3-Jaws indexing spacers 三爪、分割工具头 <BR> A.T.C.system 加工中心机刀库 <BR> Aluminum continuous melting & holding furnaces 连续溶解保温炉 <BR> Balancing equipment 平衡设备 <BR> Bayonet 卡口 <BR> Bearing fittings 轴承配件 <BR> Bearing processing equipment 轴承加工机 <BR> Bearings 轴承 <BR> Belt drive 带传动 <BR> Bending machines 弯曲机 <BR> Blades 刀片 <BR> Blades,saw 锯片 <BR> Bolts,screws & nuts 螺栓,螺帽及螺丝 <BR> Boring heads 搪孔头 <BR> Boring machines 镗床 <BR> Cable making tools 造线机 <BR> Casting,aluminium 铸铝 <BR> Casting,copper 铸铜 <BR> Casting,gray iron 铸灰口铁 <BR> Casting,malleable iron 可锻铸铁 <BR> Casting,other 其他铸造 <BR> Casting,steel 铸钢 <BR> Chain drive 链传动 <BR> Chain making tools 造链机 <BR> Chamfer machines 倒角机 <BR> Chucks 夹盘 <BR> Clamping/holding systems 夹具/支持系统 <BR> CNC bending presses 电脑数控弯折机 <BR> CNC boring machines 电脑数控镗床 <BR> CNC drilling machines 电脑数控钻床 <BR> CNC EDM wire-cutting machines 电脑数控电火花线切削机 <BR> CNC electric discharge machines 电脑数控电火花机 <BR> CNC engraving machines 电脑数控雕刻机 <BR> CNC grinding machines 电脑数控磨床 <BR> CNC lathes 电脑数控车床 <BR> CNC machine tool fittings 电脑数控机床配件 <BR> CNC milling machines 电脑数控铣床 <BR> CNC shearing machines 电脑数控剪切机 <BR> CNC toolings CNC刀杆 <BR> CNC wire-cutting machines 电脑数控线切削机 <BR> Conveying chains 输送链 <BR> Coolers 冷却机 <BR> Coupling 联轴器 <BR> Crimping tools 卷边工具 <BR> Cutters 刀具 <BR> Cutting-off machines 切断机 <BR> Diamond cutters 钻石刀具 <BR> Dicing saws 晶圆切割机 <BR> Die casting dies 压铸冲模 <BR> Die casting machines 压铸机 <BR> Dies-progressive 连续冲模 <BR> Disposable toolholder bits 舍弃式刀头 <BR> Drawing machines 拔丝机 <BR> Drilling machines 钻床 <BR> Drilling machines bench 钻床工作台 <BR> Drilling machines,high-speed 高速钻床 <BR> Drilling machines,multi-spindle 多轴钻床 <BR> Drilling machines,radial 摇臂钻床 <BR> Drilling machines,vertical 立式钻床 <BR> drills 钻头 <BR> Electric discharge machines(EDM) 电火花机 <BR> Electric power tools 电动刀具 <BR> Engraving machines 雕刻机 <BR> Engraving machines,laser 激光雕刻机 <BR> Etching machines 蚀刻机 <BR> Finishing machines 修整机 <BR> Fixture 夹具 <BR> Forging dies 锻模 <BR> Forging,aluminium 锻铝 <BR> Forging,cold 冷锻 <BR> Forging,copper 铜锻 <BR> Forging,other 其他锻造 <BR> Forging,steel 钢锻 <BR> Foundry equipment 铸造设备 <BR> Gear cutting machines 齿轮切削机 <BR> Gears 齿轮 <BR> Gravity casting machines 重力铸造机 <BR> Grinder bench 磨床工作台 <BR> Grinders,thread 螺纹磨床 <BR> Grinders,tools & cutters 工具磨床 <BR> Grinders,ultrasonic 超声波打磨机 <BR> Grinding machines 磨床 <BR> Grinding machines,centerless 无心磨床 <BR> Grinding machines,cylindrical 外圆磨床 <BR> Grinding machines,universal 万能磨床 <BR> Grinding tools 磨削工具 <BR> Grinding wheels 磨轮 <BR> Hand tools 手工具 <BR> Hard/soft and free expansion sheet making plant 硬(软)板(片)材及自由发泡板机组 <BR> Heat preserving furnaces 保温炉 <BR> Heating treatment funaces 熔热处理炉 <BR> Honing machines 搪磨机 <BR> Hydraulic components 液压元件 <BR> Hydraulic power tools 液压工具 <BR> Hydraulic power units 液压动力元件 <BR> Hydraulic rotary cylinders 液压回转缸 <BR> Jigs 钻模 <BR> Lapping machines 精研机 <BR> Lapping machines,centerless 无心精研机 <BR> Laser cutting 激光切割 <BR> Laser cutting for SMT stensil 激光钢板切割机 <BR> Lathe bench 车床工作台 <BR> Lathes,automatic 自动车床 <BR> Lathes,heavy-duty 重型车床 <BR> Lathes,high-speed 高速车床 <BR> Lathes,turret 六角车床 <BR> Lathes,vertical 立式车床 <BR> Lubricants 润滑液 <BR> Lubrication Systems 润滑系统 <BR> Lubricators 注油机 <BR> Machining centers,general 通用加工中心 <BR> Machining centers,horizontal 卧式加工中心 <BR> Machining centers,horizontal & vertical 卧式及立式加工中心 <BR> Machining centers,vertical 立式加工中心 <BR> Machining centers,vertical double-column type 立式双柱加工中心 <BR> Magnetic tools 磁性工具 <BR> Manifolds 集合管 <BR> Milling heads 铣头 <BR> Milling machines 铣床 <BR> Milling machines,bed type 床身式铣床 <BR> Milling machines,duplicating 仿形铣床 <BR> Milling machines,horizontal 卧式铣床 <BR> Milling machines,turret vertical 六角立式铣床 <BR> Milling machines,universal 万能铣床 <BR> Milling machines,vertical 立式铣床 <BR> Milling machines,vertical & horizontal 立式及卧式铣床 <BR> Mold & die components 模具单元 <BR> Mold changing systems 换模系统 <BR> Mold core 模芯 <BR> Mold heaters/chillers 模具加热器/冷却器 <BR> Mold polishing/texturing 模具打磨/磨纹 <BR> Mold repair 模具维修 <BR> Molds 模具 <BR> Nail making machines 造钉机 <BR> Oil coolers 油冷却器 <BR> Overflow cutting machines for aluminium wheels 铝轮冒口切断机 <BR> P type PVC waterproof rolled sheet making plant P型PVC高分子防水 <BR> PCB fine piecing systems 印刷电器板油压冲孔脱料系统 <BR> Pipe & tube making machines 管筒制造机 <BR> Planing machines 刨床 <BR> Planing machines vertical 立式刨床 <BR> Pneumatic hydraulic clamps 气油压虎钳 <BR> Pneumatic power tools 气动工具 <BR> Powder metallurgic forming machines 粉末冶金成型机 <BR> Presses,cold forging 冷锻冲压机 <BR> presses,crank 曲柄压力机 <BR> Presses,eccentric 离心压力机 <BR> Presses,forging 锻压机 <BR> Presses,hydraulic 液压冲床 <BR> Presses,knuckle joint 肘杆式压力机 <BR> Presses,pneumatic 气动冲床 <BR> Presses,servo 伺服冲床 <BR> Presses,transfer 自动压力机 <BR> Pressing dies 压模 <BR> Punch formers 冲子研磨器 <BR> Quick die change systems 速换模系统 <BR> Quick mold change systems 快速换模系统 <BR> Reverberatory furnaces 反射炉 <BR> Rollers 滚筒 <BR> Rolling machines 辗压机 <BR> Rotary tables 转台 <BR> Sawing machines 锯床 <BR> Sawing machines,band 带锯床 <BR> Saws,band 带锯 <BR> Saws,hack 弓锯 <BR> Saws,horizontal band 卧式带锯 <BR> Saws,vertical band 立式带锯 <BR> shafts 轴 <BR> Shapers 牛头刨床 <BR> Shearing machines 剪切机 <BR> Sheet metal forming machines 金属板成型机 <BR> Sheet metal working machines 金属板加工机 <BR> Slotting machines 插床 <BR> spindles 主轴 <BR> Stamping parts 冲压机 <BR> Straightening machines 矫直机 <BR> Switches & buttons 开关及按钮 <BR> Tapping machines 攻螺丝机 <BR> Transmitted chains 传动链 <BR> Tube bending machines 弯管机 <BR> Vertical hydraulic broaching machine 立式油压拉床 <BR> Vises 虎钳 <BR> Vises,tool-maker 精密平口钳 <BR> Wheel dressers 砂轮修整器 <BR> Woven-Cutting machines 织麦激光切割机 <BR> Wrenches 扳手 </P><P> (2): 按中文拼音字母排序<BR> <BR> 铝轮冒口切断机 Overflow cutting machines for aluminium wheels <BR> 离心压力机 Presses,eccentric <BR> 六角立式铣床 Milling machines,turret vertical <BR> 六角车床 Lathes,turret <BR> 螺栓,螺帽及螺丝 Bolts,screws & nuts <BR> 螺纹磨床 Grinders,thread <BR> 冷却机 Coolers <BR> 冷锻 Forging,cold <BR> 冷锻冲压机 Presses,cold forging <BR> 立式双柱加工中心 Machining centers,vertical double-column type <BR> 立式铣床 Milling machines,vertical <BR> 立式油压拉床 Vertical hydraulic broaching machine <BR> 立式刨床 Planing machines vertical <BR> 立式车床 Lathes,vertical <BR> 立式带锯 Saws,vertical band <BR> 立式加工中心 Machining centers,vertical <BR> 立式及卧式铣床 Milling machines,vertical & horizontal <BR> 立式钻床 Drilling machines,vertical <BR> 联轴器 Coupling <BR> 连续溶解保温炉 Aluminum continuous melting & holding furnaces <BR> 连续冲模 Dies-progressive <BR> 链传动 Chain drive <BR> 切断机 Cutting-off machines <BR> CNC刀杆 CNC toolings <BR> 曲柄压力机 presses,crank <BR> 修整机 Finishing machines <BR> 舍弃式刀头 Disposable toolholder bits <BR> 润滑系统 Lubrication Systems <BR> 润滑液 Lubricants <BR> 熔热处理炉 Heating treatment funaces <BR> 三爪、分割工具头 3-Jaws indexing spacers <BR> 伺服冲床 Presses,servo <BR> 输送链 Conveying chains <BR> 手工具 Hand tools <BR> 砂轮修整器 Wheel dressers <BR> 蚀刻机 Etching machines <BR> 外圆磨床 Grinding machines,cylindrical <BR> 搪磨机 Honing machines <BR> 搪孔头 Boring heads <BR> 卧式铣床 Milling machines,horizontal <BR> 卧式带锯 Saws,horizontal band <BR> 卧式加工中心 Machining centers,horizontal <BR> 卧式及立式加工中心 Machining centers,horizontal & vertical <BR> 万能铣床 Milling machines,universal <BR> 万能磨床 Grinding machines,universal <BR> 镗床 Boring machines <BR> 弯曲机 Bending machines <BR> 弯管机 Tube bending machines <BR> 通用加工中心 Machining centers,general <BR> 铜锻 Forging,copper <BR> 铣头 Milling heads <BR> 铣床 Milling machines <BR> 无心磨床 Grinding machines,centerless <BR> 无心精研机 Lapping machines,centerless <BR> 压模 Pressing dies <BR> 压铸冲模 Die casting dies <BR> 压铸机 Die casting machines <BR> 油冷却器 Oil coolers <BR> 造链机 Chain making tools <BR> 造线机 Cable making tools <BR> 造钉机 Nail making machines <BR> 印刷电器板油压冲孔脱料系统 PCB fine piecing systems <BR> 摇臂钻床 Drilling machines,radial <BR> 硬(软)板(片)材及自由发泡板机组 Hard/soft and free expansion sheet making plant <BR> 辗压机 Rolling machines <BR> 液压元件 Hydraulic components <BR> 液压冲床 Presses,hydraulic <BR> 液压动力元件 Hydraulic power units <BR> 液压工具 Hydraulic power tools <BR> 液压回转缸 Hydraulic rotary cylinders <BR> P型PVC高分子防水 P type PVC waterproof rolled sheet making plant <BR> 刨床 Planing machines <BR> 牛头刨床 Shapers <BR> 其他铸造 Casting,other <BR> 其他锻造 Forging,other <BR> 模芯 Mold core <BR> 模具 Molds <BR> 模具维修 Mold repair <BR> 模具打磨/磨纹 Mold polishing/texturing <BR> 模具单元 Mold & die components <BR> 模具加热器/冷却器 Mold heaters/chillers <BR> 磨轮 Grinding wheels <BR> 磨削工具 Grinding tools <BR> 磨床 Grinding machines <BR> 磨床工作台 Grinder bench <BR> 平衡设备 Balancing equipment <BR> 气油压虎钳 Pneumatic hydraulic clamps <BR> 气动冲床 Presses,pneumatic <BR> 气动工具 Pneumatic power tools <BR> 轴 shafts <BR> 轴承 Bearings <BR> 轴承配件 Bearing fittings <BR> 轴承加工机 Bearing processing equipment <BR> 肘杆式压力机 Presses,knuckle joint <BR> 铸铝 Casting,aluminium <BR> 铸铜 Casting,copper <BR> 铸造设备 Foundry equipment <BR> 铸钢 Casting,steel <BR> 铸灰口铁 Casting,gray iron <BR> 织麦激光切割机 Woven-Cutting machines <BR> 重力铸造机 Gravity casting machines <BR> 重型车床 Lathes,heavy-duty <BR> 主轴 spindles <BR> 扳手 Wrenches <BR> 拔丝机 Drawing machines <BR> 保温炉 Heat preserving furnaces <BR> 插床 Slotting machines <BR> 齿轮 Gears <BR> 齿轮切削机 Gear cutting machines <BR> 冲压机 Stamping parts <BR> 冲子研磨器 Punch formers <BR> 超声波打磨机 Grinders,ultrasonic <BR> 车床工作台 Lathe bench <BR> 磁性工具 Magnetic tools <BR> 传动链 Transmitted chains <BR> 床身式铣床 Milling machines,bed type <BR> 带传动 Belt drive <BR> 带锯 Saws,band <BR> 带锯床 Sawing machines,band <BR> 电脑数控镗床 CNC boring machines <BR> 电脑数控弯折机 CNC bending presses <BR> 电脑数控铣床 CNC milling machines <BR> 电脑数控线切削机 CNC wire-cutting machines <BR> 电脑数控磨床 CNC grinding machines <BR> 电脑数控车床 CNC lathes <BR> 电脑数控电火花线切削机 CNC EDM wire-cutting machines <BR> 电脑数控电火花机 CNC electric discharge machines <BR> 电脑数控雕刻机 CNC engraving machines <BR> 电脑数控机床配件 CNC machine tool fittings <BR> 电脑数控剪切机 CNC shearing machines <BR> 电脑数控钻床 CNC drilling machines <BR> 电动刀具 Electric power tools <BR> 电火花机 Electric discharge machines(EDM) <BR> 雕刻机 Engraving machines <BR> 刀片 Blades <BR> 刀具 Cutters <BR> 倒角机 Chamfer machines <BR> 多轴钻床 Drilling machines,multi-spindle <BR> 锻铝 Forging,aluminium <BR> 锻压机 Presses,forging <BR> 锻模 Forging dies <BR> 仿形铣床 Milling machines,duplicating <BR> 粉末冶金成型机 Powder metallurgic forming machines <BR> 反射炉 Reverberatory furnaces <BR> 钢锻 Forging,steel <BR> 高速车床 Lathes,high-speed <BR> 高速钻床 Drilling machines,high-speed <BR> 管筒制造机 Pipe & tube making machines <BR> 滚筒 Rollers <BR> 工具磨床 Grinders,tools & cutters <BR> 攻螺丝机 Tapping machines <BR> 弓锯 Saws,hack <BR> 虎钳 Vises <BR> 换模系统 Mold changing systems <BR> 夹盘 Chucks <BR> 夹具 Fixture <BR> 夹具/支持系统 Clamping/holding systems <BR> 剪切机 Shearing machines <BR> 加工中心机刀库 A.T.C.system <BR> 激光切割 Laser cutting <BR> 激光雕刻机 Engraving machines,laser <BR> 激光钢板切割机 Laser cutting for SMT stensil <BR> 集合管 Manifolds <BR> 矫直机 Straightening machines <BR> 金属板成型机 Sheet metal forming machines <BR> 金属板加工机 Sheet metal working machines <BR> 锯片 Blades,saw <BR> 锯床 Sawing machines <BR> 卷边工具 Crimping tools <BR> 晶圆切割机 Dicing saws <BR> 精密平口钳 Vises,tool-maker <BR> 精研机 Lapping machines <BR> 可锻铸铁 Casting,malleable iron <BR> 快速换模系统 Quick mold change systems <BR> 卡口 Bayonet <BR> 开关及按钮 Switches & buttons <BR> 钻石刀具 Diamond cutters <BR> 钻头 drills <BR> 钻模 Jigs <BR> 钻床 Drilling machines <BR> 钻床工作台 Drilling machines bench <BR> 自动压力机 Presses,transfer <BR> 自动车床 Lathes,automatic <BR> 注油机 Lubricators <BR> 转台 Rotary tables </P><P> 作者:中国数控世界
状 态:
离线
公司名称:
中华工控网
| 联 系 人: |
| 电 话: |
0755-26546361
| 传 真: |
0755-26585268 |
| 地 址: |
深圳市南山区创业路现代城华庭1栋6A |
| 邮 编: |
518054 |
| 主 页: |
