产品名称: |
AX88180 -- 高性能Non-PCI 32位千兆以太网控制芯片
型 号: |
AX88180 |
价 格: |
0.00 |
品 牌: |
产品介绍: |
The AX88180 is a high-performance and cost-effective non-PCI Gigabit Ethernet controller for various embedded systems including consumer electronics and home network markets that require a higher bandwidth of network connectivity. The AX88180 supports 16/32-bit SRAM-like interface and Gigabit Ethernet MAC, which is IEEE802.3 10Base-T, IEEE802.3u 100Base-T, and IEEE802.3ab 1000Base-T compatible. The AX88180 supports full-duplex or half-duplex operation at 10/100/1000Mbps speed with auto-negotiation or manual setting. The AX88180 integrates embedded SRAM for packet buffering to accommodate high bandwidth applications and supports IP/TCP/UDP checksum in hardware to offload processing loading from microprocessor/microcontroller in an embedded system. |
规格:
- High-performance non-PCI local bus
- Supports 16/32-bit SRAM-like interface (US Patent Approval)
- Supports big/little endian data bus type
- Supports interrupt with high or low active trigger mode
- Highly-integrated Gigabit Ethernet controller
- Compatible with IEEE802.3, 802.3u, and 802.3ab standards
- Embeds SRAM for packet buffers
- Supports IP/TCP/UDP checksum offload
- Supports 10/100/1000Mbps data rate
- Supports full duplex operations with 1000Mbps data rate
- Supports full and half duplex operations with 10/100Mbps data rate
- Supports 10/100/1000Mbps N-way Auto- negotiation operation
- Supports 10/100/1000Mbps data rate with RGMII interface
- Supports IEEE 802.3x flow control for full-duplex operation
- Supports back-pressure flow control for half-duplex operation
- Supports packet length set by software
- Supports Jumbo frame
- Supports Wake-on-LAN function by following events
- Detection of a change in the network link state
- Receipt of a Magic Packet
- Supports optional EEPROM interface
- Supports system reference clock from 40MHz to 100MHz
- Integrates voltage regulator
- 3.3V power supply with 5V I/O tolerance
- 128-pin LQFP with CMOS process, RoHS package
方块图
选型指南
关 键 词: |
高级成度 小封装 兼容性稳定 |
