产品名称: 法国ADAS计数卡
型  号: PCI307
Pci StbBciSoftwareAdas Electronique
Description
  • 4 isolated 32-bit counting channels
  • 4 inputs per channel : A, B, strobe, Clear
  • 4 inputs levels +5V ; +12V ; +15V ; +24V
  • Low input current (# 6mA)
  • Counts up to 5MHz in any mode (10m)
  • Programmable filtering for noisy environments
  • Direct interface with incremental encoders (X1, X4)
  • 2 time bases and 1 program. clock
  • Power supply 5V/0.8A, galvanically isolated
  • Several program operating modes
  • 18 programmable interrupt sources
  • PCI interface 32 bits
  • Support and supply of drivers (option)
Adas board
Description
Designed for counting applications, the PCI 307 board provides 4 stand-alone 32-bit counters for performing frequency and period measurements, counting and counting down events, and conditioning incremental (circular or linear) encoders.
Designed to operate in noisy environments, the PCI 307 board uses photocoupled inputs and anti-bounce circuits.
The PCI 307 is fully programmable using easy-to-use and powerful software. It includes:
  • advanced interrupt management (18 sources),
  • programmable management of counters loading and reset-to-zero.
PCI 304 similar soft.
Iqnet
9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
Tél.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
PCI 307
4 ISOLATED 32-BIT COUNTING CHANNELS
PCI 307
SPECIFICATIONS (t = 25°C)
TYPE
4 COUNTING CHANNELS 32 BITS
INPUTS
- Per channel Channel "A", channel "B", strobe, clear
- Type Optocoupled, regulated low input current
- Inputs level + 5V, + 12V, + 15V, +24V
- Galvanic isolation Up to 2500V (1mn) to PCI
- Filtering Anti-bounce on counter inputs (A + B) software switchable adjustable frequencies of 125KHz, 1MHz, 10MHz
5 MHz in direct mode (10 meters max cf RS422 distance)
- Max. input frequencies
5 MHz in quadruple discriminator mode (X4)
ACCURACY
- Frequency measurement 10 -4 at 1KHz
- Period measurement
10 -4 at 1KHz
MEANS
- Internal clock Programmable from 100Hz to 10MHz in decades
- Time bases
2 (programmable from 0.01s to 10s in decades)
OPERATING MODES
Quadruple, double, single impulse per cycle for increment coders.
Counting up or down of events, measurement of impulse width and frequencies with prepositionable count-up or countdown.
Direct recognition of count-up or countdown modes and possibilities: Hysterisis, inhibition, counting, and preloading.
External possibilities and loading and reset software.
Possibility of interrupt after external loading, external clear, overflow, direction loading or end of time base.
INTERFACE PCI
- Decoding 32 bytes in memory space
- Interrupts
18 sources available
POWER SUPPLIES
- Consumption + 5V ± 0.25V / 1.2A max. + DC/DC
- DC/DC converter Isolated, + 5V / 0.8A (available for STB or BCI terminal blocks)
- Protection
Two 1A fuses on fuse-holders
PRESENTATION
- Format PCI short
- Front panel connectors 1 x µD 68 pins Female
- Matching terminal blocks
STB 546 - BCI 146
ENVIRONMENT
- Operating temperature 0°C to + 60°C
- Storage temperature - 10°C to + 70°C
- Humidity
90 % (without condensation)
EUROPEAN NORMS
  EMC - EN 61326
  CE Compliance
  ROHS - 2002/95/EC
关 键 词: ADAS 数据采集卡 计数卡
公司名称: 深圳市申克工业设备有限公司
联 系 人: 赵鸿斌
电  话: 0755-83841930
手  机: 13537649763
地  址: 深圳市 福田区 福强路32号
邮  编: 518048
64 数字I/O输入输出(PCI 264)
西门子74系列阀用定位器(74-SG1/74-SN1)
西门子智能阀门定位器(5DR5010-ONGOO-OAAO)
西门子353控制器(353)
西门子352P控制器(352P)
西门子阀用定位器(760E)
ADAS ICV726模( ICV726)
西门子73系列阀用定位器(73N12F)
20 Mega 数据采集( PCI 102)
ADAS STB534连(STB534连接适配器)
ADAS STB532 (STB532)
