²úÆ·ÓÅÊÆ
Ê׿îCortex-A8ÓÊÆ±¿×AM335XºËÐÄÄ£¿é£¬¾«Éè¼Æ£¬µÍ³É±¾£¬¿ÉÐÅÀµ
¡ô 720M/1G¸ßËÙCortex-A8ºËÐÄ£»
¡ô µ¥¿Å256M/512M×Ö½ÚDDR3 SDRAM£¬³É±¾¸üµÍÁ®£»
¡ô ´óÈÝÁ¿°åÔØµç×ÓÅÌ£¬¸ü¶àÓû§¿Õ¼ä£»
¡ô ¾«ÖÂÓÊÆ±¿×Éè¼Æ,³¬Ð¡³ß´ç42mm*52mm£¬ÅúÁ¿Ê¹Óóɱ¾¸üµÍ£»
¡ô Ö§³Ö2·10M/100M/1000MÒÔÌ«Íø£»
¡ô ºËÐİå¶ÀÁ¢RTC£¬ ×ßʱ¾«×¼£»
¡ô ×îÓÅÐãµÄÏÔʾÐÔÄÜ£¬·Ö±æÂʸߴï1366*768£»
¡ô CPUÄÚÖÃ6·RS232´®¿Ú£¨ÆäÖÐ1·232ΪCOM_DBU£©£»
¡ô ÍⲿÀ©Õ¹2*IIC,1*SPI½Ó¿Ú£»
¡ô ×ÜÏßÈ«²¿Òý³ö£¬¿É·½±ãÀ©Õ¹FPGA£¬DSPµÈÍⲿÉ豸£»
¡ô CPUÄÚÖÃ˫·CAN BUS£¬ÊʺÏÓÚÏÖ³¡¹¤Òµ¿ØÖÆ£»
¡ô Ö§³ÖSD¿¨½Ó¿Ú£¬´óÈÝÁ¿´æ´¢£»
¡ô ¸ßËÙUSB 2.0 Device½Ó¿Ú£»
¡ô ¸ßËÙUSB 2.0 Host½Ó¿Ú£»
¡ô רҵWINCE 6.0¡¢LINUX 3.2¡¢ANDROID²Ù×÷ϵͳ֧³Ö£¬Ö§³ÖSD¿¨³õʼ»¯ÏµÍ³£¬¿ÉUSBÉý¼¶ÏµÍ³£»
¡ô ºËÐİå¸ß¼¯³É¶È£¬¿ÉÒÔÖ±½ÓÓ¦Ó㬿ɸù¾Ý¿Í»§¶¨ÖÆÖ÷°å£»
¡ô ÍÆ¼öÓ¦ÓãºÒ½ÁÆ¡¢ÒÇ±í¡¢ÏÔʾÖÕ¶Ë¡¢³äµç×®£»
¹¦ÄÜ
FUNCTION
COM-335X
Kernel
CPU
TI AM3352/AM3354£¬CORTEX-A8£¬720MHz
System RAM
256MB DDR3 SDRAM£¨up to 512M DDR3 £©
Flash
128MB (up to 512MB)
Graphic Chip
24-bit LCD controller by CPU
Rtc
YES
Watchdog Timer
YES
Power Management
NO
Reset
H/W reset & S/W reset (by register setting)
I/O (All interfaces with industrial TTL 3.3V Level)
UART
TTL level x6
Ethernet LAN
10/100/1000Mbps
USB 2.0 Client
1(High speed)
USB Host
1(High speed)
SD/MMC
1(4-wire)
Touch
1(4-wire resistive type)
System bus
YES £¨FPGA ,DSP£©
IIC interface
2
SPI interface
1
GPIO
IIS
1
Multimedia
Graphic Chip
CPU internal 24-bit LCD controller
Resolution
Max 1366×768¡¢24bits (320 x 240 ~ 1366×768 as optional)
LCD interface
16-bit TTL
Power
Power input
5.0 VDC (+-5%)
Power Consumption
TBD
Mechanical & Environment
Size
42MM*52MM*3.2MM
Operating Temperature
-20 ~ 70° C (-40 ~85° C by project base)
Operating Humidity
5 ~ 95 % relative humidity, non-condensing
Other
RoHS
YES
Certifications
CE/FCC Class A
Software Support
Embedded Linux 3.2 (WCE6.0 and ANDROID by project support)
ϵͳ¿òͼ
¶©¹ºÐÅÏ¢
Part No.
CPU
RAM
Flash Memory
UART
LAN
USB Host
USB OTG
LCD
video decoder
Touch
SD
IIC
SPI
size
Power Input
Operating temp.
Com-335X-B1
AM3352
256M
128M
6
1
1
1
16-bit
yes
1
2
1
42*52mm
5.0v
-20-70
Com-335X-B2
AM3354
256M
128m
6
1
1
1
16-bit
yes
yes
1
1
1
42*52mm
5.0v
-20-70
