÄÖ¸ÕëÖð½¥½«±»²âÖµÔÚ¶ÈÅÌÉÏָʾ³öÀ´¡£
Configuration principle
This instrument comprises of indicating part of measuring system and outer housing. With its good leakproofness and sealing device based on examination, its interior measuring gear is prevented from mechanical damage and invasion of dirty objects.
The action principle of this instrument is based on deformation of elastic cell (spring pipe in the measuring system). Under the pressure affect of tested medium, corresponding deformation displacement are generated by the end of spring pipe. Through the transmission and amplification by tension rod of the gear transmitting device, the value of such deformation is indicated on scale by the needle fixed on the axle of the gear.
ÍâÐγߴç Overall Dimensions
µ¥Î» mm
½Ó¿Ú³ß´ç
ÐͺÅmodel |
½Ó¿Ú³ß´ç |
Y-100ϵÁÐ |
M20¡Á1.5£»G1/2£»1/4NPT£»1/2NPT |
Y-150ϵÁÐ |
¶ÈÅ̱íʾ·½·¨
×îС·Ö¶ÈÖµ±í
Min value of pitch line
ÈçÐè¶¨ÖÆÌØÊâ±íÅÌ,ÇëÔÚ¶©µ¥ÖÐ×¢Ã÷¡£
For customized special meter dial,
clear notes shall be made on the order.
ѹÁ¦Öµ Pressure date |
¾«È·¶ÈµÈ¼¶£¨Accuracy£© |
0.4 |
0.3 |
0¡«0.1 |
0.0005 |
0 |
¡«0.16 |
0.001 |
0 |
¡«0.25 |
0.002 |
0 |
¡«0.4 |
0.002 |
0 |
¡«0.6 |
0.0005 |
0 |
¡«1 |
0.005 |
0 |
¡«1.6 |
0.01 |
0 |
¡«2.5 |
0.02 |
0 |
¡«4 |
0.02 |
0 |
¡«6 |
0.005 |
0 |
¡«10 |
0.05 |
0.1 |
¡«16 |
0.1 |
0.1 |
¡«25 |
0.2 |
0.1 |
¡«40 |
0.2 |
0.1 |
¡«60 |
0.5 |
0.2 |
¡«100 |
0.5 |
0.5 |
Õæ¿ÕÖµ£º-0.1¡«0 |
0.0005 |
0 |
¶ÈÅ̲ο¼Í¼
²ÄÖÊ˵Ã÷
Ãû³Æ |
²ÄÖÊ |
Ãô¸ÐÔª¼þ£¨µ¯»É¹ÜÐÍʽ£© |
CÐÍ¹Ü |
ÎýÁ×ÇàÍ |
-0£»0-0.1£»0-0.16£»0-0.25£»0-0.4£»0-0.6£»0-1£»0-1.6£»0-2.5£»0-4£»0-6£» |
CÐÍ¹Ü |
¸õ·°¸Ö |
0-10£»0-16£»0-25£»0-40£»0-60£»0¡«100 |
½ÓÒº²ÄÖÊ |
Í¡¢316²»Ðâ¸Ö |
Íâ¿Ç |
ÖýÂÁ¡¢304²»Ðâ¸Ö |
¶©»õÐëÖª:
¶©»õʱÐë×¢Ã÷£ºÐͺš¢Ãû³Æ¡¢¾«È·¶ÈµÈ¼¶¡¢²âÁ¿·¶Î§¡£ÈçÌØÊâÒªÇ󣬶©»õʱÇë×¢Ã÷¼¼ÊõÒªÇó¡£
ÎÞÎýÊÐÒËÐËË«»ªÒDZíÓÐÏÞ¹«Ë¾ÄϾ©°ìÊ´¦ ÁªÏµÈË£º ÁõÀöÄÈ ÁªÏµ·½Ê½£º025-52771556
