6ES7291-8BA20-0XA0
s7-200电池盒现货销售 6ES7291-8BA20-0XA0
Type |
24 V/4 A
Order number |
6EP1 332-1SH51 |
Input |
Single-phase AC |
Rated voltage Uinrated |
100 V - 240 V AC wide-range input |
Voltage range |
85 V to 264 V AC |
Overvoltage strength |
2.3 x Uin rated/1.3 ms |
Line buffering at Iout rated |
> 40 ms at Uin = 187 V |
Rated line frequency, rated line-frequency range |
50/60 Hz; 47 Hz to 63 Hz |
Rated current Iinrated |
1.95 A - 0.97 A |
Switch-on current limit (+25 °C) |
< 30 A |
I2t |
< 2.5 A2s |
Built-in line-side fuse |
Internal |
Recommended miniature circuit breaker (IEC 898) in the supply feeder |
At and above 16 A, B characteristic or at and above 10 A, C characteristic |
Output |
Controlled, isolated DC voltage |
Rated voltage Uoutrated |
24 V DC |
Total tolerance, static |
±3 % |
Approx. 0.1 % |
Approx. 1.5 % |
Ripple content (clock frequency approx. 90 kHz) |
< 200 m Vpp |
Spikes (bandwidth approx. 20 MHz) |
< 300 m Vpp |
Adjustment range |
22.2 V to 26.4 V |
Operation indicator |
Green LED for output voltage OK |
Response on activation/deactivation |
No overshoot of Uout (soft start) |
Startup delay/voltage rise |
< 0.5 s/typ. 35 ms |
Rated current Ioutrated |
4 A |
Current range up to +55 °C |
0 A to 4 A |
Parallel switching for enhanced performance |
Yes |
Efficiency |
Efficiency at Uoutrated, Iout rated |
Typically. 89 % |
Heat loss at Uoutrated, Iout rated |
Typically 12 W |
Control |
Dynamic line smoothing (Uin rated ±15 %) |
< 0.2 % Uout |
Dynamic load smoothing (Iout: 10/90/10 %) |
±1.5 % Uout |
Load-step settling time |
Typically 20 ms |
Typically 20 ms |
Protection and monitoring |
Current limit |
Typically 4.7 A |
Short-circuit protection |
Constant-current characteristic |
Sustained-short-circuit-current rms value |
< 10 A |
Overload/short-circuit indicator |
Security |
Primary/secondary galvanic isolation |
Yes, safety extra-low output voltage Uout to EN 60950 and EN 50178 |
Protection class |
Class II (without protective conductor) |
CE marking |
Yes |
UL/cUL (CSA) approval |
Yes, cULus-listed (UL 508, CSA 22.2), file E197259; cURus-recognized (UL 60950, CSA 22.2), file E151273 |
FM approval |
Yes, Class I Div. 2, Group A, B, C, D T4 |
Marine Type Approval |
Yes, GL, ABS |
Degree of protection (EN 60529) |
IP20 |
EMC |
Emitted interference |
EN 55022 Class B |
Supply-harmonics limitation |
EN 61000-3-2 |
Noise immunity |
EN 61000-6-2 |
Operating data |
Ambient temperature range |
-20 °C to +55 °C with natural convection |
Transport/storage temperature range |
-40 °C to +70 °C |
Humidity class |
Climate class 3K3 to EN 60721, no condensation |
Mechanical system |
Supply-input connections L1, N |
Solid/finely-stranded per screw-type terminal for 0.5 mm to 2.5 mm2 |
Connections
Per 2 screw-type terminals for 0.5 mm to 2.5 mm2
Dimensions (W x H x D) in mm |
90 x 90 x 55 |
Weight |
Approx. 0.34 kg |
Mounting |
Snaps onto DIN rail DIN EN 50022-35x15/7.5 |
