| 产品名称: |
中空轴电机
| 型 号: |
中空轴电机 |
| 价 格: |
| 品 牌: |
日机电装nikki denso |
产品介绍: |
NIKKI DENSO 中空轴伺服电机
拥有60毫米中空轴感应式交流伺服电机的BSM系列,用户可以将通过中空管道穿过电线或其他设备。该系列的功率范围包括从1千瓦到11kW。 如果用户希望更大的中空轴,我们的大容量直 接驱动交流伺服电机可以满足要求。
Motor specification
Item |
Unit Type |
BSM-102-20ST |
BSM-202-20ST |
BSM-302-20ST |
BSM-402-20ST |
Rated output |
kW |
1.0 |
2.0 |
3.0 |
4.0 |
Number of poles |
P |
8 |
8 |
8 |
8 |
Rated torque |
N・m (kgf・m) |
4.81 (0.49) |
9.51 (0.97) |
14.32 (1.46) |
19.12 (1.95) |
Rated speed |
rpm |
2000 |
2000 |
2000 |
2000 |
Rated current |
A |
11.5 |
24 |
32 |
46 |
Instantaneous max. torque |
N・m (kgf・m) |
9.61 (0.98) |
19.02 (1.94) |
28.64 (2.92) |
36.28 (3.70) |
Excitation current |
A |
9 |
19 |
25 |
33 |
Power rate |
kW/s |
1.68 |
4.19 |
9.49 |
14.3 |
Angular accel |
rad/s2 |
350 |
440 |
663 |
750 |
Rotor inertia |
kgf・ms2 |
0.00140 |
0.0022 |
0.0022 |
0.0026 |
Rotor GD2 |
kgf・m2 |
0.055 |
0.085 |
0.085 |
0.101 |
Cooling method |
空冷自冷 |
Load factor |
%ED |
25 |
25 |
25 |
25 |
Weight |
kg |
30 |
36 |
36 |
41 |
Applicable controller |
NCS-FI |
-122 |
-242 |
-402 |
-752 |
Applicable driver |
NPS-FI |
-122 |
-242 |
-402 |
-752 |
(Declared speed:2000rpm) |
Item |
Unit Type |
BSM-552-20ST |
BSM-752-20ST |
BSM-113-20ST |
BSM-102-30ST |
Rated output |
kW |
5.5 |
7.5 |
11 |
1 |
Number of poles |
P |
8 |
8 |
8 |
6 |
Rated torque |
N・m (kgf・m) |
26.28 (2.68) |
35.79 (3.65) |
52.49 (5.35) |
3.14 (0.32) |
Rated speed |
rpm |
2000 |
2000 |
2000 |
3000 |
Rated current |
A |
51 |
71 |
82 |
6.5 |
N・m (kgf・m) |
52.56 (5.36) |
71.59 (7.30) |
104.99 (10.70) |
6.28 (0.64) |
A |
42 |
51 |
49 |
3.3 |
Power rate |
kW/s |
18.5 |
28.4 |
28.3 |
1.8 |
Angular accel |
rad/s2 |
705 |
795 |
540 |
571 |
Rotor inertia |
kgf・ms2 |
0.0038 |
0.00459 |
0.00997 |
0.00056 |
Rotor GD2 |
kgf・m2 |
0.149 |
0.180 |
1.391 |
0.022 |
Cooling method |
空冷自冷 |
空冷自冷 |
Load factor |
%ED |
25 |
25 |
25 |
100 |
Weight |
kg |
55 |
68 |
85 |
30 |
NCS-FI |
-752 |
-113 |
-153 |
-801 *1 |
Applicable driver |
NPS-FI |
-752 |
-113 |
-153 |
-801 *1 |
(3000rpm) |
| 关 键 词: |
中空轴 nikki BSM |
公司名称:
上海奥茵绅机电科技有限公司
| 联 系 人: |
耿新红
| 电 话: |
086-18964531017
| 手 机: |
13916694162 |
| 地 址: |
上海市浦东新区金桥出口加工区金豫路100号1号楼1005室 |
| 邮 编: |
201206 |
| 主 页: |
