Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 3.7gËܽºÊý×Ö¶æ»ú
²úÆ·Ãû³Æ£º 3.7gËܽºÊý×Ö¶æ»ú
ÐÍ ºÅ£º DS-S001
No Item ÏîÄ¿ Specification ¹æ¸ñ   Remarks ±¸×¢
1 Operating Voltage ¹¤×÷µçѹ·¶Î§ 3.7~4.2V DC
2 Standby Current ¾²Ì¬µçÁ÷ ≤20mA
3 No Load Current* ¿ÕÔØµçÁ÷ ≤50mA at3.7V(REF.²Î¿¼Öµ)
≤60mA at4.2V(STD.±ê×¼Öµ)
4 No Load Speed* ¿ÕÔØËÙ¶È ≤0.12sec/60° at3.7V(REF.²Î¿¼Öµ)
≤0.10sec/60° at4.2V(STD.±ê×¼Öµ)
5 Rated Torque ¶î¶¨Å¤¾Ø 57gf.cm at3.7V(REF.²Î¿¼Öµ)
62gf.cm at4.2V(STD.±ê×¼Öµ)
6 Stall Current ¶ÂתµçÁ÷ ≤330mA at3.7V (REF.²Î¿¼Öµ)
≤380mA at4.2V (STD.±ê×¼Öµ)
7 Stall Torque* ¶ÂתŤ¾Ø ≥0.4kgf.cm at3.7V (REF.²Î¿¼Öµ) ŤÁ¦°õ²âÊÔ
≥0.45kgf.cm at4.2V (STD.±ê×¼Öµ)
8 Rotating Direction* Ðýת·½Ïò CCW (1000→2000μs)ÄæÊ±Õë ¸©ÊÓÊä³öÖá¶Ë·½Ïò
9 Pulse Width Range Ðźſí¶È·¶Î§ 700~2300μs
10 Neutral Position ÖÐλ 1500μs
11 Operating Travel Angle  ¿É²Ù×÷½Ç¶È 145°±10°£¨700~2300μs£©
12 Mechanical Limit Angle»úе¼«ÏÞ½Ç¶È 360°
13 Angle deviation ½Ç¶È¾«¶È ≤ 2° ¼´»ØÖвî
14 Back Lash* Ðéλ ≤ 2°
15 Dead Band Width ËÀÇø¿í¶È ≤ 4 μs ×îСÆô¶¯Ðźſí¶È
16 Operating Temperature Range¹¤×÷»·¾³ -10¡æ~+50¡æ£» ≤90%RH
17 Storage Temperature Range ´¢´æÎÂ¶È -20¡æ~+60¡æ£» ≤90%RH
18 Weight ÖØÁ¿ 4.3± 0.2g
19 Case Material Íâ¿Ç²ÄÖÊ ABS
20 Gear Set Material ³ÝÂÖ²ÄÖÊ Plastic gear  Ëܽº³Ý
21 Motor Type Âí´ïÀàÐÍ Coreless motor  ¿ÕÐı­Âí´ï
22 Angle Sansor ½Ç¶È´«¸ÐÆ÷ Type ÀàÐÍ   Carbon-Film Potentiometer
Angle ½Ç¶È   280°
Life ÊÙÃü 500,000Cycles Min
23 Connector and Cable Á¬½ÓÆ÷ºÍµçÀ Type ÀàÐÍ   JR(3PIN/B.R.O)
Material ²ÄÖÊ   PVC
Length Ïß³¤¶È   150±5mm (¿ÇÍâÏß³¤²»º¬²åÍ·)
Pin Assignment
Òý½Å¶¨Òå
1 Brown GND
2 Red Vcc
3 Orange Signal
24 Horn Type Ò¡±ÛÀàÐÍ 28T/∅3.90mm
25 Rocker Arm Screw Ò¡±ÛÂÝË¿ ¼ûÅä¼þ
26 Communication Interface ͨÐÅ·½Ê½ PWM£¨DIgital£©
27 Current Protection µç×Ó±£»¤ N/A
28 Clutch Protection ÀëºÏ±£»¤ N/A
¹«Ë¾Ãû³Æ£º ¹ã¶«µÂêÉÖÇÄܿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 0769 82252765 / ºú±ÌÓñ
ÊÖ»ú£º 13612767560
µØ Ö·£º ¶«Ý¸ÊÐÌÁÏÃÕòÇåºþÍ·Çåºþ·112ºÅµÂêɼ¯ÍÅ
ÓÊ ±à£º 523710
Ö÷ Ò³£º https://www.dspower.net/
  • 9gÀëºÏËܽº³ÝÊý×Ö¶æ»ú
  • 9gËܽº³ÝÊý×Ö¶æ»ú
  • 9g½ðÊô³ÝÊý×Ö¶æ»ú
  • 5g½ðÊô³ÝÊý×Ö¶æ»ú
  • 5gËܽº³ÝÊý×Ö¶æ»ú DSpower
  • 2g½ðÊô³Ý΢ÐͶæ»ú DS-M005B
  • 2gËܽº³Ý΢ÐͶæ»ú DS-M005
  • 4.3gËܽºÊý×Ö¶æ»ú
  • 3.7gËܽºÊý×Ö¶æ»ú
