| System components |
| Emitter |
OBE10M-18GM60-S-V1 |
| Receiver |
OBE10M-18GM60-E5-V1 |
| General specifications |
| Effective detection range |
0 ... 10 m |
| Light source |
IRED |
| Light type |
880 nm IR light |
| Approvals |
CE, cULus Listed 57M3 (Only in association with UL Class 2 power supply; Type 1 enclosure) |
| Diameter of the light spot |
approx. 600 mm at detection range 10 m |
| Indicators/operating means |
| Function display |
Dual color-LED, yellow/green yellow: switching state green: power on flashing: stability control |
| Controls |
sensitivity adjustment |
