在报纸生产过程中使用康耐视 DataMan 500 读取条码
要解决的问题: 代替陈旧的激光扫描技术,在高速报纸生产线上进行条码读取,这些条码的高度和位置各不相同且位于塑料下面。
解决方案: DataMan® 500 条码读码器提供 100 % 的可靠性。
优势: DataMan 条码读码器具有无与伦比的读取速率,能够带来理想的追踪效果。DataMan 读码器不带有任何活动部件,这大大降低了 Axel Springer 过去为维修激光扫描仪花费的维护费用。
Speed is essential in the world of the printed word. Newspapers must reach their readers reliably, day in day out. Hamburg-Ahrensburg offset printers are supported by a DataMan® 500 from Cognex to guarantee smooth and accurate logistics. The image-based barcode reader, which has been integrated into the system by bci GmbH, lowered investment, maintenance and repair costs.
Hundreds of thousands of newspapers are rushing over the heads of the employees at great speed. Hot off the press, the headlines, news reports and latest stories are on their way to their readers, clamped firmly along the fold to the aerial conveyor belts. Speed is everything. News is only news if it is fresh, not if it is old hat. These are the demands made on the technology at Hamburg-Ahrensburg offset printers. Axel Springer has been printing newspapers for northern Germany here since 1983, in addition to publications on behalf of other publishers. This is where the words of Das Bild, the Hamburger Abendblatt, Die Zeit and many other print papers took physical form and were made visible for the readers. Barcodes are used to pack the newspapers into bundles to make sure they not only arrived quickly but also at the right address. For three decades the barcodes were read using a laser scanner with a tilting mirror, but recently this mature technology was replaced by the next generation of barcode readers: Cognex image-based logistics barcode readers, which ensure high precision identification. The intelligent DataMan 500, integrated by the bci GmbH and operational technology staff into the component systems of Axel Springer AG, reads the barcode codes at lightning speed and with 100 percent reliability.
Reflections from the creases
Anyone who has ever passed a newspaper kiosk early in the morning will be familiar with the piles of newspapers wrapped in plastic foil. The machines at the Hamburg-Ahrensburg offset printing press stack newspapers in piles up to 10 inches high (depending on the order quantity), put a covering sheet on top with 1-D codes, wrap the pile in transparent plastic and finally tie it up cross-wise with plastic packaging straps. The DataMan 500 reads the codes immediately after this step as the package passes along the conveyor belt. If there is one combination that you do not want from the point of view of an optical sensor, it is codes on paper with a variety of colors plus creased, highly reflective sheeting. This was a real challenge for the bci GmbH experts and was the key factor in the decision to choose the Cognex DataMan 500 barcode reader.
It was clear when the Axel Springer AG project started in November 2011 that the laser scanner was coming to the end of its operational life. Wear and tear on the tilting mirror and other movable parts was too great and the resulting maintenance and follow-up costs were too high. It was also becoming increasingly difficult to get hold of replacement parts for the aging equipment and the read failure rate was no longer acceptable. A decision was made to replace it with modern, image-based ID reading equipment from Cognex, which are designed with no moving parts that wear out.
Traceability
The high performance DataMan 500 made it possible for bci GmbH to achieve 100 percent reliability in reading the barcodes after a test phase of just four weeks. And that was for newspaper bundles ranging in height from 0.5 to 10 inches and variations in the position of the code over a range of 15 inches plus. That was no problem for the DataMan 500 because of its depth of field capabilities. To make maximum use of the reader’s potential, bci prioritized customer-specific programming. These complex challenges were overcome rapidly in a number of test runs.
Filtered light
The DataMan 500 only needs one master setting to manage the incoming packs of highly reflective newspapers with their different heights and varying positions. The intelligent DataMan utilizes an HPIA (high-powered illumination accessory). Both the DataMan 500 lens and the additional light source are fitted with polarizing filters, which effectively reduce the cross-fade produced by the packaging foil.
Because the pilot project is running so reliably, Hamburg-Ahrensburg offset printers are planning to replace the aging laser scanners throughout the system with Cognex barcode reading equipment in the medium term. The reasons for doing this are the lower investment costs and the reduction in maintenance costs.
With an eye on the future, the flexibility of DataMan 500 is also a significant plus for Axel Springer, as it will be easy to reprogram the Cognex image-based barcode reading equipment if they switch to using 2-D codes in the near future. Last but not least, the DataMan 500 even consumes significantly less electricity than the laser scanner.
公司名称: 康耐视中国
联 系 人: 市场部
电  话: 400-008-1133
传  真: 021-32091980
地  址: 上海浦东新区外高桥保税区泰谷路207号一楼D1座
邮  编: 200131
该厂商相关解决方案:
康耐视的Checker传感器确保瓶装检测的正确无误
全程质量跟踪确保西门子汽车业客户长期保持高满意度
康耐视的视觉系统保证更好的瓶装技术
TipTop冰淇淋的完美包装
Checker™ - 以100个工件/秒的速度实现完美无暇的标签检测
康耐视:复杂视觉应用的唯一解决方案
康耐视PatMax™- 适用于机器人应用环境的统一解决方案
康耐视视觉系统简化了激光焊接技术
康耐视实现外科植入物完全自动化检测
康耐视 In-Sight使汽车装配时间缩短了20%
对2000种不同的断路器实现百分之百的可靠检测
更多方案...
立即发送询问信息在线联系该解决方案厂商::
