²úÆ·¼ò½é
SWL3108ÊÇÒ»¿îÂÌÉ«µÍ¹¦ºÄÎÞÏß¹¤ÒµÒÔÌ«Íø½»»»»ú,ÒÔ¹âÏ˽ӿÚ×é³É¿ìËÙÈßÓà»·ÐÎÍøÂç,ÎÞÏß½Ó¿ÚʵÏÖ¹¤ÒµÒƶ¯×°ÖõĿìËÙ¿í´ø½ÓÈëºÍÎÞ·ìÒÆ¶¯ÂþÓÎ.¿ìËÙ»·ÍøÈßÓàÇл»Ê±¼ä<50ms;×î´óÎÞÏßÊý¾ÝËÙÂÊ´ï54Mbps;²¢¿ÉÔÚ120Km/HϵĸßËÙÔ˶¯ÏÂÍê³ÉÕ¾µãÇл».Âú×ãÁË¿ó¾®ÏµÈÌØÊâ»·¾³¿Á¿ÌµÄÒªÇó.SWL3108µÄ°²×°·½Ê½Îª¿¨¹ìʽ»ò±Ú¹Òʽ°²×°,Ç°Ãæ°åÉϾßÓÐ2¸ö100Base-FX½Ó¿Ú,6¸ö10/100Base-T(X)µç¿Ú,1¸öSMAÎÞÏß½Ó¿Ú.
¹Ø¼üÌØÐÔ
1. ÂÌÉ«¹¤ÒµÒÔÌ«ÍøÏµÁÐ
2. Âú×ãIEEE802.11a/b/gÐÒéµÄÎÞÏß½ÓÈ빦ÄÜ
3. Ö§³ÖRCP˽ÓпìËÙÂþÓÎÐÒé(120km/HµÄÔ˶¯Çл»)
4. 2¸ö°ÙÕ×¹â¿Ú,6¸ö°ÙÕ×µç¿Ú
5. Ö§³ÖDT-RingÐÒé×åºÍMSTP
6. IP40·À»¤µÈ¼¶
7. CE,FCCÈÏÖ¤
²úÆ·ÌØÐÔ
1. ÎÞÏßÐÒé:Ö§³ÖIEEE802.11a/b/gÐÒé,RCP˽ÓпìËÙÂþÓÎÐÒé,AP/Bridge/ClientģʽºÍWDS
2. ÈßÓ༼Êõ:Ö§³ÖDT-RingÐÒé×å(×ÔÓúʱ¼ä<50ms)ºÍMSTP
3. ×é²¥ÐÒé:Ö§³ÖIGMP Snooping,GMRPºÍ¾²Ì¬×é²¥
4. ÍøÂç»®·Ö:Ö§³ÖVLAN,PVLAN
5. ·þÎñÖÊÁ¿:Ö§³ÖQoSºÍWMM
6. ´ø¿í¹ÜÀí:Ö§³Ö¶Ë¿Ú¾ÛºÏ,¶Ë¿ÚÏÞËÙ,¹ã²¥·ç±©ÒÖÖÆ
7. ÍøÂç¹ÜÀí¼à¿Ø:Ö§³ÖCLI,Telnet,WEB¹ÜÀí·½Ê½,Kyvision¼¯ÖйÜÀí,SNMPv1/v2/v3,RMON,LLDP,SNTP
8. ÍøÂ簲ȫ:Ö§³Ö¶Ë¿ÚMACµØÖ·°ó¶¨,WPA/WPA2,SSH,SSL,TACACS+,ACL,64/128/512λWEPÊý¾Ý¼ÓÃÜ,Òþ²ØSSID,NAT,¶þ²ã¸ôÀë(¿Í»§¶Ë¸ôÀë)
9. É豸¹ÜÀí:Ö§³ÖFTPÉý¼¶
10. É豸ά»¤:Ö§³Ö¶Ë¿Ú¾µÏñ
11. ¸æ¾¯Êä³ö:Ö§³ÖIP/MAC³åÍ»,µçÔ´,¶Ë¿ÚºÍ»·¸æ¾¯
12. ÌØÉ«¹¦ÄÜ:Ö§³ÖÁ´Â·¼ì²â(Link Check)
ÐÔÄܲÎÊý
±ê×¼ |
IEEE802.11a/b/g,IEEE802.11i,IEEE802.11r,IEEE802.11e,IEEE802.3i,IEEE 802.3u,
IEEE 802.3ad,IEEE802.3x,IEEE 802.1p,IEEE 802.1Q,IEEE 802.1s,IEEE 802.1X |
ÐÒé |
RCP,WDS;DT-Ring,DT-VLAN,DT-Ring+,MSTP;GMRP,IGMP snooping;VLAN,PVLAN;
QoS,WMM;Telnet,HTTP,HTTPS,RMON,SNMPv1/v2/v3,LLDP,SNTP,Bootp,SSH,SSL,
TACACS+,ACL,NAT;FTP;ARP,LACP |
½»»»ÊôÐÔ |
ÓÅÏȼ¶¶ÓÁÐ:4
VLANÊý:256
VLAN ID:1¡«4094
×é²¥×éÊý:256
MAC±í:2K
°ü»º³åÇø:1Mbit
°üת·¢ÂÊ:0.9Mpps
½»»»ÑÓ³Ù:<5¦Ìs |
½Ó¿Ú |
°ÙÕ×¹â¿Ú:100Base-FX,µ¥/¶àÄ£SC/ST/FCÈÎÑ¡
°ÙÕ×µç¿Ú:10/100Base-T(X)×ÔÊÊÓ¦ÒÔÌ«ÍøRJ45½Ó¿Ú
ÌìÏß½Ó¿Ú:SMA
Console¿Ú:RS232,RJ45
¸æ¾¯¶Ë¿Ú:3о3.81mm¼ä¾à²åÈëʽ¶Ë×Ó |
ָʾµÆ |
Ç°Ãæ°åָʾµÆ
ÔËÐÐָʾµÆ:Run
µçԴָʾµÆ:PWR
½»/Ö±Á÷µçԴָʾµÆ:AC/DC
¸æ¾¯Ö¸Ê¾µÆ:Alarm
½Ó¿ÚָʾµÆ:Link/ACT,Speed(µç¿Ú);Link/ACT(¹â¿Ú) |
´«Êä¾àÀë |
¶àÄ£¹âÏË:1310nm,5km(°ÙÕ×)
µ¥Ä£¹âÏË:1310nm,40km/60km(°ÙÕ×)
1550nm,60km/80km(°ÙÕ×) |
ÎÞÏßÖ¸±ê |
¹¤×÷Ƶ¶Î:ÃÀ¹ú:2.400-2.483GHz,5.15-5.35GHz,5.725-5.825GHz
Å·ÖÞ:2.400-2.483GHz,5.15-5.35GHz,5.725-5.825GHz
ÈÕ±¾:2.400-2.483GHz,4.90-5.09GHz,5.15-5.25GHz
Öйú:2.400-2.483GHz,5.725-5.85GHz
µ÷ÖÆ·½Ê½:802.11a/g OFDM(64QAM,16QAM,QPSK,BPSK)
802.11b DSSS(CCK,DQPSK,DBPSK)
·¢É书ÂÊ:<17dBm(0¡«17¿Éµ÷)
½ÓÊÕÁéÃô¶È:-85dBm |
µçÔ´ |
ÊäÈëµçѹ:12DC(9-18VDC)
½ÓÈë¶Ë×Ó:5о5.08mm¼ä¾à²åÈëʽ¶Ë×Ó
¹¦ÂÊ:<10W
¹ýÔØ±£»¤:Ö§³Ö
·´½Ó±£»¤:Ö§³Ö
ÈßÓà±£»¤:Ö§³Ö |
»úе½á¹¹ |
Íâ¿Ç:½ðÊô²ÄÖÊ,ÎÞ·çÉÈ
·À»¤µÈ¼¶:IP40
³ß´ç:80mm¡Á180mm¡Á136mm(W¡ÁH¡ÁD)
ÖØÁ¿:1.5Kg
°²×°·½Ê½:DIN¿¨¹ìʽ»ò±Ú¹Òʽ |
»·¾³ |
¹¤×÷ζÈ:-40¡æ¡«+85¡æ
´¢´æÎ¶È:-40¡æ¡«+85¡æ
Ïà¶Ôʪ¶È:5¡«95%ÎÞÄý¶ |
Öʱ£ |
±£ÐÞÆÚ:5Äê |
ÈÏÖ¤ |
CE,FCC |
ÐÐÒµ±ê×¼ |
EMI:
FCC CFR47 Part 15,EN55022/CISPR22,Class A
EMS:
IEC61000-4-2(ESD) ¡À8kV(contact),¡À15kV(air)
IEC61000-4-3(RS) 10V/m(80MHz¡«2GHz)
IEC61000-4-4(EFT) Power Port:¡À4kV;Data Port:¡À2kV
IEC61000-4-5(Surge) Power Port:¡À2kV/DM,¡À4kV/CM;Data Port:¡À2kV
IEC61000-4-6(CS) 3V(10kHz¡«150kHz);10V(150kHz¡«80MHz)
IEC61000-4-16(¹²Ä£´«µ¼) 30V(cont.),300V(1s)
»úе:
IEC60068-2-6(Õñ¶¯) IEC60068-2-27(³å»÷) IEC60068-2-32(×ÔÓɵøÂä)
¹¤Òµ:
IEC61000-6-2 |
¶©»õÐÅÏ¢
ÍÆ¼öÐͺŠ|
°ÙÕ×¹â¿Ú |
°ÙÕ×µç¿Ú |
ÎÞÏß½Ó¿Ú |
SWL3108-2S/M-6T |
2(FC/ST/SC) |
6 |
1(SMA) |
¹â¿ÚÑ¡ÐͲÎÊý |
SC |
SC½ÓÍ· |
ST |
ST½ÓÍ· |
FC |
FC½ÓÍ· |
1310-5 |
¶àÄ£,1310nm,5km |
1310-40 |
µ¥Ä£,1310nm,40km |
1310-60 |
µ¥Ä£,1310nm,60km |
1550-80 |
µ¥Ä£,1550nm,80km |
µçÔ´ |
ÃèÊö |
12DC |
9-18VDC,ÈßÓàÊäÈë |
²úÆ·×ÊÁÏ
[²úÆ·µ¥Ò³] SWL3108 Datasheet 201301V1.0.pdf
[Ó²¼þ°²×°ÊÖ²á] SWL3108ÎÞÏß¹¤ÒµÒÔÌ«Íø½»»»»úÓ²¼þ°²×°ÊÖ²á_V1.0.pdf
