产品名称: Core 2 Duo 工控機
型  号: DT-B1104
价  格:
Specification
CPU
  • Intel® Core 2 Duo/ Core Duo/ Core Solo mobile Processor
  • FSB: 533/800 MHz
Chipset
  • North Bridge: Intel GME965
  • South Bridge: ICH8M
Memory
  • 2 x 200pin SO-DIMM Socket Support Dual Channel DDR2 533/667 SDRAM up to 4GB
BIOS
  • Award 16MB SPI BIOS
Display
  • Intel GME965 Integrated Graphics Media Accelerator X3100, supports 384MB video memory
  • Resolution: 2048*1536 @32bpp (@60Hz)
  • Dual Display: CRT + LVDS or CRT + DVI-D
  • LVDS: 18/24-bit Dual-channel LVDS
  • DVI: Chrontel CH7307C DVI transmitter up to 165MB pixels/second
Audio
  • AC97 2.0 CODEC compatible
  • 1 x Mic-in,1 x Line-in,1 x Line-out
  • TPA3005D2 5W Stereo Amplifier
Ethernet
  • Controller: Realtek RTL8111B
  • 2 x Gigabit Ethernet Port
I/O Interface
  • SSD: 1 x Type II Compact Flash Connector
  • IDE connector:1 x 40pin IDE Connector
  • SATA: 3 x Serial ATA Connector
  • PS/2 Port :1 x Keyboard, 1 x Mouse
  • USB 2.0 Port:2 x Front, 4 x Rear
  • Serial Port:4 x 1L D-SUB 9pin connector (Power output)
  • DIO: 8-bit General Purpose I/O for DI & DO
  • Expansion Slot: 1 x PCI
Power
  • 125W Internal Power Supply
Watchdog Timer
  • Reset: 1 sec ~ 255 min. and 1 sec or 1 min/step
H/W Status Monitor
  • Monitoring CPU temperature, voltage, and cooling fan Status.
  • Auto throttling control when CPU overheats
Mechanical and Environment
Dimensions
  • 310mm ( L ) X 255mm ( W ) X 100mm ( H )
Housing
  • Metal Case
Temperature
  • Operating:0oC ~ 40oC
  • Storage:- 20oC ~ 80oC
Relative Humidity
  • 0 %~ 90%
Odering Information:
 DT-B1104S
  • Socket 478 Intel Core 2 Duo/ Core Duo with Dual LAN, 6 USB, PCI x 1 Expansion
关 键 词: Core 2 Duo
公司名称: 岱爾科技有限公司
联 系 人: Michael
电  话: 886-229992208
手  机: 886-932392448
地  址: 台灣台北縣三重市重新路五段609巷18號6樓之4
邮  编: 241
10.4 寸 Panel(DT-PPC800LX)
DT-C35Q 工業機箱(DT-C35Q)
Atom 迷你工控機(DT-B1110S)
17 Panel PC (DT-PPC965)
19 Panel PC (DT-PPC945G)
Core 2 Duo 雙(DT-B1105S)
Core 2 Duo 雙(DT-B1104S)
Core 2 Quad (DT-BMX35Q)
Core 2 Duo 工(DT-BMX945G)
DT-C945(DT-C945)
DT-C1104 工業機(DT-C1104)
DT-C3100 工業機(DT-C3100)
DT-C2100 工業機(DT-C2100)
DT-C1100 工業機(DT-C1100)
3.5 VIA 計算機系(DT-B3100)
AMD 計算機系統(DT-B2100)
Pentium Cele(DT-B1100)
Atom Mini IT(DT-K1130)
AMD LX800 工業(DT-M2100)
