| 产品名称: |
NA50系列伺服马达
| 型 号: |
NA50 |
| 价 格: |
0.00 |
| 品 牌: |
日机电装nikki denso |
产品介绍: |
日本NIKKI DENSO ,NA50系列伺服电机具有超高速、高响应、体积小、惯量小等特点,转速达5000rpm,200HZ的响应频率,主要用于半导体,激光,检测,印刷等设备。型号:NA50-05NAZKNN-CE,NA50-10NALKNN-CE,NA50-10NAMKNN-CE,NA50-20NALKNN-CE,NA50-20NAMKNN-CE,NA50-40NALKNN-CE,NA50-40NAMKNN-CE,NA50-40BALKNN-CE,NA50-40BAMKNN-CE,NA50-75NAMKNN-CE,NA50-75BAMKNN-CE
| ■AC servomotor NA50Series
Item |
Unit Type |
NA50-05NAZKNN-CE |
NA50-10NALKNN-CE |
NA50-10NAMKNN-CE |
NA50-20NALKNN-CE |
NA50-20NAMKNN-CE |
Voltage spec |
VAC |
AC100/200 |
AC100 |
AC200 |
AC100 |
AC200 |
Rated output |
kW |
0.05 |
0.1 |
0.1 |
0.2 |
0.2 |
Rated torque |
Nm |
0.16 |
0.32 |
0.32 |
0.64 |
0.64 |
Rated speed |
rpm |
3000 |
3000 |
3000 |
3000 |
3000 |
Max speed |
rpm |
5000 |
5000 |
5000 |
5000 |
5000 |
Rated current |
A |
1 |
1.6 |
1.0 |
2.5 |
1.6 |
max. torque |
Nm |
0.48 |
0.95 |
0.95 |
1.7 |
1.91 |
Peak current |
A |
5.7 |
6.9 |
4.2 |
9.6 |
12.6 |
Power rate |
kW/s |
11.2 |
24.1 |
4.3 |
10.5 |
7.9 |
Rotor inertia |
kgfms2 |
0.00028 |
0.00064 |
0.00064 |
0.0017 |
0.0017 |
Item |
Unit Type |
NA50-40NALKNN-CE |
NA50-40NAMKNN-CE |
NA50-40BALKNN-CE |
NA50-40BAMKNN-CE |
NA50-75NAMKNN-CE |
NA50-75BA MKNN-CE |
Voltage spec |
VAC |
AC100 |
AC200 |
AC100 |
AC200 |
AC200 |
AC200 |
Rated output |
kW |
0.4 |
0.4 |
0.4 |
0.4 |
0.75 |
0.75 |
Rated torque |
Nm |
1.3 |
1.3 |
1.3 |
1.3 |
2.4 |
2.4 |
Rated speed |
rpm |
3000 |
3000 |
3000 |
3000 |
3000 |
3000 |
Max speed |
rpm |
4500 |
5000 |
4500 |
5000 |
4500 |
4500 |
Rated current |
A |
4.4 |
2.5 |
4.4 |
2.5 |
4.3 |
4.3 |
max. torque |
Nm |
3.36 |
3.36 |
3.36 |
3.36 |
5.73 |
7.64 |
Excitation current |
A |
2.7 |
4.5 |
4.2 |
9.6 |
12.6 |
13.8 |
Power rate |
kW/s |
11.2 |
24.1 |
20.7 |
44.8 |
36.5 |
49.8 |
Rotor inertia |
kgfms2 |
0.00023 |
0.00043 |
0.002 |
0.0037 |
0.0102 |
0.133 |
Weight |
Standard motor |
kg |
0.4 |
0.5 |
1.1 |
1.6 |
2.6 |
3.2 |
Motor with brake |
kg |
0.6 |
0.7 |
1.5 |
2.0 |
3.5 |
4.1 |
NA50-05NAZKNN-CE,NA50-10NALKNN-CE,NA50-10NAMKNN-CE,NA50-20NALKNN-CE,NA50-20NAMKNN-CE,NA50-40NALKNN-CE,NA50-40NAMKNN-CE,NA50-40BALKNN-CE,NA50-40BAMKNN-CE,NA50-75NAMKNN-CE,NA50-75BAMKNN-CE |
| 关 键 词: |
NA50-10 NA50-20 NA50-40 |
公司名称:
上海奥茵绅机电科技有限公司
| 联 系 人: |
耿新红
| 电 话: |
086-18964531017
| 手 机: |
13916694162 |
| 地 址: |
上海市浦东新区金桥出口加工区金豫路100号1号楼1005室 |
| 邮 编: |
201206 |
| 主 页: |
