²úÆ·¼ò½é
KOM200Ìṩ¹âµçת»»ÎªµÍÀûÂÊÐźŵÄRS232,RS485ºÍRS422.ÕâÊÇרΪÑÏ¿áµÄ¹¤Òµ»·¾³.
¹Ø¼üÌØÐÔ
1. 1¸ö¹âÏ˽ӿÚ,RS232/RS422/RS485ÈýÖÖ´®ÐнӿÚ
2. ȫ͸Ã÷ͨÐÅ,Óû§ÎÞÐèÈκε÷ÊÔ,¼´²å¼´ÓÃ
3. ´®¿Ú¶Ë¾ßÓÐ15KV ESD±£»¤µç·
4. ´®¿ÚÖ§³Ö´øµçÈȲå°Î
5. µçÔ´ÊäÈëµÈ¼¶¶àÖÖÑ¡Ôñ
6. ·ûºÏ¹¤ÒµËļ¶µç´Å¼æÈÝÐÔÒªÇó
7. IP30·À»¤µÈ¼¶
8. CE,FCCÈÏÖ¤
ÐÔÄܲÎÊý
±ê×¼ |
RS232,RS422,RS485 |
½Ó¿Ú |
¹â¿Ú:1¸ö¹â¿Ú,µ¥/¶àÄ£,SC/ST/FCÈÎÑ¡
´®ÐпÚ:3¸ö´®¿Ú,8о3.81mm¼ä¾à¶Ë×Ó,RS485½Ó¿Ú¿É½Ó32¡«128¸ö½ÚµçÉ豸 |
ָʾµÆ |
Ç°Ãæ°åָʾµÆ
ÔËÐÐָʾµÆ:Run
½Ó¿ÚָʾµÆ:Link/ACT(¹â¿Ú),Data(1,2) |
´«Êä¾àÀë |
´®¿ÚÏß:RS232:15m,RS422/RS485:1200m
¶àÄ£¹âÏË:1310nm,5km(°ÙÕ×)
µ¥Ä£¹âÏË:1310nm,40km(°ÙÕ×) |
µçÔ´ |
ÊäÈëµçѹ:24DC(9-36VDC),48DC(36-72VDC),110DC(72-144VDC),
220AC/DC(85-264VAC/120-300VDC)
½ÓÈë¶Ë×Ó:3о3.81mm¼ä¾à²åÈëʽ¶Ë×Ó
¹¦ÂÊ:<3W
¹ýÔر£»¤:Ö§³Ö
·´½Ó±£»¤:Ö§³Ö |
»úе½á¹¹ |
Íâ¿Ç:½ðÊô²ÄÖÊ,ÎÞ·çÉÈ
·À»¤µÈ¼¶:IP30
³ß´ç:36mm¡Á100mm¡Á75mm(W¡ÁH¡ÁD)
ÖØÁ¿:0.3Kg
°²×°·½Ê½:DIN¿¨¹ìʽ»ò±Ú¹Òʽ |
»·¾³ |
¹¤×÷ζÈ:-40¡æ¡«+85¡æ
´¢´æζÈ:-40¡æ¡«+85¡æ
Ïà¶Ôʪ¶È:5¡«95%ÎÞÄý¶ |
Öʱ£ |
MTBF:1162867h
±£ÐÞÆÚ:5Äê |
ÈÏÖ¤ |
CE,FCC |
ÐÐÒµ±ê×¼ |
EMI:
FCC CFR47 Part 15,EN55022/CISPR22,Class A
EMS:
IEC61000-4-2(ESD) ¡À8kV(contact),¡À15kV(air)
IEC61000-4-3(RS) 10V/m(80MHz¡«1GHz)
IEC61000-4-4(EFT) Power Port:¡À4kV;Data Port:¡À2kV
IEC61000-4-5(Surge) Power Port:¡À2kV/DM,¡À4kV/CM;Data Port:¡À2kV
IEC61000-4-6(CS) 3V(10kHz¡«150kHz);10V(150kHz¡«80MHz)
IEC61000-4-8(¹¤Æµ´Å³¡) 100A/m(cont.),1000A/m(1s¡«3s)
IEC61000-4-10(×èÄáÕñµ´) 30A/m
IEC61000-4-12(Õñµ´²¨) 2.5kV/CM,1kV/DM
IEC61000-4-16(¹²Ä£´«µ¼) 30V(cont.),300V(1s)
»úе:
IEC60068-2-6(Õñ¶¯) IEC60068-2-27(³å»÷) IEC60068-2-32(×ÔÓɵøÂä)
¹¤Òµ:
IEC61000-6-2
Ìú·:
EN50155,EN50121-4 |
¶©»õÐÅÏ¢
ÍƼöÐͺŠ|
¹â¿Ú |
RS232´®¿Ú |
RS422´®¿Ú |
RS485´®¿Ú |
KOM200-1S/M-232/422 |
1(FC/ST/SC) |
1 |
1 |
KOM200-1S/M-485/232 |
1(FC/ST/SC) |
2 |
1 |
KOM200-1S/M-485/232A |
1(FC/ST/SC) |
2 |
1(µÚ2,3´®¿Ú¸´ÓÃ) |
KOM200A-1S/M-232 |
1(FC/ST/SC) |
1 |
¹â¿ÚÑ¡ÐͲÎÊý |
SC |
SC½ÓÍ· |
ST |
ST½ÓÍ· |
FC |
FC½ÓÍ· |
1310-5 |
¶àÄ£,1310nm,5km |
1310-40 |
µ¥Ä£,1310nm,40km |
µçÔ´ |
ÃèÊö |
24DC |
9-36VDC,µ¥Â·ÊäÈë |
48DC |
36-72VDC,µ¥Â·ÊäÈë |
110DC |
72-144VDC,µ¥Â·ÊäÈë |
220AC/DC |
85-264VAC/120-300VDC,µ¥Â·ÊäÈë |
²úÆ·×ÊÁÏ
[²úÆ·µ¥Ò³] KOM200 Datasheet 201301V1.0.pdf
[Ó²¼þ°²×°ÊÖ²á] KOM200ϵÁÐÊý¾Ý¹âÏËÊÕ·¢Æ÷Ó²¼þ°²×°ÊÖ²á_V4.1.pdf
