产品名称: ADAS STB534连接适配器
型  号: STB534连接适配器
Stb Adas Electronique
Description
  • STB 512 : 16/32 Modulo adaptator
    STB 514 : 16/64 Modulo adaptator
    STB 534 : 32/64 Modulo adaptator
  • Low footprint and mounting on a DIN RAIL
  • Lets you switch from modulo 16 to modulo 32, modulo 16 to modulo 64 or modulo 32 to modulo 64 for interfacing BCI and STB series to ADAS I/O
  • Adaptator for flat ribbon
Adas board
Description
The STB 512, STB 514 and STB 534 interconnection terminal blocks simplify the connections between conditioners and I/O boards.
The STB 512 terminal block lets us switch from modulo 32 to 2 x 16.
The STB 514 terminal block lets us switch from modulo 32 to 4 x 16.
The STB 534 terminal block lets us switch from modulo 64 to 2 x 32.
They avoid the use of custom cables thus saving time and increasing productivity.
Other terminal blocks are also available to make our products easy to use in the following environments : MBI, VME/VXI, PC ISA, PC/PCI, CompactPCI, etc.
Iqnet
9 rue Georges Besse – BP 47 – 78330 FONTENAY LE FLEURY – FRANCE
Tél.:(33) 1 30 58 90 09 fax:(33) 1 30 58 21 33 http://www.adas.fr
Afaq
STB 512/514/534
MODULO ADAPTATORS
STB 512/514/534
SPECIFICATIONS (t = 25°C)
STB 512
TYPE
ADAPTER TERMINAL BLOCK
PURPOSE
Switching from modulo 8 to modulo 16
Switching from modulo 16 to modulo 32
Avoids re- cabling
INTERFACE
Digital : STB 516 / STB 560 to I/O boards
Analog : STB 582 to one-wire input analog boards
CONNECTIONS
To terminal blocks : 2 x HE10/50 pins
To boards : 1 x HE10/50 pins
PHYSICAL CHARACTERISTICS
- Dimensions in mm (L x W x H) 52 x 125 x 52
- Mounting
On DIN RAIL
STB 514
TYPE
PURPOSE
Routing a µD68 pins through 4 x HE10/50 pins
INTERFACE
Connects the I/O STB 516 ; STB 540 ; STB 560 and BCI 140, BCI 160
To PC PCI and Compact PCI boards
CONNECTIONS
To process : 4 x HE10/50
To boards : 1 x µD68 pins
- Dimensions in mm (L x W x H) 76 x 125 x 52
- Mounting
On DIN RAIL
STB 534
TYPE
PURPOSE
Routing a µD68 pins through 2 x HE10/50 pins
INTERFACE
Connects the I/O STB 552 ; STB 554 ; STB 520 ; STB 532 etc.
CONNECTIONS
To process : 2 x HE10/50
- Mounting
On DIN RAIL
EUROPEAN NORMS
  EMC - EN 61326
  CE Compliance
  ROHS - 2002/95/EC
关 键 词: ADAS STB534 连接适配器
公司名称: 深圳市申克工业设备有限公司
联 系 人: 赵鸿斌
电  话: 0755-83841930
手  机: 13537649763
地  址: 深圳市 福田区 福强路32号
邮  编: 518048
64 数字I/O输入输出(PCI 264)
西门子74系列阀用定位器(74-SG1/74-SN1)
西门子智能阀门定位器(5DR5010-ONGOO-OAAO)
西门子353控制器(353)
西门子352P控制器(352P)
西门子阀用定位器(760E)
ADAS ICV726模( ICV726)
法国ADAS计数卡(PCI307)
西门子73系列阀用定位器(73N12F)
20 Mega 数据采集( PCI 102)
ADAS STB532 (STB532)
