Öлª¹¤¿ØÍø ¡ú ¹¤¿Ø²úÆ· ¡ú 4.3gËܽºÊý×Ö¶æ»ú
²úÆ·Ãû³Æ£º 4.3gËܽºÊý×Ö¶æ»ú
ÐÍ ºÅ£º DS-S002
No Item ÏîÄ¿ Specification ¹æ¸ñ   Remarks ±¸×¢
1 Operating Voltage ¹¤×÷µçѹ·¶Î§ 3.7-4.2V DC
2 Standby Current ¾²Ì¬µçÁ÷ ≤15mA at 4.2V (STD.±ê×¼Öµ)
3 No Load Current* ¿ÕÔØµçÁ÷ ≤75mA at 3.7V (STD.²Î¿¼Öµ)
≤80mA at 4.2V (STD.±ê×¼Öµ)
4 No Load Speed* ¿ÕÔØËÙ¶È 0.12sec/60° at 3.7V (STD.²Î¿¼Öµ)
0.10sec/60° at 4.2V (STD.±ê×¼Öµ)
5 Rated Torque ¶î¶¨Å¤¾Ø 0.1kgf·cm at 3.7V (STD.²Î¿¼Öµ)
0.14kgf·cm at 4.2V (STD.±ê×¼Öµ)
6 Stall Current ¶ÂתµçÁ÷ ≤500mA at 3.7V (STD.²Î¿¼Öµ)
≤550mA at 4.2V (STD.±ê×¼Öµ)
7 Stall Torque* ¶ÂתŤ¾Ø 0.4kgf·cm  at 3.7V (STD.²Î¿¼Öµ) ŤÁ¦°õ²âÊÔ
0.55kgf·cm  at 4.2V (STD.±ê×¼Öµ)
8 Rotating Direction* Ðýת·½Ïò CCW£¨1000→2000μs£©ÄæÊ±Õë ¸©ÊÓÊä³öÖá¶Ë·½Ïò
9 Pulse Width Range Ðźſí¶È·¶Î§ 500~2500μs
10 Neutral Position ÖÐλ 1500μs
11 Operating Travel Angle  ²Ù×÷½Ç¶È 90°±10°(1000~2000μs£©
12 Mechanical Limit Angle»úе¼«ÏÞ½Ç¶È 360°
13 Angle deviation ½Ç¶È¾«¶È ≤ 1° ¼´»ØÖвî
14 L&R Angle deviation ×óÓÒÁ½±ß½Ç¶È¾«¶È ≤ 5° ¼´±ß½Ç²î
15 Back Lash* Ðéλ ≤ 1°
16 Dead Band Width ËÀÇø¿í¶È  4 μs ×îСÆô¶¯Ðźſí¶È
17 Operating Temperature Range¹¤×÷»·¾³ -10¡æ~+50¡æ£» ≤90%RH
18 Storage Temperature Range ´¢´æÎÂ¶È -20¡æ~+60¡æ£» ≤90%RH
19 Weight ÖØÁ¿ 4.3± 0.2g
20 Case Material Íâ¿Ç²ÄÖÊ ABS
21 Gear Set Material ³ÝÂÖ²ÄÖÊ Plastic gear  Ëܽº³Ý
22 Motor Type Âí´ïÀàÐÍ Coreless  motor  ¿ÕÐı­Âí´ï
23 Angle Sansor ½Ç¶È´«¸ÐÆ÷ Type ÀàÐÍ   Carbon Film Potenntiometer ̼ĤµçλÆ÷
Angle ½Ç¶È   280
Life ÊÙÃü 500,000 Cycles (Min.)
24 Connector and Cable Á¬½ÓÆ÷ºÍµçÀ Type ÀàÐÍ   JR
Material ²ÄÖÊ   PVC
Length Ïß³¤¶È   145±5mm£¨Íâ¶²»º¬²åÍ·£©
Pin Assignment
Òý½Å¶¨Òå
1 Brown ר GND
2 Red ºì Vcc
3 Orange ³È Signal / PWM
25 Horn Type Ò¡±ÛÀàÐÍ 28T/Φ3.90mm
26 Rocker Arm Screw Ò¡±ÛÂÝË¿ PWA§¶1.7X3.5ñ§¶4.0mm¶ÆÄø, ¼ûÅä¼þ
27 Communication Interface ͨÐÅ·½Ê½ PWM
28 Current Protection µç×Ó±£»¤ ÎÞ
29 Clutch Protection ÀëºÏ±£»¤ ÎÞ
30 Noise Level ÔëÒô±ê×¼ ≤50dBA (µÂêɲâÊÔ¼ÜF3 AU3µµ)  ¿ÕÔØ²âÊÔ,ÓëÔëÒôÒǾàÀë30cm£¬»·¾³25dBAÒÔϵÄ×î´óÔëÒôÖµ
31 Operating life time ¶î¶¨¸ºÔØÊÙÃü ³ÖÐøÔËת²âÊÔÊÙÃü≥120h ¶î¶¨¸ºÔØÏÂ,ÒԶËÙ¶ÈÏÂ˳/Äæ×ª¶¯¸÷100¶È
¹«Ë¾Ãû³Æ£º ¹ã¶«µÂêÉÖÇÄܿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 0769 82252765 / ºú±ÌÓñ
ÊÖ»ú£º 13612767560
µØ Ö·£º ¶«Ý¸ÊÐÌÁÏÃÕòÇåºþÍ·Çåºþ·112ºÅµÂêɼ¯ÍÅ
ÓÊ ±à£º 523710
Ö÷ Ò³£º https://www.dspower.net/
  • 9gÀëºÏËܽº³ÝÊý×Ö¶æ»ú
  • 9gËܽº³ÝÊý×Ö¶æ»ú
  • 9g½ðÊô³ÝÊý×Ö¶æ»ú
  • 5g½ðÊô³ÝÊý×Ö¶æ»ú
  • 5gËܽº³ÝÊý×Ö¶æ»ú DSpower
  • 2g½ðÊô³Ý΢ÐͶæ»ú DS-M005B
  • 2gËܽº³Ý΢ÐͶæ»ú DS-M005
  • 4.3gËܽºÊý×Ö¶æ»ú
  • 3.7gËܽºÊý×Ö¶æ»ú
