HAH1BV and HAH1DR current sensor
The HAH1BV and HAH1DR family is best suited for DC, AC or pulse current measurement in high power and low voltage automotive battery monitoring (BV) and Motor Drive (DR) applications. It contains a galvanic isolation between the primary circuit (high power) and the secondary circuit (electronic circuit).
The HAH1BV and HAH1DR family gives you the choice of having different peak currents (from+/- 200A up to +/- 900A) in the same housing.
Automotive applications:
HAH1:
- Battery pack monitoring
- Hybrid vehicle batteries
- EV and utility vehicle batteries
- Motor Drive
- AC/DC Converter
| 产品检索结果 |
| 模块 |
扩展 |
原边理论值 |
测量范围 |
副边信号 |
供电电压 |
精度 (%) |
封装 |
| HAH1BV S/01 |
扩展 |
300 A |
300 A |
0-5 Uni |
3 |
On primary fastening |
技术 Open loop Hall Effect |
| HAH1BV S/02 |
扩展 |
500 A |
500 A |
0-5 Uni |
3 |
| HAH1BV S/03 |
扩展 |
600 A |
600 A |
0-5 Uni |
3 |
| HAH1BV S/04 |
扩展 |
700 A |
700 A |
0-5 Uni |
3 |
| HAH1BV S/06 |
扩展 |
400 A |
400 A |
0-5 Uni |
3 |
| HAH1BV S/07 |
扩展 |
200 A |
200 A |
0-5 Uni |
3 |
| HAH1BV S/08 |
扩展 |
200 A |
200 A |
0-5 Uni |
3 |
| HAH1BV S/09 |
扩展 |
300 A |
300 A |
0-5 Uni |
3 |
| HAH1BV S/13 |
扩展 |
200 A |
200 A |
0-5 Uni |
3 |
| HAH1BV S/16 |
扩展 |
200 A |
200 A |
0-5 Uni |
3 |
