The DT-PPC 965 industrial touch panel computer is an all-in-one and compact system designed around a highly integrated Intel® 965GME chipset motherboard computer which is equipped with a 17-inch XGA TFT LCD display.
It provides a smart "All in One" design for tiny space to meet the highly performance requirements for business and industrial applications including Gaming, Automation, POS, Kiosk, Education, Network communication , Work Place and Information Center.
Specification:
| Display Type |
17" SXGA TFT LCD |
| Resolution |
1280 x 1024 pixels |
| Luminance / Brightness |
300 cd/m2 |
| Color |
16.7 M (8 bits/colors) |
| Pixel Pitch (H/V) |
0.297 mm X 0.297 mm |
| Contrast Ratio |
500 : 1 (typ.) |
| Viewing Angle (H/V) |
16065439;/ 16065439; (typ.) |
| Backlight MTBF |
50,000 hrs |
| Touch Screen Type |
5 Wire Resistive Touch Screen |
System:
CPU: Intel Core 2 Dou/ Duo Core with 65nm process technology
Chipset: 965GME+ICH8
Mini ITX Form Factor: 17 x 17 cm
DDR2 800 SDRAM up to 4GB
Two Gigabit LANs
Compact Flash Socket
Ten USB 2.0
Four Serial Ports
One IDE slot
One PCI
One PCIE x 16
| Dimension |
430mm(W) x 350mm(H) x 109.2mm(D) |
| Weight |
9.3kg |
| Environment |
Storage Temperature: -2065439;~6065439;C Operating Temperature: 065439;~5065439;C Relative Humidity: 10%~95% , non-condensing |
