²úÆ·Ãû³Æ£º
½Ó½ü¿ª¹Ø
ÐÍ ºÅ£º
NEB6-12GM50-E2-V1
| General specifications |
| Switching element function |
PNPNO |
| Rated operating distance |
6 mm |
| Installation |
virtually flush |
| Output polarity |
DC |
| Assured operating distance |
0 ... 4.8 mm |
| Actuating element |
mild steel, e. g. 1.0037, SR235JR (formerly St37-2) 18 mm x 18 mm x 1 mm |
| Reduction factor rAl |
0.28 |
| Reduction factor rCu |
0.2 |
| Reduction factor r304 |
0.7 |
| Reduction factor rBrass |
0.35 |
| Nominal ratings |
| Installation conditions |
A |
in steel 1.0037 (St37): 2.4 mm in other metal: 1.2 mm |
B |
12 mm |
C |
18 mm |
F |
24 mm |
| Operating voltage |
10 ... 30 V DC |
| Switching frequency |
0 ... 800 Hz |
| Hysteresis |
0.06 ... 1.2 mm |
| Reverse polarity protection |
yes |
| Short-circuit protection |
pulsing |
| Overload resistance |
yes |
| Wire breakage protection |
yes |
| Surge suppression |
yes |
| Ripple |
10 % |
| Voltage drop |
¡Ü 2 V |
| Repeat accuracy |
0.3 mm |
| Operating current |
0 ... 200 mA , above 70¡ãC max. 150 mA |
| Off-state current |
¡Ü 10 µA |
| No-load supply current |
¡Ü 15 mA |
| Indication of the switching state |
LED, yellow | ÉϺ£ÎåµûóÒ×ÓÐÏÞ¹«Ë¾ µØÖ·:ãÉÐÐÇøÝ·¸£Â·388ºÅ1ºÅÂ¥1008ÊÒ µç»°£º021-65752496-808 18016317662 ´«Õ棺021-65752456 QQ:2386702838 ÁªÏµÈË£ºÍõ˶
