WINCE下如何添加CPL应用程序
深圳市盈鹏飞科技有限公司
2 创建Hello World应用工程
       打开wince OS Designe工程,点击文件(F) -> 新建(N)-> Subproject添加子工程,工程类型设置为WCE Application,Subproject name命名为Helloworld
       点击下一步(N),选择A typical “Hello world” application,然后点击完成(F)。
3 创建HelloCPL控制面板应用工程
点击文件(F) -> 新建(N)-> Subproject添加子工程,工程类型设置为WCE Dynamic-Link Library,工程名为HelloCPL。
       然后点击下一步(N),在Auto-generated subproject files页面中选择A Dll that exports some symbols。
       这是工程面板中看起来如下:
       双击HelloCPL工程中Source files下的HelloCPL.cpp,将其中的内容替换如下:
// HelloCPL.cpp : Defines the entry point for the DLL
#include "stdafx.h"    // Auto-generated by wizard.
#include "HelloCPL.h"  // Auto-generated by wizard.
#include "resource.h"  // Auto-generated at compile time
#include <tchar.h>     // General text functions.
#include "cpl.h"       // Control Panel support.
#define DEBUG
// Returns the number of characters in an expression.
#define lengthof(exp) ((sizeof((exp)))/sizeof((*(exp))))
HMODULE g_hModule = NULL;   // Handle to the DLL.
// Main entry point for the Control Panel DLL.
extern "C" BOOL APIENTRY DllMain( HANDLE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved )
  switch (ul_reason_for_call)
    case DLL_PROCESS_ATTACH:
      g_hModule = (HMODULE) hModule;
    case DLL_THREAD_ATTACH:
    case DLL_THREAD_DETACH:
    case DLL_PROCESS_DETACH:
       break;
    return TRUE;
// The entry point to the Control Panel application.
extern "C" HelloCPL_API LONG CALLBACK CPlApplet(HWND hwndCPL,
                  UINT message, LPARAM lParam1, LPARAM lParam2)
  switch (message)
    case CPL_INIT:
      // Perform global initializations, especially memory
      // allocations, here.
      // Return 1 for success or 0 for failure.
      // Control Panel does not load if failure is returned.
      return 1;
    case CPL_GETCOUNT:
      // The number of actions supported by this Control
      // Panel application.
      return 1;
    case CPL_NEWINQUIRE:
      // This message is sent once for each dialog box, as
      // determined by the value returned from CPL_GETCOUNT.
      // lParam1 is the 0-based index of the dialog box.
      // lParam2 is a pointer to the NEWCPLINFO structure.
      ASSERT(0 == lParam1);
      ASSERT(lParam2);
      NEWCPLINFO* lpNewCplInfo = (NEWCPLINFO *) lParam2;
      if (lpNewCplInfo)
         lpNewCplInfo->dwSize = sizeof(NEWCPLINFO);
         lpNewCplInfo->dwFlags = 0;
         lpNewCplInfo->dwHelpContext = 0;
         lpNewCplInfo->lData = IDI_HELLOWORLD;
         // The large icon for this application. Do not free this
         // HICON; it is freed by the Control Panel infrastructure.
         lpNewCplInfo->hIcon = LoadIcon(g_hModule,
                                  MAKEINTRESOURCE(IDI_HELLOWORLD));
          LoadString(g_hModule, IDS_APP_TITLE, lpNewCplInfo->szName,
                     lengthof(lpNewCplInfo->szName));
          LoadString(g_hModule, IDS_HELLO, lpNewCplInfo->szInfo,
                     lengthof(lpNewCplInfo->szInfo));
//        LoadString(g_hModule, IDC_HelloWorld, lpNewCplInfo->szInfo,
//                     lengthof(lpNewCplInfo->szInfo));
          _tcscpy(lpNewCplInfo->szHelpFile, _T(""));
          return 0;
      return 1;  // Nonzero value means CPlApplet failed.
    case CPL_DBLCLK:
      // The user has double-clicked the icon for the
      // dialog box in lParam1 (zero-based).
      PROCESS_INFORMATION pi = {0};
      if (CreateProcess(_T("\\Windows\\HelloWorld.exe"), NULL, NULL,
                             NULL, FALSE, 0, NULL, NULL, NULL, &pi))
        CloseHandle(pi.hThread);
        CloseHandle(pi.hProcess);
        return 0;
      return 1;     // CPlApplet failed.
    case CPL_STOP:
      // Called once for each dialog box. Used for cleanup.
    case CPL_EXIT:
      // Called only once for the application. Used for cleanup.
    default:
      return 0;
  }  // CPlApplet
      &nbs, p;  本工程用到1个图标资源文件IDI_HELLOWORLD,2个字符串资源IDS_APP_TITLE和IDS_HELLO。
4 向控制面板添加资源文件
       A、右键点击HelloCPL -> Source Files,选择Add -> New Item,见下图:
       点击Add后,双击HelloCPL->source files->HelloCPL.rc,见下图
B、右键点击上图中的HelloCPL.rc,选择Add Resource,弹出下面的对话框,添加ICON
       并修改Icon的ID为IDI_HELLOWORLD.
       C、重复步骤B,添加String Table,并修改String Table中的内容如下:
5编译控制面板应用程序
A、右键点击HelloCPL工程,选择属性,弹出如下窗口
B、选择General标签页,在Custom Variable栏点击 按钮打开Custom Variable对话框。
C、点击NEW打开Environment Variable窗口,Variable Name输入CPL,Variable Value输入1。点击OK关闭Environment Variable,再点击OK关闭Custom Variables。这样做的目的是强制工程输出.cpl文件,而不是.dll文件。
D、点击C/C++标签页,在Include Directories添加$(_PROJECTROOT)\cesysgen\oak\inc。
       确认Additional MacroDefinitions设置为$(CDEFINES) -DHelloCPL_EXPORTS。
       修改DLL Entry Point为Dllmain。
      点击OK关闭属性设置对话框。
E、修改HelloCPL.bib,替换为如下内容
                           MODULES
                           HelloCPL.cpl $(_FLATRELEASEDIR)\HelloCPL.cpl           NK
F、右键点击HelloCPL,然后Build即可生成对应的内核,烧录到系统启动后即可在控制面板中看到Hello Control Panel的图标,双击后即可运行Helloworld.exe
公司名称: 深圳市盈鹏飞科技有限公司
联 系 人: 李希岗
电  话: 0086-13602511395
传  真: 0755-82523175,82523176-819
地  址: 深圳市福田区福明路40号,雷圳大厦12A06
邮  编: 518033
该厂商相关技术文摘:
Wince sqlite3移植
EAC-C925开机画面实现手册
英贝德推出单板机产品软件升级解决方案(WinCE篇)
EP9315电路设计要点
Linux下创建和使用RamDisk的技巧
英贝德科技移植PPP大揭秘:PPP拨号在ARM2410平台上的移植
AT91SAM9263在人机界面方面的应用
详解WinCE下USB Host驱动开发(2)
详解WinCE下USB Host驱动开发(1)
WinCE驱动中设备中断的处理
Linux内核学习之BogoMIPS值的计算
更多文摘...
立即发送询问信息在线联系该技术文摘厂商:
