| General specifications |
| Sensing range |
350 ... 6000 mm |
| Adjustment range |
400 ... 6000 mm |
| Unusable area |
0 ... 350 mm |
| Standard target plate |
100 mm x 100 mm |
| Transducer frequency |
approx. 65 kHz |
| Response delay |
285 ms minimum 850 ms factory setting |
| Indicators/operating means |
| LED green |
solid: Power-on flashing: Standby mode or program function object detected |
| LED yellow 1 |
solid: switching state switch output 1 flashing: program function |
| LED yellow 2 |
solid: switching state switch output 2 flashing: program function |
| LED red |
solid: temperature/program plug not connected flashing: fault or program function object not detected |
| Temperature/TEACH-IN connector |
Temperature compensation , Switch points programming , output function setting |
