| General specifications |
| Effective detection range |
0 ... 5 m |
| Threshold detection range |
7 m |
| Light source |
LED |
| Light type |
modulated visible red light |
| Approvals |
CE, cULus Listed 57M3 (Only in association with UL Class 2 power supply; Type 1 enclosure) |
| Diameter of the light spot |
approx. 500 mm at a distance of 7 m |
| Angle of divergence |
approx. 2 ¡ã |
| Functional safety related parameters |
| MTTFd |
860 a |
| Mission Time (TM) |
20 a |
| Diagnostic Coverage (DC) |
0 % |
| Indicators/operating means |
| Function display |
LED yellow: lights up when receiving the light beam ; flashes when falling short of the stability control; OFF when light beam is interrupted |
| Controls |
sensitivity adjustment |
| Controls |
Light/Dark switch |
