²úÆ·¼ò½é
KOM600GÊÇÒ»¿îȫеij¬µÍ¹¦ºÄÂÌÉ«¹¤Òµ¼¶ÒÔǧÕ×µçת»»Æ÷,ÆäÂúÔغĵçÁ¿µÍÖÁ4.5W.µÄ¹¤×÷ζȷ¶Î§´Ó-40µ½85¡ãC.
Ìṩ18-72 VDCÊäÈëµçÔ´ºÍÖ§³ÖIP40±£»¤ÀàºÍEMC¹¤ÒµËļ¶ÒªÇó.ÕâЩÌØÐÔÊÇרΪÂú×ãÑÏ¿áµÄ¹¤Òµ»·¾³Éè¼ÆµÄ,²úƷͨ¹ýUL Class 1 Div 2ÈÏÖ¤.
¹Ø¼üÌØÐÔ
1. ÂÌÉ«¹¤ÒµÒÔÌ«ÍøϵÁÐ,´ý»ú¹¦ºÄµÍÖÁ1.5W
2. 1¸öǧÕ×SFF½Ó¿Ú,1¸öǧÕ×µç¿Ú
3. Ö§³ÖLFP(Link Fault Pass-Through)
4. Ö§³Ö¿í·¶Î§½»Ö±Á÷ÊäÈë
5. ·ûºÏ¹¤ÒµËļ¶µç´Å¼æÈÝÐÔÒªÇó
6. IP40·À»¤µÈ¼¶
7.UL508(ÈÏÖ¤ÖÐ),Class 1 Div 2(ÈÏÖ¤ÖÐ),CE,FCCÈÏÖ¤
ÐÔÄܲÎÊý
±ê×¼ |
IEEE 802.3ab,IEEE802.3z |
½Ó¿Ú |
ǧÕ×SFF¿Ú:
1000Base-SX/LX/LH/ZX,SFF½Ó¿Ú
ǧÕ×µç¿Ú:
10/100/1000Base-T(X)×ÔÊÊÓ¦ÒÔÌ«ÍøRJ45½Ó¿Ú |
ָʾµÆ |
Ç°Ãæ°åָʾµÆ
µçԴָʾµÆ:PWR1,PWR2
½Ó¿ÚָʾµÆ:Link/ACT,Speed(µç¿Ú);Link/ACT(¹â¿Ú) |
´«Êä¾àÀë |
Ë«½ÊÏß:100m(²ÉÓñê×¼CAT5,CAT5e ÍøÂçÏßÀÂ)
¶àÄ£¹âÏË:850nm,550m(ǧÕ×)
µ¥Ä£¹âÏË:1310nm,10km/40km(ǧÕ×)
1550nm,60km/80km(ǧÕ×) |
µçÔ´ |
ÊäÈëµçѹ:12DCW(9-36VDC),24DCW(18-72VDC)
½ÓÈë¶Ë×Ó:5о5.08mm¼ä¾à²åÈëʽ¶Ë×Ó
¹¦ÂÊ:ÂúÔØ4.5W,´ý»ú1.5W
¹ýÔر£»¤:Ö§³Ö
·´½Ó±£»¤:Ö§³Ö
ÈßÓà±£»¤:Ö§³Ö |
»úе½á¹¹ |
Íâ¿Ç:½ðÊô²ÄÖÊ,ÎÞ·çÉÈ
·À»¤µÈ¼¶:IP40
³ß´ç:30mm¡Á115mm¡Á91.5mm(W¡ÁH¡ÁD)
ÖØÁ¿:0.46Kg
°²×°·½Ê½:DIN¿¨¹ìʽ»ò±Ú¹Òʽ |
»·¾³ |
¹¤×÷ζÈ:-40¡æ¡«+85¡æ
´¢´æζÈ:-40¡æ¡«+85¡æ
Ïà¶Ôʪ¶È:5¡«95%ÎÞÄý¶ |
Öʱ£ |
MTBF:546000h
±£ÐÞÆÚ:5Äê |
ÈÏÖ¤ |
UL508(ÈÏÖ¤ÖÐ),Class ¢ñ Div 2(ÈÏÖ¤ÖÐ),CE,FCC |
ÐÐÒµ±ê×¼ |
EMI:
FCC CFR47 Part 15,EN55022/CISPR22,Class A
EMS:
IEC61000-4-2(ESD) ¡À8kV(contact),¡À15kV(air)
IEC61000-4-3(RS) 10V/m(80MHz¡«2GHz)
IEC61000-4-4(EFT) Power Port:¡À4kV;Data Port:¡À2kV
IEC61000-4-5(Surge) Power Port:¡À2kV/DM,¡À4kV/CM;Data Port:¡À2kV
IEC61000-4-6(CS) 3V(10kHz¡«150kHz);10V(150kHz¡«80MHz)
IEC61000-4-16(¹²Ä£´«µ¼) 30V(cont.),300V(1s)
»úе:
IEC60068-2-6(Õñ¶¯) IEC60068-2-27(³å»÷) IEC60068-2-32(×ÔÓɵøÂä)
¹¤Òµ:
IEC61000-6-2
Ìú·:
EN50155,EN50121-4
½»Í¨¿ØÖÆ:
NEMA TS-2 |
¶©»õÐÅÏ¢
ÍƼöÐͺŠ|
ǧÕ×SFF¿Ú |
ǧÕ×µç¿Ú |
KOM600G-1GX-1GE |
1 |
1 |
µçÔ´ |
ÃèÊö |
12DCW |
9-36VDC,ÈßÓàÊäÈë |
24DCW |
18-72VDC,ÈßÓàÊäÈë |
²úÆ·×ÊÁÏ
