Telesis ÀسÛCOϵÁм¤¹â´ò±ê»ú£¬ÓÐÈýÖÖ²»Í¬µÄ¹¦ÂÊ¿ÉÑ¡£¬10W¡¢30WºÍ50WÊǶÔÓÚһЩËÜÁÏ¡¢Ñô¼«»¯´¦Àí½ðÊôºÍ±êÇ©´ò±êÓ¦Óõļ«ºÃÑ¡Ôñ¡£ËüÃÇÊÇ·ÉÐдò±êºÍ¾²Ì¬´ò±êµÄÍêÃÀÑ¡Ôñ¡£COϵÁдò±ê»ú£¬½á¹¹½ô´Õ£¬Ä£¿é»¯Éè¼Æ£¬¿ÉÒÔÔÚ¿Í»§Éú²úÏÖ³¡Èκεط½°²×°¡£
Telesis ÀسÛCOϵÁм¤¹â´ò±ê»ú²úÆ·¹æ¸ñ
´ò±êÍ·ÖØÁ¿ .......................13.8Kg (30.4 lbs.)(10W)26.3Kg (58 lbs.)(30W)25.45Kg (56 lbs.)(50W)
ƽ¾ù¹¦ÂÊ CO10............................................................................10W
ƽ¾ù¹¦ÂÊ CO30............................................................................30W
ƽ¾ù¹¦ÂÊ CO50............................................................................50W
¿ØÖÆÆ÷³ß´ç ................................ 49.28(W) x 20.07 (H) x 50.80cm (D)(19.4˝ x 7.9˝ x 20.0˝)
CO10 ......................................... 78.10(L) x 15.93 (W) x 20.65cm (H)(30.75˝ x 6.27˝ x 8.13˝)
CO30 ......................................... 97.35(L) x 14.71 (W) x 20.49cm (H)(38.33˝ x 5.79˝ x 8.07˝)
CO50 ......................................... 114.35(L) x 14.6 (W) x 20.78cm (H)(45.02˝ x 5.75˝ x 8.18˝ )
¿ØÖÆÆ÷ÖØÁ¿ ............................................................ 14.3Kg (31.5 lbs.)
ÊäÈë ......................................................... 100 ¨C 240 VAC, 50 ¨C 60Hz
²Ù×÷ζȷ¶Î§ ....................................................................16 ¨C 35¡ãC(61-95¡ãF)
Telesis ÀسÛCOϵÁм¤¹â´ò±ê»ú±ê×¼¾µÍ·
½¹¾à ´ò±ê·¶Î§
70mm 50mm X50mm (1.97 X 1.97˝)
100mm 70mm X 70mm (2.76˝ X2.76˝)
150mm 100mm X 100mm (3.94˝ X 3.94˝)
200mm 140mm X 140mm (5.51˝ X 5.51˝)
ÆäËü¾µÍ·Ò²¿ÉÑ¡ÓÃ
Telesis ÀسÛCOϵÁм¤¹â´ò±ê»ú´ò±êËÙ¶È
¡ñ ¶ÔÓÚ·ÉÐдò±êÓ¦Óã¬ÐÐËٶȴﵽÿ·ÖÖÓ152m(ÿ·ÖÖÓ500˝)
¡ñ ÿÃë400¸ö×Ö·û
¡ñ ´ò±êËٶȺÍÉú²úÏßËÙ¶ÈÒÀÀµÓÚ²ÄÁÏ¡¢×Ö·û´óСºÍ´ò±êÖÊÁ¿¡£
Äú»¹¿ÉÒÔÑ¡ÔñÒÔÏÂTelesis´ò±ê²úÆ·£º
1.Telesis TMP1700/470Æø¶¯´ò±ê»ú
2.Telesis ÀسÛ1000Æø¶¯´ò±ê»ú
3. BenchMark460ÊÖ³Öʽ´ò±ê»ú
4. SC3500/470Æø¶¯´ò±ê»ú
5. TMP4210/470 Æø¶¯´ò±ê»ú
6. TMP3200/470µ¥Õë´ò±ê»ú
7. TMM4200/470¶àÕë´ò±ê»ú
8. TMM4250/470 ¶àÕë´ò±ê»ú
9. F-ϵÁÐ FQ10,FQ20ºÍFQ20DH¹âÏ˼¤¹â´ò±ê»ú
10. EVC¶Ë±Ã¼¤¹â´ò±ê»ú
11. E-ϵÁÐEV10/EV15¶Ë±Ã¼¤¹â´ò±ê»ú
