| General specifications |
| Switching element function |
NO/NC programmable |
| Rated operating distance |
20 mm |
| Installation |
flush |
| Output polarity |
AS-Interface |
| Assured operating distance |
0 ... 16.2 mm |
| Reduction factor rAl |
0.33 |
| Reduction factor rCu |
0.31 |
| Reduction factor r304 |
0.74 |
| Reduction factor rBrass |
0.41 |
| Slave type |
Standard slave |
| AS-Interface specification |
V2.1 |
| Required master specification |
¡Ý V2.1 |
| Nominal ratings |
| Operating voltage |
26.5 ... 31.9 V via AS-i bus system |
| Switching frequency |
0 ... 150 Hz |
| Hysteresis |
typ. 5 % |
| Reverse polarity protection |
reverse polarity protected |
| No-load supply current |
¡Ü 40 mA |
| Operating voltage display |
LED, green |
| Indication of the switching state |
dual-LED, yellow |
| Fault indication |
dual-LED, red |
