The DT-PPC800LX industrial touch panel computer, is an all-in-one and compact system designed around a highly integrated AMD® CS5536 chipset embedded computer. Equipped with a 10.4-inch VGA TFT LCD display, an embedded ultra low power consumption AMD® Geode LX800 CPU, a fanless cooling system, it offers a smart design for economic space to meet the highly performance requirements for business and industrial applications including stores / warehouse / home/ school, POS, Kiosk, Network Communication and Information terminal.
Display Type |
10.4" VGA TFT LCD |
Resolution |
640 x 480 pixels |
Luminance / Brightness |
350 cd/m2 |
Color |
262K (8 bits/colors) |
Pixel Pitch (H/V) |
0.330 mm X 0.330 mm |
Contrast Ratio |
300 : 1 (typ.) |
Viewing Angle (H/V) |
14065439;/ 14065439;(typ.) |
Backlight MTBF |
50,000 hrs |
Touch Screen Type |
5 Wire Resistive Touch Screen with USB Interface |
System:
CPU: AMD Geode LX800 500MHz
1 x 200-pin SO-DIMM socket for DDR266/333/400 SDRAM up to 2GB
Chipset
£® AMD Geode CS5536 (USB2.0)
On-board LAN
£® 1 x RJ-45 Connector
£® Supports Wake on LAN
I/O Interface
£® Serial Port: 1 x D-SUB 9-pin Connector for RS232
£® Universal Serial Bus: Supports 4 x USB2.0 Connectors (front x 2, rear x 2)
£® Parallel Port (M/B only): 1 x D-SUB 25-pin Connector to support SPP / EPP / ECP mode
£® PS/2: 2 x 1L Mini-Din Connector for Keyboard and Mouse
£® On-board One Compact Flash Socket (Type-II socket)
£® IDE Interface: One 2 x 22 (2.0mm) Box Header
On-board RTC
£® Internal RTC supporting by CS5536
Storage
£® 2.5¡± HDD: One 44-pin Connector (secondary)
Expansion Slot
£® On-board One PCI Slot (M/B only) or One Mini PCI Socket
£® On-board One RJ-11 Connector for Mini PCI Modem Card
System Power
£® DC +5V External Power Adapter
Dimention: 300mm(W) x 69.6mm(D) x 250mm(H)
