产品名称: 64 数字I/O输入输出卡
型  号: PCI 264
价  格:
品  牌: 西门子(SIEMENS)
Pci
Description
  • 64 digital I/O programmed using 8-channel ports
  • High switching power 70V/100mA
  • TTL compatible Inputs / Outputs
  • Protected inputs (70V)
  • Readable by PCI 102
  • Read / Write by PCI DX6
  • Output readback
  • 16 interrupt sources
  • "Photo" and external latch mode
  • High reliability / High density
  • I/O space in 32 bits
  • Support and supply of drivers (option)
Adas board
Description
The PCI 264 provides 64 digital inputs / outputs programmed by 8-channel ports.
The outputs are able to supply the necessary power for items such as: small relays, lamps, displays, etc.
The inputs are protected by diodes (70V max.) and remain TTL compatible.
Interrupt triggering can be defined by a change of front for each of the first 16 channels. These interrupt sources are maskable.
The PCI 264 owns a private bus to be managed by PCI 102 or PCI DX6 boards, this in the case of determinable real time applications.
PCI 164 similar software.
Iqnet
9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
Tél.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
PCI 264
64 DIGITAL INPUTS / OUTPUTS
PCI 264
SPECIFICATIONS (t = 25°C)
TYPE
INPUTS
- Number of channels 64
- Direction
Direction programming in 8 groups of 8 channels
DIGITAL OUTPUTS
- Type OPEN COLLECTOR
- DATA 1 = ON ; 0 = OFF
- Max. sust. voltage. 70V
- Max. current 100mA
- Max. power 2W
- Vce SAT < 300mV at 100mA
- Switching time
T"on" = 500ns T”off” = 2.5μs (RL = 1K Ω )
DIGITAL INPUTS
- Type TTL compatible triggers
- Protection 70V max.
- Impedance ≥ 470K Ω
- Readback These inputs enable automatic readback of the channels programmed as outputs
- Input frequency
100KHz maximum
POWER-UP
  Channels programmed as inputs
Output registers at "0" "off" state
INTERRUPTS
  16 channels can generate an interrupt as can the timers
1 interrupt level on &#171;&#160;INTA&#160;&#187;
PCI INTERFACE
- Bus PCI
- Transfers
32 bits in the Memory space
PRIVATE BUS
- Exchanges 16 bits
- Read PCI 102
- Read / Write
PCI DX6
POWER SUPPLY
- Voltage
&#160; + 5V/2A
PRESENTATION
- Dimensions in mm Short PCI format
- Front panel connector
1 μD 68 pins Female
ENVIRONMENT
- Operating temperature 0°C to + 60°C
- Storage temperature - 10°C to + 70°C
- Relative humidity
90 % (without condensation)
EUROPEAN NORMS &#160;
&#160; EMC - EN 61326
&#160; CE Compliance
&#160; ROHS - 2002/95/EC
HOW TO ORDER?
PCI 264
ACCESSORIES
- BCI Terminal blocks BCI 146
- STB Terminal blocks STB546 or
STB534 + STB532/STB520/STB552, or
STB514 + STB516/STB560/BCI140/BCI160
- Cables
WR368
关 键 词: ASAD PCI 264
公司名称: 深圳市申克工业设备有限公司
联 系 人: 赵鸿斌
电  话: 0755-83841930
手  机: 13537649763
地  址: 深圳市 福田区 福强路32号
邮  编: 518048
西门子74系列阀用定位器(74-SG1/74-SN1)
西门子智能阀门定位器(5DR5010-ONGOO-OAAO)
西门子353控制器(353)
西门子352P控制器(352P)
西门子阀用定位器(760E)
ADAS ICV726模( ICV726)
法国ADAS计数卡(PCI307)
西门子73系列阀用定位器(73N12F)
20 Mega 数据采集( PCI 102)
ADAS STB534连(STB534连接适配器)
ADAS STB532 (STB532)
